> Обучение АКПП А604 (41ТЕ)
Гость_Мордашка_*
сообщение 31.3.2006, 10:02
Ниже приводится ссылка и, на случай недоступности ресурса, оригинальный текст об "обучении" АКПП А604 (41ТЕ) в домашних/полевых условиях.
http://www.txchange.com/a604.htm
Important Instructions
The A604 is the first transmission to control the release of one gear and the apply of another without the use of bands or sprags. It programs its shifting operation by sampling the vehicle's operation pattern while it is being driven. The sophisticated electronics present some unique installation problems that must be addressed if the transmission is to work properly and last.
To prevent 2-3 and 4-3 bindup and/or damage it is VERY IMPORTANT to 'fast re-schedule' the controller before road testing the vehicle. Because the controller will retain the program from the old transmission that had worn or burnt clutches it will increase the clutch apply rate. Most controllers won't re-set fast enough to prevent damage to the new clutches. To prevent damage the controller needs a 'fast re-schedule' before the road test.
With the wheels off the ground and the selector in OD position 1) Apply the throttle slowly until a speed of 45 to 50 mph is indicated. 2) Lift the throttle gently and allow the indicated speed to slow to 20 mph. 3) Gently apply the brakes to bring the wheels to a stop.
Repeat this at least 75 times while noticing the feel of the 2-3 shift. When a light throttle 2-3 shift no longer binds up or bogs the engine the transmission is ready to road test.
Take the vehicle on the road. At 38 mph lift the throttle and apply a very small amount of brake. If the 4-3 coast downshift is rough at 20 to 26 mph take the vehicle back up to 38 mph and lift the throttle again. At 32 to 35 mph add just enough throttle to barely make a 3-2 kick down shift. Do this 40 times and re-check for a rough 4-3 coast downshift. If the shift is still rough repeat the 3-2 kick down 40 to 80 times.
This procedure will program the transmission for proper shifts and should be performed whenever the transmission is repaired or replaced and whenever the battery is disconnected. Failure to follow these procedures may result in costly damage to internal components.
Так же полагаю не лишним ознакомиться с другими статьями посвященными АКПП, устанавливаемым на наши авто.
http://www.allpar.com/fix/trans.html
Сообщений в этой теме
- Мордашка   Обучение АКПП А604 (41ТЕ)   31.3.2006, 10:02
- - Laus   А может у нас кто американский знает и с переводом...   31.3.2006, 10:41
- - Laus   Ну че, полиглотов нету? :oops:   31.3.2006, 11:24
- - shalom   да-да пожалуйста помогите с переводом. а то на tra...   31.3.2006, 11:55
- - shalom   Вот, что выдает translate.ru: Важные Инструкции A...   31.3.2006, 12:29
- - Перецъ   Я попробую, тока попожа чуток. Поздно ща.   2.4.2006, 1:23
- - Перецъ   Итак, более или менее сносный, понятный перевод: ...   3.4.2006, 9:43
- - Laus   Спасибо за перевод! Теперь все более или менее пон...   3.4.2006, 15:11
- - AsMan   Цитата(Перчик)а также после каждого отключения акк...   3.4.2006, 15:52
- - Перецъ   Гыыы, мне тоже нравится! Значит, каждый раз, когда...   4.4.2006, 12:09
- - Валерыч   Re: Обучение АКПП А604 (41ТЕ)   14.4.2006, 13:18
|- - reshkin   Ну и как Парни ктонибудь это проделал и как резуль...   27.6.2007, 22:07
|- - 1b3ej46   И эта процедура поможет,чтобы обучить акпп?   3.10.2012, 20:45
- - Перецъ   Ну, у миня тоже ничего получилось вроде :)   15.4.2006, 21:18
- - RUS   Самое простое, это поехать на любой сервис, где ес...   16.7.2006, 11:42
|- - Anatolii57   Цитата(RUS @ 16.7.2006, 11:49) Самое прос...   29.11.2009, 16:54
- - crow   А это жестко - 75-80 раз! Со сканером поинтере...   20.7.2006, 21:29
- - fuadoller   Цитата(Мордашка @ 31.3.2006, 10:09) Ниже ...   13.5.2007, 22:52
|- - Serg   Цитата(fuadoller @ 13.5.2007, 23:59) доро...   14.5.2007, 8:08
|- - fuadoller   Цитата(Serg @ 14.5.2007, 8:15) Цитата(fua...   14.5.2007, 23:15
- - KRStwo   Сегодня поеду пробовать после работы. Поменял блок...   15.11.2007, 13:19
- - slavytich7   Здравствуйте,у меня Voyager eC, 2.4 2001 года.Проб...   9.1.2008, 16:59
|- - Serg   Цитата(slavytich7 @ 9.1.2008, 17:06) Здра...   9.1.2008, 17:18
|- - Said   Цитата(Serg @ 9.1.2008, 16:25) А не проще...   9.1.2008, 17:45
|- - ezop   Цитата(Said @ 9.1.2008, 17:52) Цитата(Ser...   9.1.2008, 18:29
|- - Said   Цитата(ezop @ 9.1.2008, 17:36) Цитата(Sai...   9.1.2008, 18:35
|- - RUS   Цитата(ezop @ 9.1.2008, 18:36) При нормал...   9.1.2008, 20:20
|- - ezop   Цитата(RUS @ 9.1.2008, 20:27) Цитата(ezop...   9.1.2008, 22:51
- - RUS   При первых поездках не произойдёт. А обучение коро...   10.1.2008, 7:47
|- - ezop   Цитата(RUS @ 10.1.2008, 7:54) При первых ...   10.1.2008, 9:42
|- - RUS   Цитата(ezop @ 10.1.2008, 9:49) Цитата(RUS...   10.1.2008, 11:01
|- - ezop   Цитата(RUS @ 10.1.2008, 11:08) Цитата(ezo...   10.1.2008, 11:20
- - slavytich7   Спасибо всем...Но в итоге-может кто-нибудь посовет...   23.1.2008, 16:23
|- - ezop   Цитата(slavytich7 @ 23.1.2008, 16:30) Спа...   23.1.2008, 17:19
- - lis-aleks   Господа ! Додж-Караван 2.4 2007год пробег 2300...   27.5.2009, 23:42
- - Александр71   так может дело не в АКПП. если обороты скачут и ди...   28.5.2009, 8:54
- - alekstix   Может она такая и есть, эта динамика,даже если она...   28.5.2009, 9:01
|- - creativer   напишу в тему. зимой лопнул шланг на акпп, вытекло...   28.5.2009, 11:02
- - lis-aleks   Обороты двигателя не скачут,работает ровно(провода...   29.5.2009, 19:13
- - processor   Зимой после замены аккумлятора заметил, что коробк...   31.5.2009, 0:48
- - Антуан   не подойдет, нужен StarSCAN или DRBIII   29.11.2009, 18:04
|- - Anatolii57   Цитата(Антуан @ 29.11.2009, 18:11) не под...   27.12.2009, 19:02
|- - alexauto2005   [/quote] В V30 тоже есть некоторые функции прове...   27.12.2009, 21:41
|- - Anatolii57   Господа! Как с помощью V30 посмотреть пробег с...   2.3.2010, 20:36
- - ycons   3Цитата(Мордашка @ 31.3.2006, 10:09) Ниже...   20.3.2010, 17:22
- - TheStereo   ага, если я буду это делать после скидывания клемм...   20.3.2010, 23:24
|- - ycons   Цитата(TheStereo @ 20.3.2010, 23:31) ага,...   21.3.2010, 0:34
- - gidrograff   парни,приветствую. вот в чем моя трабла: при запус...   27.5.2010, 12:38
- - vicrally   при переключении передачь автостиком коробка чему ...   16.1.2011, 3:39
- - Илья_я   Ребята,у меня тоже проблема с АКПП А604,после заме...   2.8.2013, 21:45
- - Илья_я   И может кто подскажет куда можно обратиться за обу...   2.8.2013, 22:02
- - Veyvel   Цитата(Илья_я @ 2.8.2013, 23:09) И может ...   3.8.2013, 18:35
RSS Текстовая версия Сейчас: 17.9.2026, 15:15Дизайн IPB
