Цитата(Tax @ 15.6.2010, 14:15)
Прошу сильно ногами не пинать, в поиске лазил, для климы не нашел. Как запустить калибровку заслонок на ТиК с трех-зонным климатом. Климат электронный. Поиск выдает одновременное нажатие кнопок омывателя заднего стекла и постоянное движение заднего дворника. Это не помогает.
В мануале прописана только одна процедура что на одно-, что на трёх-зонный....
STANDARD PROCEDURE - HEATER-A/C
CONTROL CALIBRATION
The heater-A/C control module must be recalibrated
each time an actuator motor or the control
module is replaced. If the vehicle is so equipped, the
calibration procedure also includes rear HVAC positions
for each actuator motor.
(1) Turn the ignition switch to the On position.
(2) Simultaneously depress and hold the Power
and Recirculation buttons on the heater-A/C control
for at least five seconds. The manual heater-A/C control
power Light Emitting Diode (LED) and Recirculation
LED, or the Automatic Temperature Control
(ATC) heater-A/C control Delay and Recirculation
graphics will begin to flash when the calibration procedure
has begun.
(3) The calibration procedure should take less than
two minutes to complete for the manual heater-A/C
control, and less than twenty seconds for the ATC
heater-A/C control. When the LEDs or graphics stop
flashing, the calibration procedure is complete.
(4) If the LEDs or graphics continue to flash
beyond the normal three minute (manual) or twenty
second (ATC) calibration time, it indicates that the
heater-A/C control has detected a failure and a Diagnostic
Trouble Code (DTC) has been set. Use a
DRBIIIt scan tool to perform further diagnosis. Refer
to the appropriate diagnostic information. The LEDs
or graphics will continue to flash even after the ignition
switch is cycled Off and On, until a successful
calibration is completed or until the vehicle has been
driven about 13 kilometers (8 miles).
