2 страниц V   1 2 >
Тема закрытаНачать новую тему
> Коды самодиагностики, OBD-I и OBD-II
Гость_шахтер_*
сообщение 1.6.2008, 1:27
Чета навеяло! Кто одно читать не умеет, кто готовое без лупы прочесть не может.
Систематизирую. Вернее, пробую...
ОБД1 переводить и понимать рекомендуется самостоятельно, полезный треннинг..
OBD-I
Code Description of Trouble Code
11 Timing belt skipped 1 tooth or more from initial learned value;
Intermittent loss of either camshaft or crankshaft position sensor;
No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles
13 No change in manifold absolute pressure (MAP) from start to run
14 Manifold absolute pressure (MAP) sensor voltage out of range
15 No vehicle speed sensor signal
17 Closed loop temp not reached or engine cold too long
21 02 sensor problem (oxygen sensor), upstream or downstream
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle position sensor (TPS) out of range, or disagrees with MAP
25 Idle air control motor circuits problem, target idle not reached (+/- 200), vacuum leak found
27 Injector control circuit problem
31 Evaporator purge flow monitor failure or evaporator solenoid circuit problem
32 Exhaust gas recirculating (EGR) system failure or solenoid circuit problem
33 A/C clutch relay circuit problem
34 Speed control solenoid circuits problem
35 Radiator fan control relay circuit problem
37 Torque converter clutch solenoid circuit or park/neutral switch failure
41 Generator field not switching properly
42 Fuel pump relay control circuit problem
Auto shutdown (ASD) relay control circuit problem
No ASD relay output voltage at PCM
Fuel level sending unit - volts out of range
Fuel level sending unit - no change over miles
43 Multiple/ single cylinder misfire
44 Battery temp sensor volts out of range
46 Charging system voltage too high
47 Charging system voltage too low
51 Fuel system lean
52 Fuel system rich
53 Internal controller failure
54 No cam signal at PCM
55 End of error messages (If you get this only, no errors were found)
62 PCM failure - SRI mile not stored
63 PCM failure - EEPROM write denied
64 Catalytic converter efficiency failure
65 Power steering switch failure
OBD-II
Перевод корявый , не мой, но инфы много.. и понять можно. Касается не только Крайслеров.
Пятизначный код ошибки OBD-II означает следующее:
первая позиция:
P - is for powertrain codes
B - is for body codes
C - is for chassis codes
вторая позиция:
0 - общий для OBD-II код
1 - код производителя
третья позиция - тип неисправности:
1 - топливная система или воздухоподача
2 - топливная система или воздухоподача
3 - система зажигания
4 - вспомогательный контроль
5 - холостой ход
6 – ECU (РСМ) или его цепи
7 - трансмиссия
8 - трансмиссия
четвертая и пятая позиции –
порядковый номер ошибки
0100 Массовый или объемный расходомер воздуха неисправность цепи
0101 Массовый или объемный расходомер воздуха -проблема диапазон измерений
0102 Массовый или объемный расходомер воздуха -низкое напряжение сигнала
0103 Массовый или объемный воздуха -высокое напряжение сигнала
0104 Массовый или объемный расходомер воздуха -прерывистый сигнал
0105 Неисправность цепи абсолютного или барометрического давления
0106 Проблема диапазона измерений абсолютного или барометрического давления
0107 Низкое напряжение сигнала абсолютного или барометрического давления
0108 Высокое напряжение сигнала абсолютного или барометрического давления
0109 Прерывистый сигнал датчика абсолютного или барометрического давления
0110 Цепь температуры воздуха на впуске -неисправность цепи
0111 Цепь температуры воздуха на впуске -проблемы диапазона измерений
0112 Цепь температуры. воздуха на впуске -низкий входной сигнал
0113 Цепь температуры. воздуха на высокий входной сигнал
0114 Цепь температуры .воздуха на впуске прерывистый сигнал
0115 Температура охлаждающей жидкости неисправность цепи
0116 Температура охлаждающей жидкости проблемы диапазона измерений
0117 Температура охлаждающей жидкости низкий входной сигнал цепи
0118 Температура охлаждающей жидкости высокий сигнал цепи
0119 Температура охлаждающей жидкости прерывистый входной сигнал цепи
0120 Датчик положения педали дросселя неисправность цепи выключателя А
0121 Датчик положения педали дросселя проблемы рабочего диапазона цепи выключателя А
0122 Датчик положения педали дросселя низкий сигнал выключателя А
0123 Датчик положения педали дросселя высокий сигнал выключателя А
0124 Датчик положения педали дросселя прерывистый сигнал выключателя А
0125 Недостаточная температура для замыкания петли управления. расходом
0126 Недостаточная температура для устойчивого режима
0130 Неисправность цепи датчика O2(датчик 1 блока 1)
0131 Низкое напряжение датчика O2(датчик 1 блока 1)
0132 Высокое напряжение датчика O2(датчик 1 блока 1)
0133 Медленная реакция датчика O2(датчик 1 блока 1)
0134 Нет активности в цепи датчика O2(блок1 датчик 1)
0135 Неисправность цепи подогревателя датчика О2 (блок 1 датчик 1)
0136 Неисправность цепи датчика O2(датчик 2 блока 1)
0137 Низкое напряжение датчика O2(датчик 2 блока 1)
0138 Высокое напряжение датчика O2(датчик 2 блока 1)
0139 Медленная реакция датчика O2(датчик 2 блока 1)
0140 Нет активности в цепи датчика O2(блок1 датчик 2)
0141 Неисправность цепи подогревателя датчика О2 (блок 1 датчик 2)
0142 Неисправность цепи датчика O2(датчик 3 блока 1)
0143 Низкое напряжение датчика O2(датчик 3 блока 1)
0144 Высокое напряжение датчика O2(датчик 3 блока 1)
0145 Медленная реакция датчика O2(датчик 3 блока 1)
0146 Нет активности в цепи датчика O2(блок1 датчик 3)
0147 Неисправность цепи подогревателя датчика О2 (блок 1 датчик 3)
0150 Неисправность цепи датчика O2(датчик 1 блока 2)
0151 Низкое напряжение датчика O2(датчик 1 блока 2)
0152 Высокое напряжение датчика O2(датчик 1 блока 2)
0153 Медленная реакция датчика O2 (датчик 1 блока 2)
0154 Нет активности в цепи датчика O2 (блок2 датчик 1)
0155 Неисправность цепи подогревателя датчика О2 (блок 2 датчик 1)
0156 Неисправность цепи датчика O2 датчик 2 блока 2)
0157 Низкое напряжение датчика O2 (датчик 2 блока 2)
0158 Высокое напряжение датчика O2 (датчик 2 блока 2)
0159 Медленная реакция датчика O2 датчик 2 блока 2)
0160 Нет активности в цепи датчика O2 (блок2 датчик 2)
0161 Неисправность цепи подогревателя датчика О2 (блок 2 датчик 2)
0162 Неисправность цепи датчика O2 (датчик 3 блока 2)
0163 Низкое напряжение датчика O2 (датчик 3 блока 2)
0164 Высокое напряжение датчика O2 (датчик 3 блока 2)
0165 Медленная реакция датчика O2 (датчик 3 блока 2)
0166 Нет активности в цепи датчика O2 (блок2 датчик 3)
0167 Неисправность цепи подогревателя датчика О2 (блок 2 датчик 3)
0170 Неисправность смесеобр.(блок 1)
0171 Смесь очень бедная (блок 1)
0172 Смесь очень богатая (блок 1)
0173 Неисправность смесеобр.(блок 2)
0174 Смесь очень бедная (блок 2)
0175 Смесь очень богатая (блок 2)
0176 Неисправность цепи датчика композицци топлива
0177 Проблемы диапазона измерений датчика композицци топлива
0178 Низкое напряжение цепи датчика композицци топлива
0179 Высокое напряжение цепи датчика композицци топлива
0180 Датчик А композиции топлива неисправность цепи
0181 Датчик А композиции топлива диапазона сигнала цепи
0182 Датчик А композиции топлива низкий входной сигнал цепи
0183 Датчик А композиции топлива высокий входной сигнал цепи
0184 Датчик А композиции топлива прерывистый входной сигнал цепи
0185 Датчик А композиции топлива неисправность цепи
0186 Датчик А композиции топлива ошибка диапазона сигнала цепи
0187 Датчик А композиции топлива низкий входной сигнал цепи
0188 Датчик А композиции топлива высокий входной сигнал цепи
0189 Датчик А композиции топлива прерывистый входной сигнал цепи
0190 Датчик давления топливной рейки-неисправность цепи
0191 Датчик давления топливной рейки-ошибка диапазона сигнала цепи
0192 Датчик давления топливной рейки-низкий входной сигнал цепи
0193 Датчик давления топливной рейки-высокий входной сигнал цепи
0194 Датчик давления топливной рейки-прерывистый входной сигнал цепи
0195 Датчик температуры масла двиг.- неисправность цепи
0196 Датчик температуры масла двиг.-проблемы диапазона измерений
0197 Датчик температуры масла двиг.- низкий входной сигнал цепи
0198 Датчик температуры масла двиг.-высокий входной сигнал цепи
0199 Датчик температуры масла двиг.-прерывистый входной сигнал цепи
0200 Неисправность цепи форсунки
0201 Неисправность цепи форсунки - цилиндр 1
0202 Неисправность цепи форсунки - цилиндр 2
0203 Неисправность цепи форсунки - цилиндр 3
0204 Неисправность цепи форсунки - цилиндр 4
0205 Неисправность цепи форсунки - цилиндр 5
0206 Неисправность цепи форсунки - цилиндр 6
0207 Неисправность цепи форсунки - цилиндр 7
0208 Неисправность цепи форсунки - цилиндр 8
0209 Неисправность цепи форсунки - цилиндр 9
0210 Неисправность цепи форсунки - цилиндр 10
0211 Неисправность цепи форсунки - цилиндр 11
0212 Неисправность цепи форсунки - цилиндр 12
0213 Неисправность форсунки 1 холодного пуска
0214 Неисправность форсунки 2 холодного пуска
0215 Неисправность соленоида выключения двигателя
0216 Неисправность цепи управления временем впрыска
0217 Перегрев двигателя
0218 Перегрев трансмиссии
0219 Превышение оборотов двигателя
0220 Датчик положения педали дросселя не исправность цепи выключателя В
0221 Датчик положения педали дросселя проблемы рабочего диапазона цепи выключателя В
0222 Датчик положения педали дросселя низкий сигнал выключателя В
0223 Датчик положения педали дросселя высокий сигнал выключателя В
0224 Датчик положения педали дросселя прерывистый сигнал выключателя В
0225 Датчик положения педали дросселя неисправность цепи выключателя С
0226 Датчик положения педали дросселя проблемы рабочего диапазона цепи выключателя С
0227 Датчик положения педали дросселя низкий сигнал выключателя С
0228 Датчик положения педали дросселя высокий сигнал выключателя С
0229 Датчик положения педали дросселя прерывистый сигнал выключателя В
0230 Неисправность первичной цепи топливного насоса
0231 Низкое напряжение топливного .насоса
0232 Высокое напряжение топливного. насоса
0233 Обрыв вторичной цепи топливного насоса
0234 Engine over boost condition
0235 Датчик превышен.турбокомпрессора неисправность цепи
0236 Датчик превышен.турбокомпрессора ошибка диапазона сигнала цепи
0237 Датчик превышен.турбокомпрессора низкое напряжение цепи
0238 Датчик превышен.турбокомпрессора низкое напряжение цепи
0239 Датчик превышен.турбокомпрессора неисправность цепи
0240 Датчик превышен.турбокомпрессора ошибка диапазона сигнала цепи
0241 Датчик превышен.турбокомпрессора ошибка диапазона сигнала цепи
0242 Датчик превышен.турбокомпрессора высокое напряжение цепи
0243 Соленоид А перепускного клапана турбокомпр.-неисправность цепи
0244 Соленоид А перепускного клапана турбоком.-проблема диапаз.измер.
0245 Соленоид А перепускного клапана турбоком.-низкое напряжен. цепи
0246 Соленоид А перепускного клапана турбоком.-высокое напряжен.цепи
0247 Соленоид В перепускного клапана турбокомпр.-неисправность цепи
0248 Соленоид В перепускного клапана турбоком.-проблема диапаз.измер.
0249 Соленоид В перепускного клапана турбоком.-низкое напряжен. цепи
0250 Соленоид В перепускного клапана турбоком.-высокое напряжен.цепи
0251 Контроль дозирования топлива "A"насоса впрыска-неисправность (насос с кулачковым ротором)
0252 Контроль дозирования топлива "A"насоса впрыска-проблем.диапазон. (насос с кулачковым ротором)
0253 Контроль дозирования топлива "A"насоса впрыска-низк.напряжен.цепи (насос с кулачковым ротором)
0254 Контроль дозирования топлива "A"насоса впрыска-выс.напряжен.цепи (насос с кулачковым ротором)
0255 Контроль дозирования топлива "A"насоса впрыска-прерывист.сигнал (насос с кулачковым ротором)
0256 Контроль дозирования топлива "В"насоса впрыска-неисправность (насос с кулачковым ротором)
0257 Контроль дозирования топлива "В"насоса впрыска-проблем.диапазон. (насос с кулачковым ротором)
0258 Контроль дозирования топлива "В"насоса впрыска-низк.напряжен.цепи (насос с кулачковым ротором)
0259 Контроль дозирования топлива "В"насоса впрыска-выс.напряжен.цепи (насос с кулачковым ротором)
0260 Контроль дозирования топлива "В"насоса впрыска-прерывист.сигнал (насос с кулачковым ротором)
0261 Низк.напряж.цепи форсунки цил.1
0262 Высок.напряж.цепи форсунки цил.1
0263 Снижение баланса мощности по первому цилиндру
0264 Низк.напряж.цепи форсунки цил.2
0265 Высок.напряж.цепи форсунки цил.2
0266 Снижение баланса мощности по второму цилиндру
0267 Низк.напряж.цепи форсунки цил.3
0268 Высок.напряж.цепи форсунки цил.3
0269 Снижение баланса мощности по третьему цилиндру
0270 Низк.напряж.цепи форсунки цил.4
0271 Высок.напряж.цепи форсунки цил.4
0272 Снижение баланса мощности по четвертому цилиндру
0273 Низк.напряж.цепи форсунки цил.5
0274 Высок.напряж.цепи форсунки цил.5
0275 Снижение баланса мощности по пятому цилиндру
0276 Низк.напряж.цепи форсунки цил.6
0277 Высок.напряж.цепи форсунки цил.6
0278 Снижение баланса мощности по шестому цилиндру
0279 Низк.напряж.цепи форсунки цил.7
0280 Высок.напряж.цепи форсунки цил.7
0281 Снижение баланса мощности по седьмому цилиндру
0282 Низк.напряж.цепи форсунки цил.8
0283 Высок.напряж.цепи форсунки цил.8
0284 Снижение баланса мощности по восьмому цилиндру
0285 Низк.напряж.цепи форсунки цил.9
0286 Высок.напряж.цепи форсунки цил.9
0287 Снижение баланса мощности по девятому цилиндру
0288 Низк.напряж.цепи форсунки цил.10
0289 Высок.напр.цепи форсунки цил.10
0290 Снижение баланса мощности по десятому цилиндру
0291 Низк.напряж.цепи форсунки цил.11
0292 Высок.напр.цепи форсунки цил.11
0293 Снижение баланса мощности по одинадцатому цилиндру
0294 Низк.напряж.цепи форсунки цил.12
0295 Высок.напр.цепи форсунки цил.12
0296 Снижение баланса мощности по двенадцатому цилиндру
0300 Обнаружены случайные пропуски зажигания во многих цилиндрах
0301 Пропуски зажигания в цилиндре 1
0302 Пропуски зажигания в цилиндре 2
0303 Пропуски зажигания в цилиндре 3
0304 Пропуски зажигания в цилиндре 4
0305 Пропуски зажигания в цилиндре 5
0306 Пропуски зажигания в цилиндре 6
0307 Пропуски зажигания в цилиндре 7
0308 Пропуски зажигания в цилиндре 8
0309 Пропуски зажигания в цилиндре 9
0310 Пропуски зажигания в цилиндре 10
0311 Пропуски зажигания в цилиндре 11
0312 Пропуски зажигания в цилиндре 12
0320 Неисправность цепи входной скорости распределителя зажигания
0321 Ошибка диапазона цепи входной скорости распределителя зажигания
0322 Нет сигнала цеп входной скорости распределителя зажигания
0323 Прерывмчтый сигнал входной скорости распределителя зажигания
0325 Неисправность цепи датчика детонации 1 (блок 1 или один датчик)
0326 Ошибка диапазона цепи датчика детонации 1 блок 1 или один датчик)
0327 Низкий сигнал цепи датчика детонации 1(блок 1 или один датчик)
0328 Высокий сигнал цепи датчик.детонации 1(блок 1 или один датчик)
0329 Прерывистый сигнал датчика детонации 1(блок 1 или один датчик)
0330 Неисправность цепи датчика детонации 2 (блок 2)
0331 Ошибка диапазона цепи датчика детонации 2 (блок 2)
0332 Низкий сигнал цепи датчика детонации 2(блок 2)
0333 Высокий сигнал цепи датчика детонации 2 (блок 2)
0334 Прерывистый сигнал датчика детонации 2(блок 2)
0335 Датчик А положения колевала -неисправность цепи
0336 Датчик А положения колевала -ошибка диапазона сигнала цепи
0337 Датчик А положения колевала -низкий входной сигнал цепи
0338 Датчик А положения колевала -высокий входной сигнал цепи
0339 Датчик А положения колевала -прерывистый входной сигнал цепи
0340 Датчик положения распредвала -неисправность цепи
0341 Датчик положения распредвала -ошибка диапазона сигнала цепи
0342 Датчик положения распредвала -низкий входной сигнал цепи
0343 Датчик положения распредвала -высокий входной сигнал цепи
0344 Датчик положения распредвала -прерывистый входной сигнал цепи
0350 Катушка зажигания-неисправность первичной или вторичной цепи
0351 Катушка зажигания А - неисправн. первичной или вторичной цепи
0352 Катушка зажигания B - неисправн. первичной или вторичной цепи
0353 Катушка зажигания C - неисправн. первичной или вторичной цепи
0354 Катушка зажигания D - неисправн. первичной или вторичной цепи
0355 Катушка зажигания E - неисправн. первичной или вторичной цепи
0356 Катушка зажигания F - неисправн. первичной или вторичной цепи
0357 Катушка зажигания G - неисправн. первичной или вторичной цепи
0358 Катушка зажигания H - неисправн. первичной или вторичной цепи
0359 Катушка зажигания I - неисправн. первичной или вторичной цепи
0360 Катушка зажигания J - неисправн. первичной или вторичной цепи
0361 Катушка зажигания K - неисправн. первичной или вторичной цепи
0362 Катушка зажигания L - неисправн. первичной или вторичной цепи
0370 Неисправность сигнала синхронизации высокого разрешения А
0371 Очень много имнульсов сигнала синхрониз.высокого разрешения А
0372 Очень мало имнульсов сигнала синхрониз.высокого разрешения А
0373 Несистематическая ощибка импульсов сигнала синхронизации высокого разрешения А
0374 Нет импульсов сигнала синхронизации высокого разрешения А
0375 Неисправность сигнала синхронизации высокого разрешения В
0376 Очень много имнульсов сигнала синхрониз.высокого разрешения В
0377 Очень мало имнульсов сигнала синхрониз.высокого разрешения В
0378 Несистематическая ощибка импульсов сигнала синхронизации высокого разрешения А
0379 Нет импульсов сигнала синхронизации высокого разрешения А
0380 Неисправность цепи свечей подогрева "A"
0381 Индикатор работы свечей подогрева неисправность цепи
0382 Неисправность цепи свечей подогрева "В"
0385 Датчик В положения колевала -неисправность цепи
0386 Датчик В положения колевала -ошибка диапазона сигнала цепи
0387 Датчик В положения колевала -низкий входной сигнал цепи
0388 Датчик В положения колевала -высокий сигнал цепи
0389 Датчик В положения колевала - прерывистый входной сигнал цепи
0400 Неисправность потока рециркуляции выхлопных газов
0401 Обнаружен недостаточный поток рециркуляции выхлопных газов
0402 Обнаружеы утечки потока рециркуляции выхлопных газов
0403 Неисправность цепи рециркуляции выхлопных газов
0404 Цепь рециркуляции выхлопных газов-ошибка диапазона сигнала
0405 Низкий сигнал цепи датчика А рециркуляции выхлопных газов
0406 Высокий сигнал цепи датчика А рециркуляции выхлопных газов
0407 Низкий сигнал цепи датчика В рециркуляции выхлопных газов
0408 Высокий сигнал цепи датчика В рециркуляции выхлопных газов
0410 Неисправность системы впрыска вторичного воздуха
0411 Обнаружен неправильн.поток системы впрыска вторичного воздуха
0412 Неисправность цепи клапана переключения А системы впрыска вторичного воздуха
0413 Обрыв цепи клапана переключения А системы впрыска вторич.воздуха
0414 Короткое замыкание цепи клапана переключения А системы впрыска вторичного воздуха
0415 Неисправность цепи клапана переключения В системы впрыска вторичного воздуха
0416 Обрыв цепи клапана переключения В системы впрыска вторич.воздуха
0417 Короткое замыкание цепи клапана переключения В системы впрыска вторичного воздуха
0418 Неисправность цепи реле "A" системы впрыска вторичного воздуха
0419 Неисправность цепи реле "В" системы впрыска вторичного воздуха
0420 Эффективность каталитической системы ниже предельной (блок 1)
0421 Эффективность разогревающегося катализат.ниже предельн.(блок 1)
0422 Эффективность главной каталитич. системы ниже предельной (блок 1)
0423 Эффективность нагретого катализатора ниже предельной (блок 1)
0424 Температура нагрева катализатора ниже предельной (блок 1)
0430 Эффективность каталитической системы ниже предельной (блок 2)
0431 Эффективность разогревающегося катализат.ниже предельн.(блок 2)
0432 Эффективность главной каталитич. системы ниже предельной (блок 2)
0433 Эффективность нагретого катализатора ниже предельной (блок 2)
0434 Температура нагрева катализатора ниже предельной (блок 2)
0440 Неисправность системы управления улавливанием паров топлива
0441 Система управ.улавливанием паров топлива-некоррект.поток продувки
0442 Система управ.улавливанием паров топлива-обнаруж.небольшие утечки
0443 Неисправность цепи управления клапаном продувки системы улавливания паров топлива
0444 Обрыв цепи управления клапаном продувки системы улавливания паров топлива
0445 Короткое замыкание цепи управления клапаном продувки системы улавливания паров топлива
0446 Неисправность цепи управления клапаном вентиляции системы улавливания паров топлива
0447 Обрыв цепи управл.клапаном вентил.систем.улавлив.паров топлива
0448 Короткое замыкание цепи управления клапаном вентиляции системы улавливания паров топлива
0449 Неисправность цепи электромагнитного клапана вентиляции системы улавливания паров топлива
0450 Неисправность датчика давления системы управления улавливанием паров топлива
0451 Ошибка диапазона измерений датдавления системы управления улавливанием паров топлива
0452 Низкий входной сигнал датчика давления системы улавлив.паров
0453 Высокий входной сигнал датчика давления системы управления улавливанием паров топлива
0454 Прерывистый сигнал датчика давления системы управления улавливанием паров топлива
0455 Обнаружены большие утечки системы управления улавливанием паров топлива
0460 Неисправность цепи датчика уровня топлива
0461 Цепь датчика уровня топлива -проблема диапазона измерений
0462 Цепь датчика уровня топлива -низкий уровень входного сигнала
0463 Цепь датчика уровня топлива -высокий уровень входного сигнала
0464 Цепь датчика уровня топлива - прерывистый сигнал
0465 Неисправность цепи датчика расхода продувки
0466 Цепь датчика расхода продувки -проблема диапазона измерений
0467 Цепь датчика расхода продувки - низкий уровень входного сигнала
0468 Цепь датчика расхода продувки - высокий уровень входного сигнала
0469 Цепь датчика расхода продувки - прерывистый сигнал
0470 Неисправность датчика давления выхлопных газов
0471 Датчик давления выхлопных газов проблема диапазона измерений
0472 Дат.давл.выхл.газов-низ.уров.сиг
0473 Дат.давл.выхл.газов-выс.уров.сиг
0474 Датчик давления выхлопных газов-прерывистый сигнал
0475 Клапан управ.давлен.выхл.газов-неисправность цепи
0476 Клапан управ.давлен.выхл.газов-проблема диапазона измерений
0477 Клапан управ.давлен.выхл.газов-низкий уровень входного сигнала
0478 Клапан управ.давлен.выхл.газов-высокий уровень входного сигнала
0479 Клапан управ.давлен.выхл.газов-прерывистый сигнал
0480 Неисправность цепи управления вентилятора охлаждения 1
0481 Неисправность цепи управления вентилятора охлаждения 2
0482 Неисправность цепи управления вентилятора охлаждения 3
0483 Ошибка проверки вентилятора охлаждения
0484 Перегруз.цепи вентилятора охлаж.
0485 Неисправность цепи массы вентилятора охлаждения
0500 Неисправн.датчика скорости атом
0501 Датчик скорости автомобиля-проблема диапазона измерений
0502 Цепь датчика скорости автомобилянизкий уровень входного сигнала
0503 Датчик скорости автомобиля-прерывистост.неопредел.характера
0505 Неисправн.системы управ.хол.хода
0506 Обороты системы холостого хода ниже ожидаемых
0507 Обороты системы холостого хода выше ожидаемых
0510 Неисправность выключателя закрытого положения дросселя
0520 Датчик давления масла двигателя-неисправность цепи
0521 Датчик давления масла двигателя-ошибка диапазона сигнала цепи
0522 Датчик давления масла двигателя-низкий входной сигнал цепи
0523 Датчик давления масла двигателя-высокий входной сигнал цепи
0530 Датчик давления хладагента A/C -неисправность цепи
0531 Датчик давления хладагента A/C -ошибка диапазона сигнала цепи
0532 Датчик давления хладагента A/C -низкий входной сигнал цепи
0533 Датчик давления хладагента A/C -высокий входной сигнал цепи
0534 Потеря зарядки хладагентом системы воздушного кондиционера
0550 Датчик давления усилителя руля -неисправность цепи
0551 Датчик давления усилителя руля -ошибка диапазона сигнала цепи
0552 Датчик давления усилителя руля -низкий входной сигнал цепи
0553 Датчик давления усилителя руля -высокий входной сигнал цепи
0554 Датчик давления усилителя руля -прерывистый входной сигнал цепи
0560 Неисправность напряжения системы
0561 Нестабильное напряжение системы
0562 Очень низкое напряжение системы
0563 Очень высокое напряжение системы
0565 Неисправность сигнала включения круиз-контроля
0566 Неисправность сигнала выключения круиз-контроля
0567 Неисправность повторного сигнала круиз контроля
0568 Неисправность опорного сигнала круиз контроля
0569 Неисправность сигнала инерции круиз контроля
0570 Неисправность сигнала акселерат. круиз контроля
0571 Неисправность цепи тормозного переключателя А круиз-контроля
0572 Низкий сигнал цепи тормозного переключателя А круиз-контроля
0573 Высокий сигнал цепи тормозного переключателя А круиз-контроля
0600 Неисправность последовательной линии связи
0601 Ошибка встроенного модуля проверки контрольной суммы памяти
0602 Ошибка програмирования модуля управления
0603 Ошибка встроенного модуля энергонезависимой памяти (KAM)
0604 Ошибка встроенного модуля оперативной памяти (RAM)
0605 Ошибка встроенного модуля ПЗУ (ROM)
0606 Неисправность процессора ЭБУ PCM
0608 Неисправность выхода модуля управления "А" датчика скорости
0609 Неисправность выхода модуля управления "B" датчика скорости
0620 Неисправность цепи управления генератором
0621 Неисправность цепи управления лампой "L" генератора
0622 Неисправность цепи управления электромагн.полем генератора "F"
0650 Неисправность цепи управления индикаторной лампой (mil)
0654 Неисправность цепи сигнала выходных оборотов двигателя
0655 Неисправность выходной цепи управления лампой перегрева двигат
0656 Неисправность цепи сигнала уровня топлива
0700 Неисправность системы управлениятрансмиссией
0701 Ошибка диапазона работы системы управления трансмиссией
0702 Неравномерная работа системы управления трансмиссией
0703 Неисправность цепи выключателя В муфты гидротрансформатора
0704 Неисправность входной цепи выключателя сцепления
0705 Датчик диапазона трансмиссии -неисправность цепи
0706 Датчик диапазона трансмиссии -ошибка диапазона сигнала цепи
0707 Датчик диапазона трансмиссии -низкий входной сигнал цепи
0708 Датчик диапазона трансмиссии - высокий входной сигнал цепи
0709 Датчик диапазона трансмиссии - прерывистый входной сигнал цепи
0710 Датчик температуры масла КПП - неисправность цепи
0711 Датчик температуры масла КПП - ошибка диапазона сигнала цепи
0712 Датчик температуры масла КПП - низкий входной сигнал цепи
0713 Датчик температуры масла КПП - высокий входной сигнал цепи
0714 Датчик температуры масла КПП - прерывистый входной сигнал цепи
0715 Датчик скорости входной турбины-неисправность цепи
0716 Датчик скорости входной турбины-ошибка диапазона сигнала цепи
0717 Датчик скорости входной турбины-нет сигнала цепи
0718 Датчик скорости входной турбины-прерывистый входной сигнал цепи
0719 Цепь выключателя муфты гидротрансформатора B-низкое напряжение
0720 Датчик выходной скорости -неисправность цепи
0721 Датчик выходной скорости -ошибка диапазона сигнала цепи
0722 Датчик выходной скорости - нет сигнала цепи
0723 Датчик выходной скорости - прерывистый сигнал цепи
0724 Цепь выключателя тормоза преобразов.момента B-высок.напряжение
0725 Неисправность цепи входной скорости двигателя
0726 Ошибка диапазона сигнала цепи входной скорости двигателя
0727 Нет сигнала цепи входной скорости двигателя
0728 Прерывистый сигнал цепи входной скорости двигателя
0730 Некоррект.передат.отношение КПП
0731 КПП-1,некоррект.передат.отношен.
0732 КПП-2,некоррект.передат.отношен.
0733 КПП-3,некоррект.передат.отношен.
0734 КПП-4,некоррект.передат.отношен.
0735 КПП-5,некоррект.передат.отношен.
0736 Некор.перед.отношен.задней скор.
0740 Муфта гидротрансформатора - неисправность цепи
0741 Муфта гидротрансформатора-ошибка диапаз.цепи или закл.шток
0742 Муфта гидротрансформатора - шток выдвинут
0743 Электрическая цепь муфты гидротрансформатора
0744 Прерывистый сигнал цепи муфты гидротрансформатора
0745 Неисправность соленоида управления давлением
0746 Соленоид управления давления-ошибка диапаз.цепи или закл.шток
0747 Соленоид управления давления -шток выдвинут
0748 Соленоид управления давления - неисправность электрической цепи
0749 Соленоид управления давления - прерывистый сигнал цепи
0750 Неисправность соленоида А селек.
0751 Соленоид А селектора - ошибка диапаз.цепи или закл.шток
0752 Шток соленоида В селектора выдв.
0753 Электрич.цепь соленоида А селек.
0754 Прерывист.сигнал соленоид.В сел.
0755 Неисправность соленоида В селек.
0756 Соленоид В селектора - ошибка диапаз.цепи или закл.шток
0757 Шток соленоида В селектора выдв.
0758 Электрич.цепь соленоида В селек.
0759 Прерывист.сигнал соленоид.В сел.
0760 Неисправность соленоида С селек.
0761 Соленоид С селектора - ошибка диапаз.цепи или закл.шток
0762 Шток соленоида С селектора выдв.
0763 Электрич.цепь соленоида С селек.
0764 Прерывист.сигнал соленоид.С сел.
0765 Неисправность соленоида D селек.
0766 Соленоид D селектора - ошибка диапаз.цепи или закл.шток
0767 Шток соленоида D селектора выдв.
0768 Электрич.цепь соленоида D селек.
0769 Прерывист.сигнал соленоид.D сел.
0770 Неисправность соленоида E селек.
0771 Соленоид E селектора - ошибка диапаз.цепи или закл.шток
0772 Шток соленоида E селектора выдв.
0773 Электрич.цепь соленоида E селек.
0774 Прерывист.сигнал соленоид.E сел.
0780 Неисправность селектора
0781 1-2 - неисправность селектора
0782 2-3 - неисправность селектора
0783 3-4 - неисправность селектора
0784 4-5 - неисправность селектора
0785 Неисправность соленоида синхронизации селектора
0786 Соленоид синхронизац.селектора -сигнал за диапазоном измерений
0787 Низк.сигнал солен.синхр.селект.
0788 Высок.сигнал солен.синхр.селект.
0789 Соленоид синхронизац.селектора -прерывистый сигнал
0790 Переключатель нормальной деятел. неисправность цепи
0801 Неисправность схемы запрета задней скорости
0803 Неисправн.цепи управл. Соленоида включен.повышающей передачи 1-4
0804 Неисправн.цепи управления лампой включен.повышающей передачи 1-4
[Архив]
Гость_Катеринка_*
сообщение 1.6.2008, 8:46
http://forum.chrysler-dodge.ru/index.php?showtopic=42234
отличие координально?!
Гость_шахтер_*
сообщение 1.6.2008, 9:40
Ценю информацию в ФАКе и от КРОУ, и от ГОЛЬФа, и от АЛЕКСКОМРАДА.
Но имеющий глаза да увидит!
Я просто привел инфу, которой давно пользуюсь сам. Это 466 кодов ОБД. Не все одинаково полезны, но....
в ФАКе то же в объеме 204. Почувствуйте разницу, Катеринка !! "кООрдинальную"!
Гость_Юрий К._*
сообщение 19.10.2008, 19:46
У меня высветилась ошибка Р0660 - нигде не нашел расшифровки. Так что это может означать?
Гость_Грибы_*
сообщение 19.10.2008, 20:12
на а\м обрыв цепи на соленоиде который разделяет и соединяет две части впускного коллектора
Гость_Юрий К._*
сообщение 19.10.2008, 22:28
Спасибо
Гость_Грибы_*
сообщение 19.10.2008, 22:37
табица с кодами вобщем подходит толька на свежие года есть дополнения
Гость_Юрий К._*
сообщение 19.10.2008, 22:39
Эти дополнения можно где-нибудь увидеть?
Гость_Грибы_*
сообщение 19.10.2008, 22:56
1. эта таблица только для мозгов двигателя, а тормоза, АКПП и тд. /ол. дата- сборники
Serg
сообщение 20.10.2008, 9:45
Администратор
Группа: Админ форума
Из: г.Москва, Тушино
Пользователь №: 5
Прям для твоей машины/года лежат на нашем FTP. Они в составе полного сервисного мануала.
© Serg '2012
Гость_Юрий К._*
сообщение 20.10.2008, 13:02
Правильно ли я понимаю, что это находится по адресу "DISK 1/pub/SOFT/chrysler/Chrysler PAIS/" (4 Гб)?
P. S. Кстати, в файле "все файлы кладем в PUB.txt" написано "Сказано же - в иди в папку DISK 2", которого (DISK 2) вроде как нету совсем...
Serg
сообщение 20.10.2008, 13:21
Администратор
Пользователь №: 5
Совершенно неправильно... Я же написал тебе что все коды в составе "сервисного мануала". Так причём здесь PAIS?
Вот здесь: /pub/chrysler-dodge/manuals/Service%20Manuals/2004_LH_300M_Concorde_Intrepid/
© Serg '2012
Гость_Юрий К._*
сообщение 21.10.2008, 22:57
C этой ссылки 9-ая часть не закачивается - пишет про ошибку, так что пришлось брать её с HTTP.
А есть на клубном FTP что-нибудь не по машинам, а, например, музыка, аудиокниги и т. п.? Я когда-то создал себе вот такое соединение , думая, что это и есть клубный FTP, но, похоже, слегка ошибся.
Если подобного нет, то, может, стОит это сделать -- народ мог бы сам закачивать, обмениваться всякими "глупостями".
Сообщение отредактировал Юрий К. - 21.10.2008, 23:11
Serg
сообщение 22.10.2008, 10:01
Администратор
Пользователь №: 5
1. Скачал безо всяких сложностей. Похоже проблема в твоём клиенте.
2. На том хостинге которым мы пользуемся сейчас - не стОит. Но если ты предложишь свой безразмерный и абсолютно бесплатный хостинг подо всякие наши глупости - мы будем премного благодарны. :-))))
© Serg '2012
Вадим2
сообщение 22.10.2008, 17:48
Из: Москва ЮАО
Пользователь №: 5 913
Реальное имя:Вадим
Цитата(шахтер @ 1.6.2008, 10:47) *
Это 466 кодов ОБД.
Добавлю:
Гость_Юрий К._*
сообщение 22.10.2008, 21:13
Сообщение #16
Увы, но если я, спрашивая "а чё такое хостинг?", выпучу глаза и отвешу челюсть, то это будет не очень уж большим преувеличением morning1.gif rolleyes.gif
Гость_t0lkman_*
сообщение 5.10.2009, 13:23
Сообщение #17
А, я купил вот такую вот штуку:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=320428724039
для своего dodge stratus 98 года, скажите а есть специальный софт для этой модели от chrysler?
а то с этим кабелем идет какой то простой generic софт.
Гость_Alex*K_*
сообщение 5.10.2009, 13:31
Сообщение #18
http://forum.chrysler-dodge.ru/index.php?showtopic=20100
tisa
сообщение 11.10.2009, 17:20
Сообщение #19
Из: эстонния
Пользователь №: 1 389
всем привет лазил сегодня на просторах интернета встретил такой сайт по ошибкам кое что есть новенькое и комуто может помочь с расшифровкой ошибки если полезная информация добавте в ФАК.
УДАЧИ НА ДОРОГАХ..
http://www.pilot-akpp.ru/createstr.php?rid...439&page=22
Сообщение отредактировал tisa - 11.10.2009, 17:22
ycons
сообщение 11.10.2009, 17:30
Сообщение #20
Пользователь №: 8 112
Реальное имя:Юрий
А вот еще есть перечень стандартных кодов OBD II: http://www.e-detector.ru/perfomans/obd/obd_standart.html
Там и Ваш код P0660 есть.
Общая сумма разума на планете – величина постоянная. А население растет...
2 страниц V   1 2 >
RSS Текстовая версия Сейчас: 24.9.2026, 13:57Дизайн IPB
