gofar
сообщение 2.6.2015, 13:39
Из: новочебоксарск
Пользователь №: 76 423
Реальное имя:ромыч
Приветствую однополчане.Кто в курсе что за байда эта такая tow/haul в режиме работы АКПП? Мож кто в английском упражнялся в школе?
Сообщение отредактировал gofar - 2.6.2015, 13:41
durango 5.7 07года
Diman
сообщение 2.6.2015, 13:57
Пользователь №: 8 687
Реальное имя: № 8 687
When To Use “TOW/HAUL” Mode
When driving in hilly areas, towing a trailer, carrying a
heavy load, etc., and frequent transmission shifting occurs,
press the “TOW/HAUL” button. This will improve
performance and reduce the potential for transmission
overheating or failure due to excessive shifting. When
operating in “TOW/HAUL” mode, 5th gear (if
equipped) is disabled and 2-3 and 3-4 shift patterns are
modified. Shifts into Overdrive (4th gear) are allowed
during steady cruise (for improved fuel economy) and
automatic closed-throttle downshifts to 3rd gear (for
improved braking) will occur during steady braking.
The “TOW/HAUL” light will illuminate in the instrument
cluster to indicate when the switch has been
activated. Pressing the switch a second time restores
normal operation. If the “TOW/HAUL” mode is desired,
the button must be pressed each time the engine is
started.
Torque Converter Clutch
A feature designed to improve fuel economy is included
in all automatic transmissions. Aclutch within the torque
converter engages automatically at a calibrated speed at
light throttle. It engages at higher speeds under heavier
acceleration. This may result in a slightly different feeling
or response during normal operation in high gear. When
the vehicle speed drops below a calibrated speed, or
during acceleration, the clutch automatically and
smoothly disengages. The feature is operational in Overdrive
and in Drive.
NOTE: The torque converter clutch will not engage
until the transmission fluid and engine coolant are warm
[usually after 1-3 miles (1.6 - 4.8 km) of driving]. Because
the engine speed is higher when the torque converter
clutch is not engaged, it may seem as if the transmission
is not shifting into Overdrive when cold. This is normal.
Pressing the9TOW/HAUL9 button, when the transmission
is sufficiently warm, will demonstrate that the
transmission is able to shift into and out of Overdrive.
NOTE: If the vehicle has not been driven in several
days, the first few seconds of operation after shifting the
transmission into gear may seem sluggish. This is due to
the fluid partially draining from the torque converter into
the transmission. This condition is normal and will not
cause damage to the transmission. The torque converter
will refill within five seconds of shifting from Park into
any other gear position.
http://lmgtfy.com/?q=%D0%9F%D0%B5%D1%80%D0...8%D0%BA+Google+
'03 DN SLT+ AWD
Buy The Right Part!
IgorN
сообщение 2.6.2015, 13:58
Из: Екатеринбург
Пользователь №: 20 193
Буксировка прицепа, в общем.
1997 Plymouth Voyager 3.3 (продан), 2001 Chrysler 300M 3.5 (продан), 2011 Jeep Grand Cherokee Limited 3.6 (продан), 2011 Dodge Challenger R/T (5.7)(продан), 2015 Jeep Grand Cherokee Limited 3.0 бензин(продан)
2019 Audi A5 Coupe 2.0 diesel stage 1
2023 Exeed 2.0 gasoline
Diman
сообщение 2.6.2015, 14:04
Ok, Google!...
'03 DN SLT+ AWD
Buy The Right Part!
gofar
сообщение 3.6.2015, 11:55
Из: новочебоксарск
Реальное имя:ромыч
Ok, Google!...
суть моего конспекта включается этот режим на прогретой коробке(на холодной нее работает),включаем если нужно тянуть,тащить,волочить.,так же на затяжных подьемах,спусках(торможение двиг-ем),5 передача отключается., изменяется режим работы сцепления.Все правильно?в грязи при засаживании авто нужно активировать этот режим?
durango 5.7 07года
Diman
сообщение 3.6.2015, 13:54
Цитата(gofar @ 3.6.2015, 11:55) *
изменяется режим работы сцепления...
Все правильно?...
если в двух словах, то да...
в грязи при засаживании авто нужно активировать этот режим?...
при засаживании нужно активировать режим поиска ближайщего трактора. Нет, не нужно...
'03 DN SLT+ AWD
Buy The Right Part!
gofar
сообщение 3.6.2015, 16:51
Из: новочебоксарск
Реальное имя:ромыч
durango 5.7 07года
Diman
сообщение 3.6.2015, 17:01
'03 DN SLT+ AWD
Buy The Right Part!
лысый джо
сообщение 4.6.2015, 10:21
Из: москва солнцево
Пользователь №: 40 542
Реальное имя:Евгений
я заметил, в этом режиме авто как в спорт режиме едет акпп. Передачи позже включаются повышенные. И мотор на более высоких оборотах работает.
DODGE DURANGO 5.7 HEMI 2005
1D8HB58D95F572482
RSS Текстовая версия Сейчас: 9.10.2025, 8:19Дизайн IPB
