8.5.2013, 21:54
AMPLIFIER (AMP)
B1460-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE B1461-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT LOW B1462-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT HIGH B1463-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT OPEN B1464-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER B1465-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE B1466-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT LOW B1467-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT HIGH B1468-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT OPEN B1469-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER B146A-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE B146B-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT LOW B146C-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT HIGH B146D-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT OPEN B146E-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER B146F-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE B1470-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT LOW B1471-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT HIGH B1472-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT OPEN B1473-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER B1474-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE B1475-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT LOW B1476-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT HIGH B1477-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT OPEN B1478-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER B1479-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE B147A-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT LOW B147B-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT HIGH B147C-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT OPEN B147D-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER B147E-CHANNEL 7 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE B147F-CHANNEL 7 AUDIO SPEAKER OUTPUT CIRCUIT LOW B1480-CHANNEL 7 AUDIO SPEAKER OUTPUT CIRCUIT HIGH B1481-CHANNEL 7 AUDIO SPEAKER OUTPUT CIRCUIT OPEN B1482-CHANNEL 7 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER B1483-CHANNEL 8 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE B1484-CHANNEL 8 AUDIO SPEAKER OUTPUT CIRCUIT LOW B1485-CHANNEL 8 AUDIO SPEAKER OUTPUT CIRCUIT HIGH B1486-CHANNEL 8 AUDIO SPEAKER OUTPUT CIRCUIT OPEN B1487-CHANNEL 8 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER B1488-CABIN EQ MISMATCH PERFORMANCE B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B221F-AMPLIFIER INTERNAL U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0184-LOST COMMUNICATION WITH RADIO CONTROLLER, Occupant Restraint (ORC) B1B00-DRIVER AIRBAG SQUIB 1 CIRCUIT LOW B1B01-DRIVER AIRBAG SQUIB 1 CIRCUIT HIGH B1B02-DRIVER AIRBAG SQUIB 1 CIRCUIT OPEN B1B03-DRIVER AIRBAG SQUIB 1 CIRCUIT SHORTED TOGETHER B1B04-DRIVER AIRBAG SQUIB 2 CIRCUIT LOW B1B05-DRIVER AIRBAG SQUIB 2 CIRCUIT HIGH B1B06-DRIVER AIRBAG SQUIB 2 CIRCUIT OPEN B1B07-DRIVER AIRBAG SQUIB 2 CIRCUIT SHORTED TOGETHER B1B08-PASSENGER AIRBAG SQUIB 1 CIRCUIT LOW B1B09-PASSENGER AIRBAG SQUIB 1 CIRCUIT HIGH B1B0A-PASSENGER AIRBAG SQUIB 1 CIRCUIT OPEN B1B0B-PASSENGER AIRBAG SQUIB 1 CIRCUIT SHORTED TOGETHER B1B0C-PASSENGER AIRBAG SQUIB 2 CIRCUIT LOW B1B0D-PASSENGER AIRBAG SQUIB 2 CIRCUIT HIGH B1B0E-PASSENGER AIRBAG SQUIB 2 CIRCUIT OPEN B1B0F-PASSENGER AIRBAG SQUIB 2 CIRCUIT SHORTED TOGETHER B1B18-LEFT SIDE CURTAIN SQUIB 1 CIRCUIT LOW B1B19-LEFT SIDE CURTAIN SQUIB 1 CIRCUIT HIGH B1B1A-LEFT SIDE CURTAIN SQUIB 1 CIRCUIT OPEN B1B1B-LEFT SIDE CURTAIN SQUIB 1 CIRCUIT SHORTED TOGETHER B1B20-RIGHT SIDE CURTAIN SQUIB 1 CIRCUIT LOW B1B21-RIGHT SIDE CURTAIN SQUIB 1 CIRCUIT HIGH B1B22-RIGHT SIDE CURTAIN SQUIB 1 CIRCUIT OPEN B1B23-RIGHT SIDE CURTAIN SQUIB 1 CIRCUIT SHORTED TOGETHER B1B70-UP-FRONT LEFT SATELLITE ACCELERATION SENSOR INTERNAL B1B71-UP-FRONT RIGHT SATELLITE ACCELERATION SENSOR INTERNAL B1B72-LEFT SIDE SATELLITE ACCELERATION SENSOR 1 INTERNAL B1B73-LEFT SIDE SATELLITE ACCELERATION SENSOR 2 INTERNAL B1B75-RIGHT SIDE SATELLITE ACCELERATION SENSOR 1 INTERNAL B1B76-RIGHT SIDE SATELLITE ACCELERATION SENSOR 2 INTERNAL B1B8D-DRIVER SEAT TRACK POSITION SENSOR CIRCUIT LOW B1B8E-DRIVER SEAT TRACK POSITION SENSOR CIRCUIT HIGH B1B8F-DRIVER SEAT TRACK POSITION SENSOR CIRCUIT OPEN B1B90-DRIVER SEAT TRACK POSITION SENSOR CIRCUIT SHORTED TOGETHER B1B91-DRIVER SEAT TRACK POSITION SENSOR CONFIGURATION MISMATCH B1BA5-AIRBAG SQUIB CONFIGURATION MISMATCH B1BC7-DEPLOYMENT DATA RECORD FULL B1C27-LEFT SIDE SEAT THORAX SQUIB 1 LOW B1C28-LEFT SIDE SEAT THORAX SQUIB 1 HIGH B1C29-LEFT SIDE SEAT THORAX SQUIB 1 OPEN B1C2A-LEFT SIDE SEAT THORAX SQUIB 1 SHORTED TOGETHER B1C2B-RIGHT SIDE SEAT THORAX SQUIB 1 LOW B1C2C-RIGHT SIDE SEAT THORAX SQUIB 1 HIGH B1C2D-RIGHT SIDE SEAT THORAX SQUIB 1 OPEN B1C2E-RIGHT SIDE SEAT THORAX SQUIB 1 SHORTED TOGETHER B1C38-1st ROW DRIVER RETRACTOR TENSIONER CIRCUIT LOW B1C39-1ST ROW DRIVER RETRACTOR TENSIONER CIRCUIT HIGH B1C3A-1st ROW DRIVER RETRACTOR TENSIONER CIRCUIT OPEN B1C3B-1st ROW DRIVER RETRACTOR TENSIONER CIRCUIT SHORTED TOGETHER B1C3D-1st ROW DRIVER SEAT BELT BUCKLE TENSIONER CIRCUIT LOW B1C3E-1st ROW DRIVER SEAT BELT BUCKLE TENSIONER CIRCUIT HIGH B1C3F-1st ROW DRIVER SEAT BELT BUCKLE TENSIONER CIRCUIT OPEN B1C40-1st ROW DRIVER SEAT BELT BUCKLE TENSIONER CIRCUIT SHORTED TOGETHER B1C47-1st ROW PASSENGER RETRACTOR TENSIONER CIRCUIT LOW B1C48-1ST ROW PASSENGER RETRACTOR TENSIONER CIRCUIT HIGH B1C49-1st ROW PASSENGER RETRACTOR TENSIONER CIRCUIT OPEN B1C4A-1st ROW PASSENGER RETRACTOR TENSIONER CIRCUIT SHORTED TOGETHER B1C4F-1st ROW PASSENGER SEAT BELT BUCKLE TENSIONER CIRCUIT SHORTED TOGETHER B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B212C-IGNITION RUN/START INPUT CIRCUIT OPEN B212D-IGNITION RUN ONLY INPUT CIRCUIT OPEN B2207-OCCUPANT RESTRAINT CONTROLLER INTERNAL 1 B2208-OCCUPANT RESTRAINT CONTROLLER INTERNAL 2 B220B-OCCUPANT RESTRAINT CONTROLLER FIRING STORED ENERGY B223B-VEHICLE CONFIGURATION MISMATCH B2255-OCCUPANT RESTRAINT CONTROLLER ROLL OVER FEATURE DISABLE B222A-VEHICLE LINE MISMATCH U0002-CAN C BUS OFF PERFORMANCE U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0170-LOST COMMUNICATION W/UP-FRONT LEFT SATELLITE ACCELERATION SENSOR U0171-LOST COMMUNICATION W/UP-FRONT RIGHT SATELLITE ACCELERATION SENSOR U0172-LOST COMMUNICATION W/LEFT SIDE SATELLITE ACCELERATION SENSOR 1 U0173-LOST COMMUNICATION W/LEFT SIDE SATELLITE ACCELERATION SENSOR 2 U0175-LOST COMMUNICATION W/RIGHT SIDE SATELLITE ACCELERATION SENSOR 1 U0176-LOST COMMUNICATION W/RIGHT SIDE SATELLITE ACCELERATION SENSOR 2 U1414-IMPLAUSIBLE/MISSING ECU CONFIGURATION DATA U1415-IMPLAUSIBLE/MISSING VEHICLE CONFIGURATION DATA HVAC, ATC B1001-A/C SWITCH REQUEST INPUT CIRCUIT LOW B100A-RECIRCULATION SWITCH REQUEST INPUT CIRCUIT LOW B1016-REAR DEFROST SWITCH REQUEST INPUT CIRCUIT LOW B1031-EVAPORATOR FIN TEMPERATURE SENSOR CIRCUIT LOW B1032-EVAPORATOR FIN TEMPERATURE SENSOR CIRCUIT HIGH B1034-INFRARED TEMPERATURE SENSOR INPUT CIRCUIT LOW B1035-INFRARED TEMPERATURE SENSOR INPUT CIRCUIT HIGH B1040-PANEL MODE DOOR 1 CONTROL CIRCUIT/PERFORMANCE B1043-PANEL MODE DOOR 1 CONTROL CIRCUIT OPEN B1044-PANEL MODE DOOR 1 TRAVEL RANGE TOO SMALL B1045-PANEL MODE DOOR 1 TRAVEL RANGE TOO LARGE B1058-RECIRCULATION DOOR CONTROL CIRCUIT/PERFORMANCE B105B-RECIRCULATION DOOR CONTROL CIRCUIT OPEN B105C-RECIRCULATION DOOR TRAVEL RANGE TOO SMALL B105D-RECIRCULATION DOOR TRAVEL RANGE TOO LARGE B106B-REAR DEFROST CONTROL CIRCUIT LOW B106C-REAR DEFROST CONTROL CIRCUIT HIGH B1082-HVAC MUX CIRCUIT LOW B1083-HVAC MUX CIRCUIT HIGH B10A2-LEFT BLEND DOOR CONTROL CIRCUIT/PERFORMANCE B10A5-LEFT BLEND DOOR CONTROL CIRCUIT OPEN B10A6-LEFT BLEND DOOR TRAVEL TOO SMALL B10A7-LEFT BLEND DOOR TRAVEL TOO LARGE B10A8-LEFT BLEND DOOR ACTUATOR PERFORMANCE B10A9-RIGHT BLEND DOOR CONTROL CIRCUIT/PERFORMANCE B10AC-RIGHT BLEND DOOR CONTROL CIRCUIT OPEN B10AD-RIGHT BLEND DOOR TRAVEL TOO SMALL B10AE-RIGHT BLEND DOOR TRAVEL TOO LARGE B10AF-RIGHT BLEND DOOR ACTUATOR PERFORMANCE B10B2-A/C COOL DOWN TEST PERFORMANCE B1601-LEFT SOLAR SENSOR CIRCUIT LOW B1602-LEFT SOLAR SENSOR CIRCUIT HIGH B1604-RIGHT SOLAR SENSOR CIRCUIT LOW B1605-RIGHT SOLAR SENSOR CIRCUIT HIGH B1610-AMBIENT LIGHT SENSOR INPUT CIRCUIT LOW B1611-AMBIENT LIGHT SENSOR INPUT CIRCUIT HIGH U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0151-LOST COMMUNICATION WITH OCCUPANT RESTRAINT CONTROLLER (ORC) U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0156-LOST COMMUNICATION WITH EOM U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN) U0184-LOST COMMUNICATION WITH RADIO U0186-LOST COMMUNICATION WITH AUDIO AMPLIFIER U0195-LOST COMMUNICATION WITH SDARS U0196-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE U0197-LOST COMMUNICATION WITH HANDS FREE PHONE MODULE U0199-LOST COMMUNICATION WITH DRIVER DOOR MODULE U0200-LOST COMMUNICATION WITH PASSENGER DOOR MODULE U0208-LOST COMMUNICATION WITH HEATED SEAT CONTROL MODULE U0209-LOST COMMUNICATION WITH MEMORY SEAT CONTROL MODULE HVAC SYSTEM TEST (ATC) HVAC, MTC 11-MODE POT OPEN 12-MODE POT SHORTED 13-TEMP POT OPEN 14-TEMP POT SHORTED 18-BLEND DOOR RANGE TOO SMALL 21-BLEND DOOR RANGE TOO LARGE 22-FRONT MODE DOOR RANGE TOO SMALL 23-FRONT MODE DOOR RANGE TOO LARGE 31-EVAPORATOR SENSOR OPEN 32-EVAPORATOR SENSOR SHORTED 33-A/C MODE SWITCH STUCK 34-EBL MODE SWITCH STUCK 35-FAILED COOL DOWN 36-EEPROM CHECKSUM ERROR 37-ROM CHECKSUM ERROR 41-FRONT MODE OVERCURRENT 43-BLEND OVERCURRENT 44-RECIRC OVERCURRENT 45-BLEND DOOR BOUND 46-FRONT MODE DOOR BOUND 47-RECIRC DOOR BOUND 51-RECIRC DOOR RANGE TOO SMALL 52-RECIRC DOOR RANGE TOO LARGE 53-FRONT MODE DOOR LINKAGE BROKEN 55-BLEND DOOR LINKAGE BROKEN 56-RECIRC DOOR LINKAGE BROKEN 61-COMMON DOOR DRIVER CIRCUIT SHORTED TO GROUND 62-COMMON DOOR DRIVER CIRCUIT SHORTED TO IGNITION 63-FRONT MODE DOOR DRIVER CIRCUIT SHORTED TO GROUND 64-FRONT MODE DOOR DRIVER CIRCUIT SHORTED TO IGNITION 67-BLEND DOOR DRIVER CIRCUIT SHORTED TO GROUND 68-BLEND DOOR DRIVER CIRCUIT SHORTED TO IGNITION 69-RECIRC DOOR DRIVER CIRCUIT SHORTED TO GROUND 71-RECIRC DOOR DRIVER CIRCUIT SHORTED TO IGNITION 72-SHORT TOO COMPLEX 73-AC REQUEST OUTPUT SIGNAL TOO HIGH 74-AC REQUEST OUTPUT SIGNAL TOO LOW 75-AC REQUEST OUTPUT SIGNAL HIGH WHEN DRIVEN LOW 76-AC REQUEST OUTPUT SIGNAL LOW WHEN DRIVEN HIGH 77-EBL OUTPUT SHORTED HIGH 81-BLOWER NOT ON HIGH AT START OF COOLDOWN TEST 82-SENSOR TOO COLD TO START COOLDOWN TEST 83-SENSOR FAILED OPEN DURING COOLDOWN TEST 84-SENSOR FAILED SHORTED DURING COOLDOWN TEST 85-BLOWER NOT ON HIGH DURING COOLDOWN TEST MODULE, Adaptive Cruise Control (ACC) C124B-XBW RULE VIOLATION C124C-ACC DISABLED DUE TO ESP C2206-VEHICLE CONFIGURATION MISMATCH C2315-ACC DISABLE DUE TO PCM FAULT P0562-BATTERY VOLTAGE LOW P0563-BATTERY VOLTAGE HIGH P1519-CRUISE CONTROL FRONT DISTANCE SENSOR LENS CRACKED MISSING P160A-ECU OVERTEMPERATURE P1614-ECU RESET/RECOVERY OCCURRED P161A-ECU IN-PLANT MODE ACTIVE P1644-INCORRECT VARIANT/CONFIGURATION P1666-CRUISE CONTROL MODULE INTERNAL P1678-ECU SENSOR ADJUSTMENT REQUIRED U0002-CAN C BUS OFF PERFORMANCE U0100-LOST COMMUNICATION WITH ECM/PCM U0101-LOST COMMUNICATION WITH TCM U110A-LOST COMMUNICATION WITH SCCM - CAN - C U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE U0401-IMPLAUSIBLE DATA RECEIVED FROM ECM/PCM U0402-IMPLAUSIBLE DATA RECEIVED FROM TCM U0415-IMPLAUSIBLE DATA RECEIVED FROM ABS U0429-IMPLAUSIBLE DATA RECEIVED FROM SCM U0431-IMPLAUSIBLE DATA RECEIVED FROM FCM MODULE, Antilock Brake (ABS) C100A-LEFT FRONT WHEEL SPEED SENSOR CIRCUIT C1011-LEFT FRONT WHEEL SPEED SENSOR SIGNAL ERRATIC PERFORMANCE C1014-LEFT FRONT WHEEL SPEED COMPARATIVE PERFORMANCE C1015-RIGHT FRONT WHEEL SPEED SENSOR CIRCUIT C101C-RIGHT FRONT WHEEL SPEED SENSOR SIGNAL ERRATIC PERFORMANCE C101F-RIGHT FRONT WHEEL SPEED COMPARATIVE PERFORMANCE C1020-LEFT REAR WHEEL SPEED SENSOR CIRCUIT C1027-LEFT REAR WHEEL SPEED SENSOR SIGNAL ERRATIC PERFORMANCE C102A-LEFT REAR WHEEL SPEED COMPARATIVE PERFORMANCE C102B-RIGHT REAR WHEEL SPEED SENSOR CIRCUIT C1032-RIGHT REAR WHEEL SPEED SENSOR SIGNAL ERRATIC PERFORMANCE C1035-RIGHT REAR WHEEL SPEED COMPARATIVE PERFORMANCE C1041-LEFT FRONT TONE WHEEL PERFORMANCE C1042-RIGHT FRONT TONE WHEEL PERFORMANCE C1043-LEFT REAR TONE WHEEL PERFORMANCE C1044-RIGHT REAR TONE WHEEL PERFORMANCE C1046-LEFT FRONT WHEEL PRESSURE PHASE MONITORING C1047-RIGHT FRONT WHEEL PRESSURE PHASE MONITORING C1048-LEFT REAR WHEEL PRESSURE PHASE MONITORING C1049-RIGHT REAR WHEEL PRESSURE PHASE MONITORING C1073-ABS PUMP MOTOR CONTROL CIRCUIT C1078-TIRE REVOLUTIONS RANGE PERFORMANCE C107C-BRAKE PEDAL SWITCH 1/2 STUCK-GAS C107D-BRAKE PEDAL SWITCH 1/2 CORRELATION-GAS C1090-ABS BRAKE LAMP CONTROL CIRCUIT LOW C1091-ABS BRAKE LAMP CONTROL CIRCUIT HIGH C1210-G SENSOR INPUT CIRCUIT PERFORMANCE C1219-STEERING ANGLE SENSOR ERRATIC PERFORMANCE C121A-STEERING ANGLE SENSOR NOT INITIALIZED C121C-TORQUE REQUEST SIGNAL DENIED C121D-BRAKE PRESSURE SENSOR CIRCUIT C121E-BRAKE PRESSURE SENSOR COMPARATIVE PERFORMANCE C1231-DRIVE TEST:STEERING ANGLE SENSOR C1232-DRIVE TEST: PRESSURE SENSOR C1234-DRIVE TEST: SENSOR CLUSTER INSTALLATION C1238-DRIVE TEST: UNSUCCESSFUL C1239-EMISSIONS ROLLS TEST ACTIVE C123A-ESP SYSTEM SENSORS CALIBRATION C123B-ESP SYSTEM CONTROL TOO LONG C123C-DYNAMICS SENSOR MOUNTING/INSTALLATION PERFORMANCE C123F-STEERING ANGLE SENSOR COMPARATIVE PERFORMANCE C1240-STEERING ANGLE SENSOR OVERTRAVEL PERFORMANCE C1242-G SENSOR INPUT SIGNAL PERFORMANCE C1243-G SENSOR NOT INITIALIZED C2100-BATTERY VOLTAGE LOW C2101-BATTERY VOLTAGE HIGH C2114-DYNAMICS SENSOR SUPPLY VOLTAGE LOW C2115-DYNAMICS SENSOR SUPPLY VOLTAGE HIGH C2116-ABS PUMP MOTOR SUPPLY LOW VOLTAGE C2200-ANTI-LOCK BRAKE MODULE INTERNAL C2202-ORIGINAL VIN MISMATCH/MISSING C2204-DYNAMICS SENSOR INTERNAL C2205-STEERING ANGLE SENSOR INTERNAL C2206-VEHICLE CONFIGURATION MISMATCH U0002-CAN C BUS OFF PERFORMANCE U0100-LOST COMMUNICATION WITH THE ECM/PCM U0101-LOST COMMUNICATION WITH TCM U0125-LOST COMMUNICATION WITH DYNAMICS SENSOR U0126-LOST COMMUNICATION WITH STEERING ANGLE SENSOR U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0146-LOST COMMUNICATION WITH CENTRAL GATEWAY U0401-IMPLAUSIBLE DATA RECEIVED FROM ECM/PCM U0429-IMPLAUSIBLE DATA RECEIVED FROM SCM U1003-ESP CAN C BUS PERFORMANCE U1104-CAN C BUS CRC PERFORMANCE U140E-IMPLAUSIBLE VEHICLE CONFIGURATION DATA RECEIVED U1501-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM ECM/PCM U1502-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM TCM U1503-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM TIPM MODULE, Auto Highbeam (AHBM) B16A7-HIGH BEAM CAMERA ALIGNMENT PERFORMANCE - LEFT B16A8-HIGH BEAM CAMERA ALIGNMENT PERFORMANCE - RIGHT B16A9-HIGH BEAM CAMERA ALIGNMENT PERFORMANCE - TOP B16AA-HIGH BEAM CAMERA ALIGNMENT PERFORMANCE - BOTTOM B210A-SYSTEM VOLTAGE LOW B210B-SYSTEM VOLTAGE HIGH B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B223A-AUTO HIGH BEAM ECU INTERNAL U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0155-LOST COMMUNICATION WITH CLUSTER/CCN MODULE, Driver Door (DDM) B16A0-DRIVER WINDOW SWITCH BACKLIGHTING CIRCUIT LOW B16A1-DRIVER WINDOW SWITCH BACKLIGHTING CIRCUIT HIGH B1852-DRIVER WINDOW SWITCH CIRCUIT STUCK B1854-DRIVER WINDOW MOTOR CONTROL CIRCUIT LOW B1855-DRIVER WINDOW MOTOR CONTROL CIRCUIT HIGH B1858-DRIVER WINDOW POSITION SENSOR POWER SUPPLY LOW B1859-DRIVER WINDOW POSITION SENSOR POWER SUPPLY HIGH B185A-DRIVER WINDOW POSITION SENSOR CIRCUIT PERFORMANCE B1868-DRIVER PASSENGER WINDOW SWITCH CIRCUIT STUCK B1D04-MIRROR ADJUST SWITCH INPUT CIRCUIT/PERFORMANCE B1D07-MIRROR ADJUST SWITCH INPUT CIRCUIT STUCK B1D09-DRIVER MIRROR POSITION SENSOR POWER SUPPLY CIRCUIT LOW B1D0A-DRIVER MIRROR POSITION SENSOR POWER SUPPLY CIRCUIT HIGH B1D0C-DRIVER MIRROR VERTICAL POSITION SENSOR INPUT CIRCUIT LOW B1D0D-DRIVER MIRROR VERTICAL POSITION SENSOR INPUT CIRCUIT HIGH B1D0F-DRIVER MIRROR HORIZONTAL POSITION SENSOR INPUT CIRCUIT LOW B1D10-DRIVER MIRROR HORIZONTAL POSITION SENSOR INPUT CIRCUIT HIGH B1D1E-DRIVER MIRROR VERTICAL MOTOR CONTROL CIRCUIT/PERFORMANCE B1D22-DRIVER MIRROR HORIZONTAL MOTOR CONTROL CIRCUIT/PERFORMANCE B1D4D-MEMORY SWITCH INPUT CIRCUIT STUCK B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B2218-DOOR MODULE INTERNAL B2578-DRIVER WINDOW NOT CALIBRATED/LOST CALIBRATION B2580-DRIVER WINDOW POSITION SENSOR(S) NO SIGNAL U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0151-LOST COMMUNICATION WITH OCCUPANT RESTRAINT CONTROLLER (ORC) U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0156-LOST COMMUNICATION WITH EOM U0159-LOST COMMUNICATION WITH PARKING ASSIST CONTROL MODULE U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE U0167-LOST COMMUNICATION WITH INTRUSION TRANSCEIVER CONTROL MODULE U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN) U0169-LOST COMMUNICATION WITH SUNROOF CONTROL MODULE U0181-LOST COMMUNICATION WITH HEADLAMP LEVELING TRANSLATOR U0184-LOST COMMUNICATION WITH RADIO U0186-LOST COMMUNICATION WITH AUDIO AMPLIFIER U0195-LOST COMMUNICATION WITH SDARS U0196-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE U0197-LOST COMMUNICATION WITH HANDS FREE PHONE MODULE U0200-LOST COMMUNICATION WITH PASSENGER DOOR MODULE U0208-LOST COMMUNICATION WITH HEATED SEAT CONTROL MODULE U0209-LOST COMMUNICATION WITH MEMORY SEAT CONTROL MODULE U0212-LOST COMMUNICATION WITH SCM - CAN-B U0231-LOST COMMUNICATION WITH LIGHT RAIN SENSING MODULE U0241-LOST COMMUNICATION WITH AUTO HIGHBEAM HEADLIGHT CONTROL MODULE MODULE, Drivetrain Control (DTCM) C1078-TIRE REVOLUTIONS RANGE PERFORMANCE C1456-AWD CLUTCH POWER CONTROL CIRCUIT LOW C1457-AWD CLUTCH POWER CONTROL CIRCUIT HIGH C145D-AWD CLUTCH POWER/RETURN CONTROL CIRCUIT OPEN C1464-FRONT AXLE DISCONNECT CONTROL CIRCUIT LOW C1465-FRONT AXLE DISCONNECT CONTROL CIRCUIT HIGH C1477-TRANSFER CASE CLUTCH OVER TEMPERATURE C147A-TRANSFER CASE TEMPERATURE SENSOR HIGH C147B-FRONT AXLE DISCONNECT SENSOR CIRCUIT PERFORMANCE C147C-FRONT AXLE DISCONNECT POWER CIRCUIT LOW C147D-FRONT AXLE DISCONNECT POWER SUPPLY CIRCUIT HIGH C2100-BATTERY VOLTAGE LOW C2101-BATTERY VOLTAGE HIGH C2112-SENSOR SUPPLY 1 VOLTAGE CIRCUIT HIGH C2201-INTERNAL CONTROLLER U0001-CAN C BUS U0100-LOST COMMUNICATION WITH THE ECM/PCM U0101-LOST COMMUNICATION WITH TCM U0121-LOST COMMUNICATION WITH ABS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0212-LOST COMMUNICATION WITH SCM U0401-IMPLAUSIBLE DATA RECEIVED FROM ECM/PCM U0402-IMPLAUSIBLE DATA RECEIVED FROM TCM U0415-IMPLAUSIBLE DATA RECEIVED FROM ABS U0429-IMPLAUSIBLE DATA RECEIVED FROM SCM U0431-IMPLAUSIBLE DATA RECEIVED FROM FCM/TIPM MODULE, Electronic Overhead (EOM) B1A32-UNIVERSAL GARAGE DOOR SWITCH 1 STUCK B1A33-UNIVERSAL GARAGE DOOR SWITCH 2 STUCK B1A34-UNIVERSAL GARAGE DOOR SWITCH 3 STUCK B2217 - EVIC/EOM/CMTC INTERNAL B222D - ECU UNABLE TO CONFIGURE / CONFIGURATION NOT LEARNED B2331-VEHICLE NEEDS DEGAUSSED U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0151-LOST COMMUNICATION WITH OCCUPANT RESTRAINT CONTROLLER (ORC) U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0159-LOST COMMUNICATION WITH PARKING ASSIST CONTROL MODULE U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE U0167-LOST COMMUNICATION WITH INTRUSION TRANSCEIVER CONTROL MODULE U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN) U0169-LOST COMMUNICATION WITH SUNROOF CONTROL MODULE U0184-LOST COMMUNICATION WITH RADIO U0186-LOST COMMUNICATION WITH AUDIO AMPLIFIER U0195-LOST COMMUNICATION WITH SDARS U0196-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE U0197-LOST COMMUNICATION WITH HANDS FREE PHONE MODULE U0199-LOST COMMUNICATION WITH DRIVER DOOR MODULE U0200-LOST COMMUNICATION WITH PASSENGER DOOR MODULE U0208-LOST COMMUNICATION WITH HEATED SEAT CONTROL MODULE U0209-LOST COMMUNICATION WITH MEMORY SEAT CONTROL MODULE U0212-LOST COMMUNICATION WITH SCM - CAN-B U0231-LOST COMMUNICATION WITH LIGHT RAIN SENSING MODULE U0231-LOST COMMUNICATION WITH LIGHT RAIN SENSING MODULE U0241-LOST COMMUNICATION WITH AUTO HIGHBEAM HEADLIGHT CONTROL MODULE MODULE, Electronic Shift (ESM) P0562-BATTERY VOLTAGE LOW - ESM P0562-BATTERY VOLTAGE LOW - ESM (COLUMN) P0563-BATTERY VOLTAGE HIGH - ESM P0563-BATTERY VOLTAGE HIGH - ESM (COLUMN SHIFT) P0607-ECU INTERNAL PERFORMANCE - ESM P0607-ECU INTERNAL PERFORMANCE - ESM (COLUMN SHIFT) P0930-BTSI CONTROL CIRCUIT LOW P0930-BTSI CONTROL CIRCUIT LOW - COLUMN SHIFT P0931-BTSI CONTROL CIRCUIT HIGH P0931-BTSI CONTROL CIRCUIT HIGH - COLUMN SHIFT P2775-AUTOSTICK UPSHIFT SWITCH CIRCUIT PERFORMANCE P2775-AUTOSTICK UPSHIFT SWITCH CIRCUIT PERFORMANCE (COLUMN SHIFT) P2779-AUTOSTICK DOWNSHIFT SWITCH CIRCUIT PERFORMANCE P2779-AUTOSTICK DOWNSHIFT SWITCH CIRCUIT PERFORMANCE (COLUMN SHIFT) U0002-CAN C BUS OFF PERFORMANCE - ESM U0002-CAN C BUS OFF PERFORMANCE - ESM (COLUMN SHIFT) U0100-LOST COMMUNICATION WITH ECM/PCM - ESM U0100-LOST COMMUNICATION WITH ECM/PCM - ESM (COLUMN SHIFT) U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE - ESM U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE - ESM (COLUMN SHIFT) U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE - ESM U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE - ESM (COLUMN SHIFT) MODULE, Hands Free (HFM) B143B-MICROPHONE 1 CIRCUIT LOW B143C-MICROPHONE 1 CIRCUIT HIGH B143E-MICROPHONE 2 CIRCUIT LOW B143F-MICROPHONE 2 CIRCUIT HIGH B2205-ORIGINAL VIN MISSING/MISMATCH U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0184-LOST COMMUNICATION WITH RADIO MODULE, Heated Seat (HSM) B1092-FRONT LEFT SEAT HEATER CONTROL CIRCUIT LOW B1094-FRONT LEFT SEAT HEATER CONTROL CIRCUIT OPEN B1096-FRONT RIGHT SEAT HEATER CONTROL CIRCUIT LOW B1098-FRONT RIGHT SEAT HEATER CONTROL CIRCUIT OPEN B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B221A-HEATED SEAT MODULE INTERNAL U0019-CAN B BUS U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE U0151-LOST COMMUNICATION WITH OCCUPANT RESTRAINT CONTROLLER U0154-LOST COMMUNICATION WITH OCCUPANT CLASSIFICATION MODULE U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0156-LOST COMMUNICATION WITH EOM U0159-LOST COMMUNICATION WITH PARKING ASSIST CONTROL MODULE U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIRELESS IGNITION NODE OR WIN) U0169-LOST COMMUNICATION WITH SUNROOF CONTROL MODULE U0181-LOST COMMUNICATION WITH HEADLAMP LEVELING TRANSLATOR U0184-LOST COMMUNICATION WITH RADIO U0186-LOST COMMUNICATION WITH AUDIO AMPLIFIER U0197-LOST COMMUNICATION WITH HFM U0199-LOST COMMUNICATION WITH DRIVER DOOR MODULE U0200-LOST COMMUNICATION WITH PASSENGER DOOR MODULE U0209-LOST COMMUNICATION WITH MEMORY SEAT CONTROL MODULE U0212-LOST COMMUNICATION WITH SCCM - CAN B U0231-LOST COMMUNICATION WITH RAIN SENSING MODULE MODULE, Intrusion Transceiver (ITM) B1A37-SECURITY TRANSMITTER SENSOR CIRCUIT LOW B1A38-SECURITY TRANSMITTER SENSOR CIRCUIT HIGH B1A3A-SECURITY RECEIVER SENSOR CIRCUIT LOW B1A3B-SECURITY RECEIVER SENSOR CIRCUIT HIGH B1A3C-INTERNAL SIREN BATTERY B1A3D-SIREN BATTERY TAMPER / LOSS OF POWER SUPPLY B1A3E-SIREN / ITM MISMATCH B1A3F-ITM ARMING SEQUENCE PERFORMANCE B1A41-SECURITY TRANSMITTER SENSOR CIRCUIT OPEN B1A42-SECURITY TRANSMITTER SENSOR CIRCUIT SHORTED TOGETHER B1A43-SECURITY TRANSMITTER SENSOR RETURN CIRCUIT LOW B1A44-SECURITY RECEIVER SENSOR CIRCUIT OPEN B1A45-SECURITY RECEIVER SENSOR CIRCUIT SHORTED TOGETHER B1A46-SECURITY RECEIVER SENSOR RETURN CIRCUIT LOW B1A47-SECURITY TRANSMITTER/RECEIVER SENSOR RETURN CIRCUIT HIGH B2206-CURRENT VIN MISSING/MISMATCH B222A-VEHICLE LINE MISMATCH B223C-INTRUSION TRANSCEIVER MODULE INTERNAL U0019-CAN B BUS U0100-LOST COMMUNICATION WITH ENGINE CONTROL MODULE/POWERTRAIN CONTROL MODULE U0121-LOST COMMUNICATION WITH ANTI—LOCK BRAKE MODULE U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE (TIPM) U0151-LOST COMMUNICATION WITH OCCUPANT RESTRAINT CONTROLLER U0155-LOST COMMUNICATION WITH CLUSTER/CCN U110D-LOST COMMUNICATION WITH SECURITY SIREN U1416-IMPLAUSIBLE SECURITY SIREN SIGNAL RECEIVED MODULE, Light Rain Sensor (LRSM) B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B2211-RAIN SENSOR MODULE INITIALIZATION PERFORMANCE B221D-(RSM) RAIN SENSOR MODULE INTERNAL B2329-RAIN SENSOR OPTICAL PATH 1 PERFORMANCE B232A-RAIN SENSOR OPTICAL PATH 2 PERFORMANCE B232B-RAIN SENSOR OPTICAL PATH 3 PERFORMANCE B232C-RAIN SENSOR OPTICAL PATH 4 PERFORMANCE U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0212-LOST COMMUNICATION WITH SCM - CAN-B MODULE, Memory Seat (MSMD) B1D56-ADJUSTABLE PEDAL SENSOR CIRCUIT LOW B1D57-ADJUSTABLE PEDAL SENSOR CIRCUIT HIGH B1D5B-ADJUSTABLE PEDAL SWITCH CIRCUIT PERFORMANCE B1D5C-ADJUSTABLE PEDAL SWITCH CIRCUIT STUCK FORWARD B1D5D-ADJUSTABLE PEDAL SWITCH CIRCUIT STUCK REARWARD B1D62-POWER SEAT SWITCH STUCK B1D63-POWER SEAT SWITCH OPEN B1D67-ADJUSTABLE PEDAL CONTROL CIRCUIT PERFORMANCE B1D6D-SEAT HORIZONTAL POSITION SENSOR CIRCUIT LOW B1D6E-SEAT HORIZONTAL POSITION SENSOR CIRCUIT HIGH B1D71-SEAT FRONT VERTICAL POSITION SENSOR CIRCUIT LOW B1D72-SEAT FRONT VERTICAL POSITION SENSOR CIRCUIT HIGH B1D75-SEAT REAR VERTICAL POSITION SENSOR CIRCUIT LOW B1D76-SEAT REAR VERTICAL POSITION SENSOR CIRCUIT HIGH B1D79-SEAT RECLINER POSITION SENSOR CIRCUIT LOW B1D7A-SEAT RECLINER POSITION SENSOR CIRCUIT HIGH B1D7B-SEAT HORIZONTAL MOTOR CONTROL CIRCUIT PERFORMANCE B1D7F-SEAT FRONT VERTICAL MOTOR CONTROL CIRCUIT PERFORMANCE B1D83-SEAT REAR VERTICAL MOTOR CONTROL CIRCUIT PERFORMANCE B1D87-SEAT BACKREST MOTOR CONTROL CIRCUIT PERFORMANCE B1D8D-STEERING COLUMN TELESCOPE POSITION SENSOR CIRCUIT LOW B1D8E-STEERING COLUMN TELESCOPE POSITION SENSOR CIRCUIT HIGH B1D91-STEERING COLUMN TILT POSITION SENSOR CIRCUIT LOW B1D92-STEERING COLUMN TILT POSITION SENSOR CIRCUIT HIGH B1D93-STEERING COLUMN TELESCOPE MOTOR CONTROL CIRCUIT PERFORMANCE B1D97-STEERING COLUMN TILT MOTOR CONTROL CIRCUIT PERFORMANCE B1D9B-SEAT HORIZONTAL FRONT STOP NOT LEARNED B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B221C-MEMORY SEAT MODULE INTERNAL U0019-CAN B BUS U0020-CAN B BUS OFF PERFORMANCE U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE U0151-LOST COMMUNICATION WITH OCCUPANT RESTRAINT CONTROLLER U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0156-LOST COMMUNICATION WITH EOM U0159-LOST COMMUNICATION WITH PARKING ASSIST CONTROL MODULE U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE U0167-LOST COMMUNICATION WITH INTRUSION TRANSCEIVER CONTROL MODULE U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIRELESS IGNITION NODE OR WIN) U0169-LOST COMMUNICATION WITH SUNROOF CONTROL MODULE U0181-LOST COMMUNICATION WITH HEADLAMP LEVELING TRANSLATOR U0184-LOST COMMUNICATION WITH RADIO U0186-LOST COMMUNICATION WITH AUDIO AMPLIFIER U0196-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE U0197-LOST COMMUNICATION WITH HFM U0199-LOST COMMUNICATION WITH DRIVER DOOR MODULE U0200-LOST COMMUNICATION WITH PASSENGER DOOR MODULE U0208-LOST COMMUNICATION WITH HEATED SEAT CONTROL MODULE U0212-LOST COMMUNICATION WITH SCCM - CAN B U0231-LOST COMMUNICATION WITH RAIN SENSING MODULE MODULE, Park Assist (PTS) B128E-11-PTS SENSOR 1-CIRCUIT SHORT TO GROUND B128E-12-PTS SENSOR 1-CIRCUIT SHORT TO BATTERY B128E-25-PTS SENSOR 1-SIGNAL SHAPE / WAVEFORM FAILURE B128E-92-PTS SENSOR 1-PERFORMANCE OR INCORRECT OPERATION B128F-11-PTS SENSOR 2-CIRCUIT SHORT TO GROUND B128F-12-PTS SENSOR 2-CIRCUIT SHORT TO BATTERY B128F-25-PTS SENSOR 2-SIGNAL SHAPE / WAVEFORM FAILURE B128F-92-PTS SENSOR 2-PERFORMANCE OR INCORRECT OPERATION B1290-11-PTS SENSOR 3-CIRCUIT SHORT TO GROUND B1290-12-PTS SENSOR 3-CIRCUIT SHORT TO BATTERY B1290-25-PTS SENSOR 3-SIGNAL SHAPE / WAVEFORM FAILURE B1290-92-PTS SENSOR 3-PERFORMANCE OR INCORRECT OPERATION B1291-11-PTS SENSOR 4-CIRCUIT SHORT TO GROUND B1291-12-PTS SENSOR 4-CIRCUIT SHORT TO BATTERY B1291-25-PTS SENSOR 4-SIGNAL SHAPE / WAVEFORM FAILURE B1291-92-PTS SENSOR 4-PERFORMANCE OR INCORRECT OPERATION B1292-11-PTS SENSOR 5-CIRCUIT SHORT TO GROUND B1292-12-PTS SENSOR 5-CIRCUIT SHORT TO BATTERY B1292-25-PTS SENSOR 5-SIGNAL SHAPE / WAVEFORM FAILURE B1295-92-PTS SENSOR 5-PERFORMANCE OR INCORRECT OPERATION B1293-11-PTS SENSOR 6-CIRCUIT SHORT TO GROUND B1293-12-PTS SENSOR 6-CIRCUIT SHORT TO BATTERY B1293-25-PTS SENSOR 6-SIGNAL SHAPE / WAVEFORM FAILURE B1293-92-PTS SENSOR 6-PERFORMANCE OR INCORRECT OPERATION B1295-11-PTS SENSOR 8 CIRCUIT SHORT TO GROUND B1295-12-PTS SENSOR 8-CIRCUIT SHORT TO BATTERY B1295-25-PTS SENSOR 8-SIGNAL SHAPE / WAVEFORM FAILURE B1295-92-PTS SENSOR 8-PERFORMANCE OR INCORRECT OPERATION B1296-11-PTS SENSOR 9-CIRCUIT SHORT TO GROUND B1296-12-PTS SENSOR 9-CIRCUIT SHORT TO BATTERY B1296-25-PTS SENSOR 9-SIGNAL SHAPE / WAVEFORM FAILURE B1296-92-PTS SENSOR 9-PERFORMANCE OR INCORRECT OPERATION B1297-11-PTS SENSOR 10-CIRCUIT SHORT TO GROUND B1297-12-PTS SENSOR 10-CIRCUIT SHORT TO BATTERY B1297-25-PTS SENSOR 10-SIGNAL SHAPE / WAVEFORM FAILURE B1297-92-PTS SENSOR 10-PERFORMANCE OR INCORRECT OPERATION B1298-11-PTS SENSOR 11-CIRCUIT SHORT TO GROUND B1298-12-PTS SENSOR 11-CIRCUIT SHORT TO BATTERY B1298-25-PTS SENSOR 11-SIGNAL SHAPE / WAVEFORM FAILURE B1298-92-PTS SENSOR 11-PERFORMANCE OR INCORRECT OPERATION B210C-16-BATTERY VOLTAGE INPUT-CIRCUIT VOLTAGE BELOW THRESHOLD B210C-17-BATTERY VOLTAGE INPUT-CIRCUIT VOLTAGE ABOVE THRESHOLD B2128-16-SENSOR SUPPLY VOLTAGE-CIRCUIT VOLTAGE BELOW THRESHOLD B2128-17-SENSOR SUPPLY VOLTAGE-CIRCUIT VOLTAGE ABOVE THRESHOLD B2129-16-PTS DISPLAY SUPPLY VOLTAGE-CIRCUIT VOLTAGE BELOW THRESHOLD B21DD-16-SYSTEM VOLTAGE-CIRCUIT VOLTAGE BELOW THRESHOLD B21DD-17-SYSTEM VOLTAGE-CIRCUIT VOLTAGE ABOVE THRESHOLD B222A-00-VEHICLE LINE MISMATCH B2232-00-(PTS) PARKTRONICS INTERNAL B2233-00-(PTS) PARKTRONICS FRONT DISPLAY INTERNAL B2234-00-(PTS) PARKTRONICS REAR DISPLAY INTERNAL U0010-00-CAN INTERIOR BUS U0141-00-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0155-00-LOST COMMUNICATION WITH CLUSTER/CCN U0423-00-IMPLAUSIBLE DATA RECEIVED FROM CLUSTER/CCN U0431-00-IMPLAUSIBLE DATA RECEIVED FROM IPM (FCM/TIPM) U1101-00-LOST COMMUNICATION WITH PTS DISPLAY-REAR 1 U112B-00-LOST COMMUNICATION WITH PTS DISPLAY-FRONT 1 MODULE, Passenger Door (PDM) B16A4-PASSENGER WINDOW SWITCH BACKLIGHTING CIRCUIT LOW B16A5-PASSENGER WINDOW SWITCH BACKLIGHTING CIRCUIT HIGH B185D-PASSENGER WINDOW SWITCH CIRCUIT STUCK B185F-PASSENGER WINDOW MOTOR CONTROL CIRCUIT LOW B1860-PASSENGER WINDOW MOTOR CONTROL CIRCUIT HIGH B1863-PASSENGER WINDOW POSITION SENSOR POWER SUPPLY LOW B1864-PASSENGER WINDOW POSITION SENSOR POWER SUPPLY HIGH B1865-PASSENGER WINDOW POSITION SENSOR CIRCUIT PERFORMANCE B1D12-PASSENGER MIRROR POSITION SENSOR POWER SUPPLY CIRCUIT LOW B1D13-PASSENGER MIRROR POSITION SENSOR POWER SUPPLY CIRCUIT HIGH B1D15-PASSENGER MIRROR VERTICAL POSITION SENSOR INPUT CIRCUIT LOW B1D16-PASSENGER MIRROR VERTICAL POSITION SENSOR INPUT CIRCUIT HIGH B1D18-PASSENGER MIRROR HORIZONTAL POSITION SENSOR INPUT CIRCUIT LOW B1D19-PASSENGER MIRROR HORIZONTAL POSITION SENSOR INPUT CIRCUIT HIGH B1D2A-PASSENGER MIRROR VERTICAL MOTOR CONTROL CIRCUIT/PERFORMANCE B1D2E-PASSENGER MIRROR HORIZONTAL MOTOR CONTROL CIRCUIT/PERFORMANCE B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B2219-PASSENGER DOOR MODULE INTERNAL B2577-PASSENGER WINDOW NOT CALIBRATED/LOST CALIBRATION B2581-PASSENGER WINDOW POSITION SENSOR(S) NO SIGNAL U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0151-LOST COMMUNICATION WITH OCCUPANT RESTRAINT CONTROLLER (ORC) U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0156-LOST COMMUNICATION WITH EOM U0159-LOST COMMUNICATION WITH PARKING ASSIST CONTROL MODULE U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE U0167-LOST COMMUNICATION WITH INTRUSION TRANSCEIVER CONTROL MODULE U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN) U0169-LOST COMMUNICATION WITH SUNROOF CONTROL MODULE U0181-LOST COMMUNICATION WITH HEADLAMP LEVELING TRANSLATOR U0184-LOST COMMUNICATION WITH RADIO U0186-LOST COMMUNICATION WITH AUDIO AMPLIFIER U0195-LOST COMMUNICATION WITH SDARS U0196-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE U0197-LOST COMMUNICATION WITH HANDS FREE PHONE MODULE U0199-LOST COMMUNICATION WITH DRIVER DOOR MODULE U0208-LOST COMMUNICATION WITH HEATED SEAT CONTROL MODULE U0209-LOST COMMUNICATION WITH MEMORY SEAT CONTROL MODULE U0212-LOST COMMUNICATION WITH SCM - CAN-B U0231-LOST COMMUNICATION WITH LIGHT RAIN SENSING MODULE U0241-LOST COMMUNICATION WITH AUTO HIGHBEAM HEADLIGHT CONTROL MODULE MODULE, Passive Entry (PEM) B1A71-01-PASSIVE ENTRY ANTENNA 1 - GENERAL ELECTRICAL FAILURE B1A72-01-PASSIVE ENTRY ANTENNA 2 - GENERAL ELECTRICAL FAILURE B1A73-01-PASSIVE ENTRY ANTENNA 3 - GENERAL ELECTRICAL FAILURE B1A74-01-PASSIVE ENTRY ANTENNA 4 - GENERAL ELECTRICAL FAILURE B2199-16-BATTERY VOLTAGE - CIRCUIT VOLTAGE BELOW THRESHOLD B2199-17-BATTERY VOLTAGE - CIRCUIT VOLTAGE ABOVE THRESHOLD B21DD-84-SYSTEM VOLTAGE - SIGNAL BELOW ALLOWABLE RANGE B219DD-85-SYSTEM VOLTAGE - SIGNAL ABOVE ALLOWABLE RANGE B2205-00-ORIGINAL VIN MISSING/MISMATCH B223B-00-VEHICLE CONFIGURATION MISMATCH B229B-00-PASSIVE ENTRY MODULE (PEM) INTERNAL B259A-00-FRONT LEFT DOOR HANDLE SENSE B259B-00-FRONT RIGHT DOOR HANDLE SENSE B259E-00-TRUNK/LIFTGATE DOOR HANDLE SENSE B25A3-00-FRONT LEFT DOOR HANDLE SENSOR B25A4-00-FRONT RIGHT DOOR HANDLE SENSOR U0019-00-CAN B BUS U0020-00-CAN B BUS OFF PERFORMANCE U0021-00-CAN B BUS (+) CIRCUIT OPEN U0022-00-CAN B BUS (+) CIRCUIT LOW U0023-00-CAN B BUS (+) CIRCUIT HIGH U0024-00-CAN B BUS (-) CIRCUIT OPEN U0025-00-CAN B BUS (-) CIRCUIT LOW U0026-00-CAN B BUS (-) CIRCUIT HIGH U0141-00-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0155-00-LOST COMMUNICATION WITH CLUSTER/CCN MODULE, Police/Taxi Interface (PTIM) P1462-FUEL LEVEL OUTPUT CIRCUIT LOW P1463-FUEL LEVEL OUTPUT CIRCUIT HIGH P1504-VEHICLE SPEED OUTPUT CIRCUIT LOW P1505-VEHICLE SPEED OUTPUT CIRCUIT HIGH P164A-MIL OUTPUT CIRCUIT LOW P164B-MIL OUTPUT CIRCUIT HIGH P170A-PARK/NEUTRAL OUTPUT CIRCUIT LOW P170B-PARK/NEUTRAL OUTPUT CIRCUIT HIGH P170C-ENGINE RPM OUTPUT CIRCUIT LOW P170D-ENGINE RPM OUTPUT CIRCUIT HIGH C1088-BRAKE LAMP SWITCH OUTPUT CIRCUIT LOW C1089-BRAKE LAMP OUTPUT CIRCUIT HIGH B1693-ACCESSORY DIMMING CONTROL CIRCUIT LOW B1694-ACCESSORY DIMMING CONTROL CIRCUIT HIGH B17CF-EMERGENCY FLASHING LAMP REQUEST 1 CIRCUIT HIGH B17D2-EMERGENCY FLASHING LAMP REQUEST 2 CIRCUIT HIGH B17D4-HEADLAMP STATUS OUTPUT CIRCUIT LOW B17D5-HEADLAMP STATUS OUTPUT CIRCUIT HIGH B19B4-DRIVER DOOR AJAR OUTPUT CIRCUIT LOW B19B5-DRIVER DOOR AJAR OUTPUT CIRCUIT HIGH B1A5B-PANIC ALARM MUTE REQUEST CIRCUIT HIGH B1A5D-PANIC ALARM ACTIVATION OUTPUT CIRCUIT LOW B1A5E-PANIC ALARM ACTIVATION STATUS CIRCUIT HIGH B1CC1-DEPLOYMENT NOTIFICATION OUTPUT CIRCUIT LOW B1CC2-DEPLOYMENT NOTIFICATION OUTPUT CIRCUIT HIGH B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B237C-DATA COMMUNICATION RADIO INPUT CIRCUIT HIGH B237F-HORN MUTE REQUEST CIRCUIT HIGH B2381-DRIVER SEAT BELT OUTPUT CIRCUIT LOW B2382-DRIVER SEAT BELT OUTPUT CIRCUIT HIGH B2384-HORN SWITCH OUTPUT CIRCUIT LOW B2385-HORN SWITCH OUTPUT CIRCUIT HIGH B2720-FRONTAL IMPACT OUTPUT CIRCUIT LOW B271F-FRONTAL IMPACT OUTPUT CIRCUIT HIGH U0021-CAN B BUS (+) CIRCUIT OPEN U0022-CAN B BUS (+) CIRCUIT LOW U0023-CAN B BUS (+) CIRCUIT HIGH U0024-CAN B BUS (-) CIRCUIT OPEN U0025-CAN B BUS (-) CIRCUIT LOW U0026-CAN B BUS (-) CIRCUIT HIGH U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0151-LOST COMMUNICATION WITH OCCUPANT RESTRAINT CONTROLLER (ORC) U0156-LOST COMMUNICATION WITH ELECTRONIC OVERHEAD MODULE U0159-LOST COMMUNICATION WITH PARK ASSIST CONTROL MODULE U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE U0167-LOST COMMUNICATION WITH INTRUSION TRANSCEIVER CONTROL MODULE U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIRELESS IGNITION NODE OR WIN) U0184-LOST COMMUNICATION WITH RADIO U0195-LOST COMMUNICATION WITH SDARS U0197-LOST COMMUNICATION WITH HANDS FREE PHONE MODULE U0208-LOST COMMUNICATION WITH HEATED SEAT CONTROL MODULE U0209-LOST COMMUNICATION WITH MEMORY SEAT CONTROL MODULE U0212-LOST COMMUNICATION WITH STEERING COLUMN CONTROL MODULE MODULE, Powertrain Control (PCM), NGC P000B-BANK 1 CAMSHAFT 2 POSITION SLOW RESPONSE P0013-BANK 1 CAMSHAFT 2 POSITION ACTUATOR CIRCUIT OPEN P0014-EXHAUST TARGET ERROR BANK 1 P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT - BANK 1 SENSOR 1 - 2.7L P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT - BANK 1 SENSOR 1 - 3.5L P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT - BANK 1 SENSOR 1 - 5.7L/SRT8 P0031-O2 SENSOR 1/1 HEATER CIRCUIT LOW P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH P0037-O2 SENSOR 1/2 HEATER CIRCUIT LOW P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH P0051-O2 SENSOR 2/1 HEATER CIRCUIT LOW P0052-O2 SENSOR 2/1 HEATER CIRCUIT HIGH P0057-O2 SENSOR 2/2 HEATER CIRCUIT LOW P0058-O2 SENSOR 2/2 HEATER CIRCUIT HIGH P0071-AMBIENT AIR TEMPERATURE SENSOR PERFORMANCE P0072-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT LOW P0073-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT HIGH P0107-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT LOW P0108-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT HIGH P0111-INTAKE AIR TEMPERATURE SENSOR 1 PERFORMANCE P0112-INTAKE AIR TEMPERATURE SENSOR 1 CIRCUIT LOW P0113-INTAKE AIR TEMPERATURE SENSOR 1 CIRCUIT HIGH P0116-ENGINE COOLANT TEMPERATURE SENSOR PERFORMANCE P0117-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW - 2.7L P0117-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW - 3.5L/5.7L/SRT8 P0118-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT HIGH - 2.7L P0118-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT HIGH - 3.5L/5.7L/SRT8 P0121-THROTTLE POSITION SENSOR 1 PERFORMANCE P0122-THROTTLE POSITION SENSOR 1 CIRCUIT LOW P0123-THROTTLE POSITION SENSOR 1 CIRCUIT HIGH P0125-INSUFFICIENT COOLANT TEMP FOR CLOSED-LOOP FUEL CONTROL P0128-THERMOSTAT RATIONALITY P0129-BAROMETRIC PRESSURE OUT-OF-RANGE LOW P0131-O2 SENSOR 1/1 CIRCUIT LOW P0132-O2 SENSOR 1/1 CIRCUIT HIGH P0133-O2 SENSOR 1/1 SLOW RESPONSE P0135-O2 SENSOR 1/1 HEATER PERFORMANCE P0137-O2 SENSOR 1/2 CIRCUIT LOW P0138-O2 SENSOR 1/2 CIRCUIT HIGH P0139-O2 SENSOR 1/2 SLOW RESPONSE P013A-O2 SENSOR 1/2 SLOW RESPONSE - RICH TO LEAN P013C-O2 SENSOR 2/2 SLOW RESPONSE - RICH TO LEAN P0140-O2 SENSOR 1/2 NO ACTIVITY DETECTED P0141-O2 SENSOR 1/2 HEATER PERFORMANCE P0151-O2 SENSOR 2/1 CIRCUIT LOW P0152-O2 SENSOR 2/1 CIRCUIT HIGH P0153-O2 SENSOR 2/1 SLOW RESPONSE P0155-O2 SENSOR 2/1 HEATER PERFORMANCE P0157-O2 SENSOR 2/2 CIRCUIT LOW P0158-O2 SENSOR 2/2 CIRCUIT HIGH P0159-O2 SENSOR 2/2 SLOW RESPONSE P0160-O2 SENSOR 2/2 NO ACTIVITY DETECTED P0161-O2 SENSOR 2/2 HEATER PERFORMANCE P0171-FUEL SYSTEM 1/1 LEAN P0172-FUEL SYSTEM 1/1 RICH P0174-FUEL SYSTEM 2/1 LEAN P0175-FUEL SYSTEM 2/1 RICH P0196-ENGINE OIL TEMPERATURE SENSOR PERFORMANCE P0197-ENGINE OIL TEMPERATURE SENSOR CIRCUIT LOW P0198-ENGINE OIL TEMPERATURE SENSOR CIRCUIT HIGH P0201-FUEL INJECTOR 1 CIRCUIT/OPEN P0202-FUEL INJECTOR 2 CIRCUIT/OPEN P0203-FUEL INJECTOR 3 CIRCUIT/OPEN P0204-FUEL INJECTOR 4 CIRCUIT/OPEN P0205-FUEL INJECTOR 5 CIRCUIT/OPEN P0206-FUEL INJECTOR 6 CIRCUIT/OPEN P0207-FUEL INJECTOR 7 CIRCUIT/OPEN P0208-FUEL INJECTOR 8 CIRCUIT/OPEN P0221-THROTTLE POSITION SENSOR 2 CIRCUIT PERFORMANCE P0222-THROTTLE POSITION SENSOR 2 CIRCUIT LOW P0223-THROTTLE POSITION SENSOR 2 CIRCUIT HIGH P0298-ENGINE OIL TEMPERATURE TOO HIGH P0300-MULTIPLE CYLINDER MISFIRE P0301-CYLINDER 1 MISFIRE P0302-CYLINDER 2 MISFIRE P0303-CYLINDER 3 MISFIRE P0304-CYLINDER 4 MISFIRE P0305-CYLINDER 5 MISFIRE P0306-CYLINDER 6 MISFIRE P0307-CYLINDER 7 MISFIRE P0308-CYLINDER 8 MISFIRE P0315-NO CRANK SENSOR LEARNED P0325-KNOCK SENSOR 1 CIRCUIT P0330-KNOCK SENSOR 2 CIRCUIT P0335-CRANKSHAFT POSITION SENSOR CIRCUIT P0339-CRANKSHAFT POSITION SENSOR INTERMITTENT P0340-CAMSHAFT POSITION SENSOR CIRCUIT - BANK 1 SENSOR 1 - 2.7 P0340-CAMSHAFT POSITION SENSOR CIRCUIT - BANK 1 SENSOR 1 - 3.5L P0340-CAMSHAFT POSITION SENSOR CIRCUIT - BANK 1 SENSOR 1 - 5.7L/SRT8 P0344-CAMSHAFT POSITION SENSOR INTERMITTENT - 2.7L P0344-CAMSHAFT POSITION SENSOR INTERMITTENT - 3.5L P0344-CAMSHAFT POSITION SENSOR INTERMITTENT - 5.7L/SRT8 P0401-EGR SYSTEM PERFORMANCE P0403-EGR CONTROL CIRCUIT/OPEN P0404-EGR POSITION SENSOR PERFORMANCE P0405-EGR POSITION SENSOR CIRCUIT LOW P0406-EGR POSITION SENSOR CIRCUIT HIGH P0420-CATALYST EFFICIENCY (BANK 1) P0430-CATALYST EFFICIENCY (BANK 2) P0440-GENERAL EVAP SYSTEM FAILURE P0441-EVAP PURGE SYSTEM PERFORMANCE P0443-EVAP PURGE CONTROL CIRCUIT P0452-EVAP PRESSURE SWITCH STUCK CLOSED P0455-EVAP SYSTEM LARGE LEAK P0456-EVAP SYSTEM SMALL LEAK P0457-LOOSE FUEL CAP P0461-FUEL LEVEL SENSOR 1 PERFORMANCE P0462-FUEL LEVEL SENSOR 1 CIRCUIT LOW P0463-FUEL LEVEL SENSOR 1 CIRCUIT HIGH P0480-COOLING FAN 1 CONTROL CIRCUIT P0481-COOLING FAN 2 CONTROL CIRCUIT P050B-COLD START IGNITION TIMING PERFORMANCE P0501-VEHICLE SPEED SENSOR 1 PERFORMANCE (Equipped with ABS) P0501-VEHICLE SPEED SENSOR 1 PERFORMANCE (Not Equipped with ABS) P0503-VEHICLE SPEED SENSOR 1 ERRATIC (Equipped with ABS) P0503-VEHICLE SPEED SENSOR 1 ERRATIC (Not Equipped with ABS) P0506-IDLE SPEED PERFORMANCE LOWER THAN EXPECTED P0507-IDLE SPEED PERFORMANCE HIGHER THAN EXPECTED P050D-COLD START ROUGH IDLE P0513-INVALID SKIM KEY P0520-ENGINE OIL PRESSURE SENSOR CIRCUIT P0521-ENGINE OIL PRESSURE SENSOR PERFORMANCE P0522-ENGINE OIL PRESSURE SENSOR CIRCUIT LOW P0522-OIL PRESSURE TOO LOW - 3.5L P0523-ENGINE OIL PRESSURE SENSOR CIRCUIT HIGH P0524-ENGINE OIL PRESSURE TOO LOW P0551-POWER STEERING PRESSURE SWITCH PERFORMANCE P0562-BATTERY VOLTAGE LOW P0563-BATTERY VOLTAGE HIGH P0571-BRAKE SWITCH 1 PERFORMANCE P0572-BRAKE SWITCH 1 STUCK ON P0579-SPEED CONTROL SWITCH 1 PERFORMANCE (EXCEPT POLICE PACKAGE) P0579-SPEED CONTROL SWITCH 1 PERFORMANCE (POLICE PACKAGE) P0580-SPEED CONTROL SWITCH 1 CIRCUIT LOW (EXCEPT POLICE PACKAGE) P0580-SPEED CONTROL SWITCH 1 CIRCUIT LOW (POLICE PACKAGE) P0585-SPEED CONTROL SWITCH 1/2 CORRELATION (EXCEPT POLICE PACKAGE) P0585-SPEED CONTROL SWITCH 1/2 CORRELATION (POLICE PACKAGE) P0591-SPEED CONTROL SWITCH 2 PERFORMANCE (EXCEPT POLICE PACKAGE) P0591-SPEED CONTROL SWITCH 2 PERFORMANCE (POLICE PACKAGE) P0592-SPEED CONTROL SWITCH 2 CIRCUIT LOW (EXCEPT POLICE PACKAGE) P0592-SPEED CONTROL SWITCH 2 CIRCUIT LOW (POLICE PACKAGE) P0600-SERIAL COMMUNICATION LINK P0601-INTERNAL MEMORY CHECKSUM INVALID P0606-INTERNAL CONTROL PROCESSOR P060B-ETC A/D GROUND PERFORMANCE P060D-ETC LEVEL 2 APP PERFORMANCE P060E-ETC LEVEL 2 TPS PERFORMANCE P060F-ETC LEVEL 2 ECT PERFORMANCE P061A-ETC LEVEL 2 TORQUE PERFORMANCE P061C-ETC LEVEL 2 RPM PERFORMANCE P0622-GENERATOR FIELD CONTROL CIRCUIT/OPEN P0627-FUEL PUMP CONTROL CIRCUIT/OPEN P062C-ETC LEVEL 2 MPH PERFORMANCE P0630-VIN NOT PROGRAMMED IN PCM P0632-ODOMETER NOT PROGRAMMED IN PCM P0633-SKIM SECRET KEY NOT STORED IN PCM P0642-SENSOR REFERENCE VOLTAGE 1 CIRCUIT LOW P0643-SENSOR REFERENCE VOLTAGE 1 CIRCUIT HIGH P0645-A/C CONTROL CIRCUIT/OPEN P0652-SENSOR REFERENCE VOLTAGE 2 CIRCUIT LOW P0653-SENSOR REFERENCE VOLTAGE 2 CIRCUIT HIGH P0660-MANIFOLD TUNING VALVE (MTV) CONTROL CIRCUIT P0685-AUTO SHUTDOWN CONTROL CIRCUIT P0688-ASD/MAIN SENSE CIRCUIT P0573-BRAKE SWITCH 1 STUCK OFF P0700-TRANSMISSION CONTROL SYSTEM (MIL REQUEST) P0703-BRAKE SWITCH 2 PERFORMANCE P0850-PARK/NEUTRAL SWITCH PERFORMANCE P1004-SHORT RUNNER VALVE CONTROL PERFORMANCE P1005-MANIFOLD TUNING VALVE CONTROL PERFORMANCE P1115-GENERAL TEMPERATURE RATIONALITY P1128-CLOSED LOOP FUELING NOT ACHIEVED - BANK 1 P1129-CLOSED LOOP FUELING NOT ACHIEVED - BANK 2 P1239-ENGINE OIL TEMPERATURE TOO LOW P1404-EGR CLOSE POSITION PERFORMANCE P1411-CYLINDER 1 REACTIVATION CONTROL PERFORMANCE P1414-CYLINDER 4 REACTIVATION CONTROL PERFORMANCE P1416-CYLINDER 6 REACTIVATION CONTROL PERFORMANCE P1417-CYLINDER 7 REACTIVATION CONTROL PERFORMANCE P1501-VEHICLE SPEED SENSOR 1/2 CORRELATION - DRIVE WHEELS (Equipped with ABS) P1502-VEHICLE SPEED SENSOR 1/2 CORRELATION - NON DRIVE WHEELS (Equipped with ABS) P150D-COLD START ROUGH IDLE - OPEN THROTTLE START P1521-INCORRECT ENGINE OIL TYPE P1524- OIL PRESSURE OUT OF RANGE - CAMSHAFT ADVANCE/RETARD DISABLED P1572-BRAKE PEDAL STUCK ON P1573-BRAKE PEDAL STUCK OFF P1593-SPEED CONTROL SWITCH 1/2 STUCK (EXCEPT POLICE PACKAGE) P1593-SPEED CONTROL SWITCH 1/2 STUCK (POLICE PACKAGE) P1603-PCM INTERNAL DUAL-PORT RAM COMMUNICATION FAILURE P1604-PCM INTERNAL DUAL-PORT RAM READ/WRITE INTEGRITY FAILURE P1607-PCM INTERNAL SHUTDOWN TIMER RATIONALITY P1618-SENSOR REFERENCE VOLTAGE 1 ERRATIC P1628-SENSOR REFERENCE VOLTAGE 2 ERRATIC P1696-EEPROM MEMORY WRITE DENIED/INVALID P1697-EMR (SRI) MILEAGE NOT STORED P1897-LVL2 RPM FAIL - NO POST P2008-SHORT RUNNER VALVE (SRV) CONTROL CIRCUIT P2016-SHORT RUNNER VALVE (SRV) POSITION SENSOR CIRCUIT LOW P2017-SHORT RUNNER VALVE (SRV) POSITION SENSOR CIRCUIT HIGH P2066-FUEL LEVEL SENSOR 2 PERFORMANCE P2067-FUEL LEVEL SENSOR 2 CIRCUIT LOW P2068-FUEL LEVEL SENSOR 2 CIRCUIT HIGH P2072-ELECTRONIC THROTTLE CONTROL SYSTEM - ICE BLOCKAGE P2077-INTAKE MANIFOLD TUNING VALVE POSITION SENSOR CIRCUIT LOW P2078-INTAKE MANIFOLD TUNING VALVE POSITION SENSOR CIRCUIT HIGH P2096-DOWNSTREAM FUEL TRIM SYSTEM 1 LEAN P2097-DOWNSTREAM FUEL TRIM SYSTEM 1 RICH P2098-DOWNSTREAM FUEL TRIM SYSTEM 2 LEAN P2099-DOWNSTREAM FUEL TRIM SYSTEM 2 RICH P2100-ELECTRONIC THROTTLE CONTROL MOTOR CIRCUIT/OPEN - BANK 1 P2101-ELECTRONIC THROTTLE CONTROL MOTOR PERFORMANCE - BANK 1 P2107-ELECTRONIC THROTTLE CONTROL MODULE PROCESSOR P2108-ELECTRONIC THROTTLE CONTROL MODULE PERFORMANCE P2110-ELECTRONIC THROTTLE CONTROL SYSTEM - FORCED LIMITED RPM P2111-ELECTRONIC THROTTLE CONTROL SYSTEM - UNABLE TO CLOSE P2112-ELECTRONIC THROTTLE CONTROL SYSTEM - UNABLE TO OPEN P2115-ACCELERATOR PEDAL POSITION SENSOR 1 MINIMUM STOP PERFORMANCE P2116-ACCELERATOR PEDAL POSITION SENSOR 2 MINIMUM STOP PERFORMANCE P2118-ELECTRONIC THROTTLE CONTROL MOTOR CURRENT PERFORMANCE P2122-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT LOW P2123-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT HIGH P2127-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT LOW P2128-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT HIGH P2135-THROTTLE POSITION SENSOR 1/2 CORRELATION P2138-ACCELERATOR PEDAL POSITION SENSOR 1/2 CORRELATION P2161-VEHICLE SPEED SENSOR 2 ERRATIC (with ABS) P2166-ACCELERATOR PEDAL POSITION SENSOR 1 MAXIMUM STOP PERFORMANCE P2167-ACCELERATOR PEDAL POSITION SENSOR 2 MAXIMUM STOP PERFORMANCE P2172-HIGH AIRFLOW/VACUUM LEAK DETECTED (INSTANTANEOUS ACCUMULATION) P2173-HIGH AIRFLOW/VACUUM LEAK DETECTED (SLOW ACCUMULATION) P2174-LOW AIRFLOW/RESTRICTION DETECTED (INSTANTANEOUS ACCUMULATION) P2175-LOW AIRFLOW/RESTRICTION DETECTED (SLOW ACCUMULATION) P2181-COOLING SYSTEM PERFORMANCE P2271-O2 SENSOR 1/2 SIGNAL BIASED RICH P2273-O2 SENSOR 2/2 SIGNAL BIASED RICH P2299-BRAKE PEDAL POSITION/ACCELERATOR PEDAL POSITION INCOMPATIBLE P2302-IGNITION COIL 1 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5 P2302-IGNITION COIL 1 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8 P2305-IGNITION COIL 2 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5 P2305-IGNITION COIL 2 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8 P2308-IGNITION COIL 3 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5 P2308-IGNITION COIL 3 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8 P2311-IGNITION COIL 4 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5 P2311-IGNITION COIL 4 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8 P2314-IGNITION COIL 5 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5 P2314-IGNITION COIL 5 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8 P2317-IGNITION COIL 6 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5 P2317-IGNITION COIL 6 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8 P2320-IGNITION COIL 7 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8 P2323-IGNITION COIL 8 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8 P2503-CHARGING SYSTEM OUTPUT LOW P2504-CHARGING SYSTEM OUTPUT HIGH P2533-IGNITION SWITCH RUN/START POSITION CIRCUIT P2610-PCM INTERNAL ENGINE OFF TIMER PERFORMANCE P3400-MDS RATIONALITY BANK 1 P3401-MDS SOLENOID 1 CIRCUIT P3402-CYLINDER 1 DEACTIVATION CONTROL PERFORMANCE P3425-MDS SOLENOID 4 CIRCUIT P3426-CYLINDER 4 DEACTIVATION CONTROL PERFORMANCE P3441-MDS SOLENOID 6 CIRCUIT P3442-CYLINDER 6 DEACTIVATION CONTROL PERFORMANCE P3449-MDS SOLENOID 7 CIRCUIT P3450-CYLINDER 7 DEACTIVATION CONTROL PERFORMANCE P3497-MDS RATIONALITY BANK 2 U0001-CAN C BUS U0101-LOST COMMUNICATION WITH TCM U0103-LOST COMMUNICATION WITH ELECTRIC GEAR SHIFT MODULE U0104-LOST COMMUNICATION WITH ACC MODULE U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE U0141-LOST COMMUNICATION WITH FCM/TIPM U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN) U110A-LOST COMMUNICATION WITH SCM (SAS) U110C-LOST FUEL LEVEL MESSAGE U110E-LOST AMBIENT TEMPERATURE MESSAGE U110F-LOST FUEL VOLUME MESSAGE U1110-LOST VEHICLE SPEED MESSAGE U1113-LOST A/C PRESSURE MESSAGE U1120-LOST WHEEL DISTANCE MESSAGE U1186-LOST COMMUNICATION WITH CRUISE CONTROL MODULE U1403-IMPLAUSIBLE FUEL LEVEL SIGNAL RECEIVED U1411-IMPLAUSIBLE FUEL VOLUME SIGNAL RECEIVED U1412-IMPLAUSIBLE VEHICLE SPEED SIGNAL RECEIVED U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED U1418-IMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED U1431-IMPLAUSIBLE CCM DATA RECEIVED MODULE, Steering Control (SCM) B1489-STEERING WHEEL CONTROL AUDIO SWITCH CIRCUIT B148A-STEERING WHEEL CONTROL MENU SWITCH CIRCUIT B148B-STEERING WHEEL CONTROL UP SWITCH CIRCUIT B148C-STEERING WHEEL CONTROL DOWN SWITCH CIRCUIT B148D-STEERING WHEEL CONTROL SIDE SWITCH CIRCUIT B148E-STEERING WHEEL CONTROL [+] SWITCH CIRCUIT B148F-STEERING WHEEL CONTROL [-] SWITCH CIRCUIT B1490-STEERING WHEEL CONTROL C/T SWITCH CIRCUIT B1DA0-STEERING COLUMN TILT SWITCH CIRCUIT STUCK B1DA5-STEERING COLUMN TELESCOPE SWITCH CIRCUIT STUCK B2225-STEERING CONTROL MODULE INTERNAL B2332-HORN SWITCH INPUT CIRCUIT/PERFORMANCE C1219-STEERING ANGLE SENSOR ERRATIC PERFORMANCE P0562-BATTERY VOLTAGE LOW P0563-BATTERY VOLTAGE HIGH P0585-SPEED CONTROL MULTIPLEXED SWITCH 1/2 CORRELATION U0002-CAN C BUS OFF PERFORMANCE U0019-CAN B BUS CIRCUIT U0121-LOST COMMUNICATION WITH ABS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0155-LOST COMMUNICATION WITH CLUSTER / CCN U1109-LOST COMMUNICATION WITH LIN STEERING WHEEL CONTROLS MODULE, Sunroof (SUNR) B1841-SUNROOF OPEN SWITCH INPUT CIRCUIT HIGH B1844-SUNROOF CLOSE SWITCH INPUT CIRCUIT HIGH B1847-SUNROOF VENT SWITCH INPUT CIRCUIT HIGH B1849-SUNROOF MOTOR CONTROL CIRCUIT/PERFORMANCE (STALLED) B210A-SYSTEM VOLTAGE LOW B210B-SYSTEM VOLTAGE HIGH B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B2227-SUNROOF ECU INTERNAL U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0155-LOST COMMUNICATION WITH CLUSTER/CCN MODULE, Tire Pressure (TPM) B2199-16-BATTERY VOLTAGE - CIRCUIT VOLTAGE BELOW THRESHOLD B2199-17-BATTERY VOLTAGE - CIRCUIT VOLTAGE ABOVE THRESHOLD B21DD-84-SYSTEM VOLTAGE - SIGNAL VOLTAGE BELOW ALLOWABLE RANGE B21DD-85-SYSTEM VOLTAGE - SIGNAL ABOVE ALLOWABLE RANGE C0077-00-LOW TIRE PRESSURE C1501-96-TIRE PRESSURE SENSOR 1 - INTERNAL COMPONENT FAILURE C1502-96-TIRE PRESSURE SENSOR 2 - INTERNAL COMPONENT FAILURE C1503-96-TIRE PRESSURE SENSOR 3 - INTERNAL COMPONENT FAILURE C1504-96-TIRE PRESSURE SENSOR 4 - INTERNAL COMPONENT FAILURE C151C-00-TIRE PRESSURE SENSORS MISSING C151D-00-TIRE PRESSURE SENSOR LOCATION UNDETERMINED C1580-00-LEFT/RIGHT SIDE TIRE PRESSURE SENSOR LOCATION UNDETERMINED C1581-00-FRONT/REAR TIRE PRESSURE SENSOR LOCATION UNDETERMINED C2209-00-TIRE PRESSURE MONITOR INTERNAL U0001-00-CAN C BUS U0002-00-CAN C BUS OFF PERFORMANCE U0100-00-LOST COMMUNICATION WITH ECM/PCM U0121-00-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE U0141-00-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0168-00-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN/WCM) MODULE, Totally Integrated Power (TIPM) B10B4-CABIN HEATER 1 CONTROL CIRCUIT LOW B10B5-CABIN HEATER 1 CONTROL CIRCUIT HIGH B10B8-CABIN HEATER 2 CONTROL CIRCUIT LOW B10B9-CABIN HEATER 2 CONTROL CIRCUIT HIGH B162B-LEFT LOW BEAM DRIVER CIRCUIT LOW B162C-LEFT LOW BEAM CONTROL CIRCUIT HIGH B162F-RIGHT LOW BEAM CONTROL CIRCUIT LOW B1630-RIGHT LOW BEAM CONTROL CIRCUIT HIGH B1633-LEFT HI BEAM CONTROL CIRCUIT LOW B1634-LEFT HI BEAM CONTROL CIRCUIT HIGH B1637-RIGHT HI BEAM CONTROL CIRCUIT LOW B1638-RIGHT HI BEAM CONTROL CIRCUIT HIGH B163B-FRONT LEFT TURN CONTROL CIRCUIT LOW B163C-FRONT LEFT TURN CONTROL CIRCUIT HIGH B163F-FRONT RIGHT TURN CONTROL CIRCUIT LOW B1640-FRONT RIGHT TURN CONTROL CIRCUIT HIGH B1643-REAR LEFT TURN CONTROL CIRCUIT LOW B1644-REAR LEFT TURN CONTROL CIRCUIT HIGH B1647-REAR RIGHT TURN CONTROL CIRCUIT LOW B1648-REAR RIGHT TURN CONTROL CIRCUIT HIGH B1659-FRONT FOG LAMP CONTROL CIRCUIT LOW B165C-PARK LAMP CONTROL CIRCUIT LOW B165D-PARK LAMP CONTROL CIRCUIT HIGH B1660-FRONT FOG LAMP CONTROL CIRCUIT HIGH B1663-REAR FOG LAMP CONTROL CIRCUIT LOW B1667-REVERSE LAMP CONTROL CIRCUIT LOW B1664-REAR FOG LAMP CONTROL CIRCUIT HIGH B1668-REVERSE LAMP CONTROL CIRCUIT HIGH B1820-HOOD AJAR INPUT CIRCUIT HIGH B1D68-ADJUSTABLE PEDAL CONTROL CIRCUIT LOW B2101-IGNITION RUN/START INPUT LOW B2102-IGNITION RUN/START INPUT HIGH B2104-IGNITION RUN/START 1 CONTROL CIRCUIT LOW B2105-IGNITION RUN/START 1 CONTROL CIRCUIT HIGH B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B2112-5 VOLT SUPPLY CIRCUIT LOW B211E-IGNITION RUN/ACC/PAD CONTROL CIRCUIT LOW B211F-IGNITION RUN/ACC/PAD CONTROL CIRCUIT HIGH B2122-IGNITION RUN CONTROL CIRCUIT LOW B2123-IGNITION RUN CONTROL CIRCUIT HIGH B2184-IGNITION UNLOCK RUN/START CONTROL CIRCUIT LOW B2206-CURRENT VIN MISSING/MISMATCH B2215-FRONT CONTROL MODULE INTERNAL B222C-VEHICLE CONFIGURATION NOT PROGRAMMED B2304-WIPER PARK SWITCH INPUT CIRCUIT LOW B2305-WIPER PARK SWITCH INPUT CIRCUIT HIGH B2323-HEADLAMP WASHER MOTOR CONTROL CIRCUIT LOW B2324-HEADLAMP WASHER MOTOR CONTROL CIRCUIT HIGH B2328-WASHER FLUID LEVEL SENSOR INPUT CIRCUIT HIGH B2336-HORN CONTROL CIRCUIT LOW B2337-HORN CONTROL CIRCUIT HIGH B2346-WIPER MOTOR LOW SPEED CONTROL CIRCUIT LOW B2347-WIPER MOTOR LOW SPEED CONTROL CIRCUIT HIGH B234A-WIPER MOTOR HIGH SPEED CONTROL CIRCUIT LOW B234B-WIPER MOTOR HIGH SPEED CONTROL CIRCUIT HIGH C1007-BRAKE FLUID LEVEL CIRCUIT LOW C1008-BRAKE FLUID LEVEL CIRCUIT HIGH C1017-RIGHT FRONT WHEEL SPEED SENSOR CIRCUIT LOW C1018-RIGHT FRONT WHEEL SPEED SENSOR CIRCUIT HIGH P0072-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT LOW P0073-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT HIGH P0532-A/C PRESSURE SENSOR CIRCUIT LOW P0533-A/C PRESSURE SENSOR CIRCUIT HIGH P0616-STARTER CONTROL CIRCUIT LOW - DIESEL P0616-STARTER CONTROL CIRCUIT LOW - NGC P0646-A/C CLUTCH CONTROL CIRCUIT LOW - DIESEL P0646-A/C CLUTCH CONTROL CIRCUIT 2 LOW - NGC P0647-A/C CLUTCH CONTROL CIRCUIT HIGH - DIESEL P0647-A/C CLUTCH CONTROL CIRCUIT 2 HIGH - NGC P0691-COOLING FAN 1 CONTROL CIRCUIT LOW P0692-COOLING FAN 1 CONTROL CIRCUIT HIGH P0693-COOLING FAN 2 CONTROL CIRCUIT LOW P0694-COOLING FAN 2 CONTROL CIRCUIT HIGH P0886-TCM POWER CONTROL CIRCUIT LOW P0887-TCM POWER CONTROL CIRCUIT HIGH U0001-CAN C BUS U0019-CAN B BUS U0021-CAN B BUS (+) CIRCUIT OPEN U0022-CAN B BUS (+) CIRCUIT LOW U0023-CAN B BUS (+) CIRCUIT HIGH U0024-CAN B BUS (-) CIRCUIT OPEN U0025-CAN B BUS (-) CIRCUIT LOW U0026-CAN B BUS (-) CIRCUIT HIGH U0100-LOST COMMUNICATION WITH ECM/PCM U0101-LOST COMMUNICATION WITH TCM U0102-LOST COMMUNICATION WITH DTCM U0103-LOST COMMUNICATION WITH ELECTRIC GEAR SHIFT MODULE U0104-LOST COMMUNICATION WITH CRUISE CONTROL MODULE U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE U0127-LOST COMMUNICATION WITH TIRE PRESSURE MONITOR MODULE U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0143-LOST COMMUNICATION WITH MULTI-PURPOSE MODULE (POLICE AND TAXI INTERFACE MODULE) (PTIM) U0151-LOST COMMUNICATION WITH OCCUPANT RESTRAINT CONTROLLER (ORC) U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0156-LOST COMMUNICATION WITH EOM U0159-LOST COMMUNICATION WITH PARK ASSIST CONTROL MODULE U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE U0167-LOST COMMUNICATION WITH INTRUSION TRANSCEIVER CONTROL MODULE U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIRELESS IGNITION NODE OR WIN) U0169-LOST COMMUNICATION WITH SUNROOF CONTROL MODULE U0181-LOST COMMUNICATION WITH HEADLAMP LEVELING TRANSLATOR U0184-LOST COMMUNICATION WITH RADIO U0186-LOST COMMUNICATION WITH AUDIO AMPLIFIER U0196-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE – FIRST ROW U0197-LOST COMMUNICATION WITH HANDS FREE PHONE MODULE U0203-LOST COMMUNICATION WITH DOOR MODULE FRONT LEFT - (DMFL) (DRIVER DOOR MODULE - DDM) U0204-LOST COMMUNICATION WITH DOOR MODULE FRONT RIGHT - (DMFR) (PASSENGER DOOR MODULE - PDM) U0208-LOST COMMUNICATION WITH HEATED SEAT CONTROL MODULE U0209-LOST COMMUNICATION WITH MEMORY SEAT CONTROL MODULE U0212-LOST COMMUNICATION WITH SCM U0231-LOST COMMUNICATION WITH RAIN SENSING MODULE U0241-LOST COMMUNICATION WITH AUTO HIGHBEAM HEADLAMP CONTROL MODULE U0249-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE – LAST ROW (VES3) U1105-CAN B SIGNAL MISSING U1106-CAN C SIGNAL MISSING U1108-ADDITIONAL CAN B ECU DETECTED U110A-LOST COMMUNICATION WITH SCM - CAN-C U1145-LOST COMMUNICATION WITH KEYLESS GO SECURITY MODULE U1148-ADDITIONAL CAN-C ECU DETECTED U1158-LOST COMMUNICATION WITH SATELLITE VIDEO RECEIVER MODULE, Transmission Control (TCM) P0219-ENGINE OVERSPEED P0501-VEHICLE SPEED SENSOR 1 PERFORMANCE P0562-BATTERY VOLTAGE LOW P0563-BATTERY VOLTAGE HIGH P0601-INTERNAL MEMORY CHECKSUM INVALID P0602-CONTROL MODULE PROGRAMMING ERROR/NOT PROGRAMMED P0604-INTERNAL CONTROL MODULE RAM P0605-INTERNAL CONTROL MODULE ROM P0613-INTERNAL TRANSMISSION PROCESSOR P0614-ECM/TCM INCOMPATIBLE P0642-SENSOR REFERENCE VOLTAGE 1 CIRCUIT LOW P0643-SENSOR REFERENCE VOLTAGE 1 CIRCUIT HIGH P0657-SOLENOID SUPPLY VOLTAGE CIRCUIT P0710-TRANSMISSION TEMPERATURE SENSOR CIRCUIT P0712-TRANSMISSION TEMPERATURE SENSOR LOW P0714-TRANSMISSION TEMPERATURE SENSOR INTERMITTENT P0717-INPUT SPEED SENSOR 1 CIRCUIT NO SIGNAL P0730-INCORRECT GEAR RATIO P0731-GEAR RATIO ERROR IN 1ST P0732-GEAR RATIO ERROR IN 2ND P0733-GEAR RATIO ERROR IN 3RD P0734-GEAR RATIO ERROR IN 4TH P0735-GEAR RATIO ERROR IN 5TH P0741-TORQUE CONVERTER CLUTCH CIRCUIT PERFORMANCE P0742-TORQUE CONVERTER CLUTCH STUCK ON P0743-TCC SOLENOID CIRCUIT P0748-MODULATOR PRESSURE SOLENOID CIRCUIT P0752-1-2/4-5 SOLENOID P0753-1-2/4-5 SOLENOID CIRCUIT P0757-2-3 SOLENOID P0758-2-3 SOLENOID CIRCUIT P0762-3-4 SOLENOID P0763-3-4 SOLENOID CIRCUIT P0778-SHIFT PRESSURE SOLENOID CIRCUIT P0817-STARTER DISABLE (P/N) CIRCUIT/OPEN P1629-TCM INTERNAL - SOLENOID SUPPLY/ WATCHDOG P1631-TCM INTERNAL- PROCESSOR CLOCK PERFORMANCE P1632-TCM INTERNAL - TEST INTERNAL WATCHDOG PERFORMANCE P1633-TCM INTERNAL - TEST EXTERNAL WATCHDOG PERFORMANCE P1634-TCM INTERNAL- INTERNAL WATCHDOG PERFORMANCE P1636-TCM INTERNAL- EXTERNAL WATCHDOG PERFORMANCE P1637-TCM INTERNAL-EEPROM PERFORMANCE P1638-TCM INTERNAL-CAN 1 RAM PERFORMANCE P1639-TCM INTERNAL-CAN 2 RAM PERFORMANCE P1644-INCORRECT VARIANT/CONFIGURATION P1704-INPUT SPEED SENSOR 1 OVERSPEED P1705-INPUT SPEED SENSOR 2 OVERSPEED P1731-INCORRECT GEAR ENGAGED P2638-TORQUE MANAGEMENT FEEDBACK SIGNAL PERFORMANCE P2767-INPUT SPEED SENSOR 2 CIRCUIT NO SIGNAL P2783-TORQUE CONVERTER TEMPERATURE TOO HIGH P2784-INPUT SPEED SENSOR 1/2 CORRELATION U0002-CAN C BUS OFF PERFORMANCE U0100-LOST COMMUNICATION WITH ECM/PCM U0103-LOST COMMUNICATION WITH ELECTRIC GEAR SHIFT MODULE U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE U0401-IMPLAUSIBLE DATA RECEIVED FROM ECM/PCM U0404-IMPLAUSIBLE DATA RECEIVED FROM ESM U0414-IMPLAUSIBLE DATA RECEIVED FROM FDCM U0415-IMPLAUSIBLE DATA RECEIVED FROM ABS U0423-IMPLAUSIBLE DATA RECEIVED FROM CLUSTER/CCN U0424-IMPLAUSIBLE DATA RECEIVED FROM HVAC CONTROL MODULE U0431-IMPLAUSIBLE DATA FROM FCM/TIPM U110B-LOST ENGINE COOLANT MESSAGE U1118-LOST ENGINE MESSAGE U1119-LOST FCM MESSAGE U1400-IMPLAUSIBLE TPS SIGNAL RECEIVED U1401-IMPLAUSIBLE ENGINE SPEED SIGNAL RECEIVED U1402-IMPLAUSIBLE ENGINE TEMPERATURE SIGNAL RECEIVED U1404-IMPLAUSIBLE STATIC ENGINE TORQUE SIGNAL RECEIVED U1405-IMPLAUSIBLE MINIMUM ENGINE TORQUE SIGNAL RECEIVED U1406-IMPLAUSIBLE MAXIMUM ENGINE TORQUE SIGNAL RECEIVED U1407-IMPLAUSIBLE ENGINE TORQUE REQUEST SIGNAL RECEIVED U1408-IMPLAUSIBLE BRAKE SIGNAL RECEIVED U1409-IMPLAUSIBLE LEFT FRONT WHEEL SPEED SIGNAL RECEIVED U140A-IMPLAUSIBLE RIGHT FRONT WHEEL SPEED SIGNAL RECEIVED U140B-IMPLAUSIBLE LEFT REAR WHEEL SPEED SIGNAL RECEIVED U140C-IMPLAUSIBLE RIGHT REAR WHEEL SPEED SIGNAL RECEIVED U140D-IMPLAUSIBLE WHEEL SPEED SIGNALS RECEIVED U140F-IMPLAUSIBLE ENGINE VARIANT DATA U1410-IMPLAUSIBLE/MISSING FCM VARIANT DATA U1505-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM FDCM U1507-IMPLAUSIBLE ENGINE TEMPERATURE MESSAGE DATA LENGTH RECEIVED U1508-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM ESM U1509-IMPLAUSIBLE ENGINE VARIANT MESSAGE DATA LENGTH RECEIVED U150A-IMPLAUSIBLE FCM VARIANT MESSAGE DATA LENGTH RECEIVED NODE, Cabin Compartment (CCN) B1084-LEFT HEATED SEAT SWITCH INPUT CIRCUIT/PERFORMANCE B1087-RIGHT HEATED SEAT SWITCH INPUT CIRCUIT/PERFORMANCE B1200-AIRBAG WARNING INDICATOR CIRCUIT LOW B1202-AIRBAG WARNING INDICATOR CIRCUIT OPEN B120E-LEFT HEATED SEAT HI INDICATOR CONTROL CIRCUIT HIGH B120F-LEFT HEATED SEAT HI INDICATOR CONTROL CIRCUIT OPEN B1216-LEFT HEATED SEAT LO INDICATOR CONTROL CIRCUIT HIGH B1217-LEFT HEATED SEAT LO INDICATOR CONTROL CIRCUIT OPEN B121A-RIGHT HEATED SEAT HI INDICATOR CONTROL CIRCUIT HIGH B121B-RIGHT HEATED SEAT HI INDICATOR CONTROL CIRCUIT OPEN B1222-RIGHT HEATED SEAT LO INDICATOR CONTROL CIRCUIT HIGH B1223-RIGHT HEATED SEAT LO INDICATOR CONTROL CIRCUIT OPEN B1225-REAR WIPER INDICATOR CONTROL CIRCUIT LOW B1226-REAR WIPER INDICATOR CONTROL CIRCUIT HIGH B1607-HEADLAMP SWITCH INPUT CIRCUIT LOW B1608-HEADLAMP SWITCH INPUT CIRCUIT HIGH B160A-PANEL DIMMER INPUT CIRCUIT LOW B160B-PANEL DIMMER INPUT CIRCUIT HIGH B1613-PANEL ILLUMINATION CONTROL CIRCUIT LOW B1614-PANEL ILLUMINATION CONTROL CIRCUIT HIGH B161B-COURTESY/DOME LAMP CONTROL CIRCUIT LOW B161F-READING LAMP CONTROL CIRCUIT LOW B168F-FRONT FOG LAMP SWITCH STUCK B1801-DRIVER DOOR LOCK/UNLOCK SWITCH CIRCUIT LOW B1803-DRIVER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK LOCK B1804-DRIVER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK UNLOCK B1806-PASSENGER DOOR LOCK/UNLOCK SWITCH CIRCUIT LOW B1808-PASSENGER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK LOCK B1809-PASSENGER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK UNLOCK B1826-TRUNK RELEASE SWITCH INPUT CIRCUIT LOW B1A20-PRE-ARM TIMEOUT B2213-CCN INTERNAL C230D-TRAC/ESP OFF SWITCH INPUT CIRCUIT LOW P0460-FUEL LEVEL SENSOR 1 CIRCUIT P0462-FUEL LEVEL SENSOR 1 LOW CIRCUIT P0463-FUEL LEVEL SENSOR 1 HIGH CIRCUIT U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0151-LOST COMMUNICATION WITH OCCUPANT RESTRAINT CONTROLLER (ORC) U0159-LOST COMMUNICATION WITH PARKING ASSIST CONTROL MODULE U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE U0167-LOST COMMUNICATION WITH INTRUSION TRANSCEIVER CONTROL MODULE U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN) U0184-LOST COMMUNICATION WITH RADIO U0195-LOST COMMUNICATION WITH SDARS U0197-LOST COMMUNICATION WITH HANDS FREE PHONE MODULE U0208-LOST COMMUNICATION WITH HEATED SEAT CONTROL MODULE U0209-LOST COMMUNICATION WITH MEMORY SEAT CONTROL MODULE U0212-LOST COMMUNICATION WITH SCM - CAN-B NODE, Wireless Ignition (WIN) B1A08-RKE FOB 1 PERFORMANCE B1A09-RKE FOB 2 PERFORMANCE B1A0A-RKE FOB 3 PERFORMANCE B1A0B-RKE FOB 4 PERFORMANCE B1A0C-RKE FOB 5 PERFORMANCE B1A0D-RKE FOB 6 PERFORMANCE B1A0E-RKE FOB 7 PERFORMANCE B1A0F-RKE FOB 8 PERFORMANCE B1A10-RKE FOB 1 BATTERY LOW B1A11-RKE FOB 2 BATTERY LOW B1A12-RKE FOB 3 BATTERY LOW B1A13-RKE FOB 4 BATTERY LOW B1A14-RKE FOB 5 BATTERY LOW B1A15-RKE FOB 6 BATTERY LOW B1A16-RKE FOB 7 BATTERY LOW B1A17-RKE FOB 8 BATTERY LOW B1A24-KEY NOT PROGRAMMED B1A25-INVALID KEY B1A26-MAXIMUM NUMBER OF KEYS PROGRAMMED B1A27-WIN PROGRAMMING PERFORMANCE B1A28-ECM MISMATCH WITH SKIM B1A29-SKIM BASESTATION MISMATCH B1A35-UNIDENTIFIED KEY COMMUNICATION ERROR B1A68-STEERING COLUMN LOCK MODULE BOLT CONTROL LOW (WIN) B1A6B STEERING COLUMN LOCK MODULE NOT INITIALIZED B1A6C-SECRET KEY MISMATCH B1A77- REMOTE START ANTENNA CIRCUIT LOW B1A79- REMOTE START ANTENNA CIRCUIT OPEN OR NOT CONNECTED B210A-SYSTEM VOLTAGE LOW B210B-SYSTEM VOLTAGE HIGH B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B2204-ECU CONFIGURATION MISMATCH B2205-ORIGINAL VIN MISSING/MISMATCH B2224-SKREEM INTERNAL B2229-SKREEM INTERNAL - SKIM IMMOBILIZER B2254-COLUMN LOCK MODULE INTERNAL C0077-00- LOW TIRE PRESSURE C1501-96-TIRE PRESSURE MONITORING (TPM) SENSOR 1 INTERNAL C1502-96-TIRE PRESSURE SENSOR 2 INTERNAL C1503-96-TIRE PRESSURE SENSOR 3 INTERNAL C1504-96-TIRE PRESSURE SENSOR 4 INTERNAL P0928-BTSI CONTROL CIRCUIT U0100-LOST COMMUNICATION WITH THE ECM/PCM U0121-LOST COMMUNICATION WITH ABS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0236-LOST COMMUNICATION WITH COLUMN LOCK MODULE U1197-SECURITY SEED RESPONSE NOT RECEIVED FROM ECM/PCM RADIO B1401-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT LOW B1402-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH B1403-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN B1405-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW B1406-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH B1407-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN B1409-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT LOW B140A-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH B140B-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN B140D-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW B140E-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH B140F-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN B1421-AUDIO CD READ ERROR/INOPERABLE DISC B1422-AUDIO DVD READ ERROR/INOPERABLE DISC B1424-IMPROPER DVD-WRONG REGION B1429-RADIO DISPLAY HIGH TEMPERATURE B142A-RADIO UNIT HIGH TEMPERATURE B142D-AUDIO ANTENNA NOT CONNECTED B142E-GPS ANTENNA NOT CONNECTED B142F-SATELLITE RADIO ANTENNA NOT CONNECTED B1430(2.5)-SATELLITE RADIO ANTENNA INTERNAL PERFORMANCE B1430(4.0)-SATELLITE RADIO ANTENNA INTERNAL PERFORMANCE B143B-MICROPHONE 1 CIRCUIT LOW B143C-MICROPHONE 1 CIRCUIT HIGH B143E-MICROPHONE 2 CIRCUIT LOW B143F-MICROPHONE 2 CIRCUIT HIGH B145C-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER B145D-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER B145E-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER B145F-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER B1492-GENERAL MICROPHONE PERFORMANCE B14B7-MICROPHONE 1 CIRCUIT OPEN B14B8-MICROPHONE 2 CIRCUIT OPEN B156B-SATELLITE RADIO ANTENNA CIRCUIT B221E-RADIO INTERNAL U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0159-LOST COMMUNICATION WITH PARKING ASSIST CONTROL MODULE U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN) U0186-LOST COMMUNICATION WITH AUDIO AMPLIFIER U0196-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE U0197-LOST COMMUNICATION WITH HANDS FREE PHONE MODULE SYSTEM, Video Entertainment, Three (VES3) B142B-VES UNIT HIGH TEMPERATURE B14CE-VES BRIGHTNESS UP INPUT BUTTON STUCK B14CF-VES BRIGHTNESS DOWN INPUT BUTTON STUCK B210A-SYSTEM VOLTAGE LOW B210B-SYSTEM VOLTAGE HIGH B210D-BATTERY VOLTAGE LOW B210E-BATTERY VOLTAGE HIGH B21A1-ECU RESET/RECOVERY OCCURRED B222B-VEHICLE ENTERTAINMENT SYSTEM INTERNAL B222C-VEHICLE CONFIGURATION NOT PROGRAMMED U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0155-LOST COMMUNICATION WITH CLUSTER/CCN U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN) U0184-LOST COMMUNICATION WITH RADIO U1158-LOST COMMUNICATION WITH SATELLITE VIDEO RECEIVER (SDARV) TRANSLATOR, High Intensity Discharge (HIDT) B167A-LEFT FRONT HEADLAMP LIGHT SOURCE CIRCUIT B167B-RIGHT FRONT HEADLAMP LIGHT SOURCE CIRCUIT B2235-LEFT FRONT HEADLAMP BALLAST ECU INTERNAL B2236-RIGHT FRONT HEADLAMP BALLAST ECU INTERNAL B2237-LEFT FRONT HEADLAMP BALLAST NOT CALIBRATED B2286-CALIBRATION NOT LEARNED/LOST CALIBRATION B2239-HID LEVELING TRANSLATOR ECU INTERNAL U0019-CAN B BUS U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM) U0155-LOST COMMUNICATION WITH CLUSTER/CCN [Архив] -------------------- '03 DN SLT+ AWD
Buy The Right Part! |
9.5.2013, 0:18
![]() Fanatus Vulgaris ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 1 761 Регистрация: 8.3.2011 Из: Москва, Алтуфьево Пользователь №: 37 680 Реальное имя:Роман
ОФФ: вот что с человеком бан на месяц делает!
Спасибо! Это по всем годам? -------------------- --------------------
9.5.2013, 0:22
![]() Fanatus Vulgaris ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 2 059 Регистрация: 16.11.2009 Из: Defolt-city (Москва, СолнцевоПарк) Пользователь №: 26 309 Реальное имя:Георгий
Що це було?
-------------------- Крайслер T&C Limited 3.8 2004
Ваз21214 говноезд |
9.5.2013, 1:22
Это по всем годам? ...это нога, чья надо нога...(с) Що це було? Дай те бог, никогда этого не узнать... -------------------- '03 DN SLT+ AWD
15.5.2013, 15:19
Долгожитель ![]() ![]() ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 920 Регистрация: 26.11.2009 Из: Московия-Балторуссия Пользователь №: 26 550 Реальное имя:Сергей
Вот, держи! Что это? Это ноги! Зачем? Делай ноги, отсюда!!! (с)
-------------------- Додж Дюранго 2004, 5,7 HEMI, чёрный, красавелла вааще!
1.7.2021, 22:30
![]() Долгожитель ![]() ![]() ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 735 Регистрация: 4.2.2008 Из: СПб, Московские ворота. Москва, Марьино. Пользователь №: 12 055
Ошибки
B121E-02 B121D-08 B121D-05 B121D-09 B121E-03 B1219-22 C3FFF-FF Кто-нибудь расшифруйте. Если, что, то это по парктронику. -------------------- Крайслер Гранд Вояджер, 3.3, Лимитед 2006(VIN-2007) был.
Додж Караван 2,4 2001 был |
1.7.2021, 22:41
2.7.2021, 6:39
Сканировали на сервисе. Не профильном. Салова 40. -------------------- Крайслер Гранд Вояджер, 3.3, Лимитед 2006(VIN-2007) был.
2.7.2021, 8:45
Сканировали на сервисе. Не профильном. Салова 40. профильный? насканировали и сами не поняли чего?
2.7.2021, 12:21
Сканировали на сервисе. Не профильном. Салова 40. профильный? насканировали и сами не поняли чего?Евроавто -------------------- Крайслер Гранд Вояджер, 3.3, Лимитед 2006(VIN-2007) был.
Текстовая версия | Сейчас: 21.9.2026, 14:34 | ![]() |
