13.10.2017, 8:37
#3161
![]() Fanatus Vulgaris ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 1 528 Регистрация: 24.9.2012 Из: Екатеринбург Пользователь №: 54 977
В том то и дело что условно)
И то не всегда ( например датчики кислорода на 98 году верхний и нижний имеют одинаковую цифровую но разную буквенные части - и это два разных датчика) Дмитрий в общем то говорил что если разные номера значит были какие то изменения Нашел вот такое Default Okay I put the door on the other day but did the guts today and door alignment tweaking. What is different, 1.Well of coarse the door panel 2.Both the bars for the door lock and door handle are different. 3. Tweeter is in a different location and has a different mount but still can be swapped with a little tweaking. Okay the bars, Well its pretty tight in there so its kind of a pain. First we will talk about the door lock., simply has one clip each end and the bar pull off... The newer door has the door lock by the door handle (inside) the older has the door lock on the rear top of the door panel, that was the easy swap. The door handle bar was not as easy and again just one clip each end holding it on but just a little harder to get to. And if you want to use you key on that side you also need to swap the door handle. it has 2 bars and 2 clip one being a real pain to get to. It has 2 nuts that holds it in place 1 bottom front that is easy to see and another bottom rear that you will not see. You need to remove that little plastic cover on the rear back to gain access to it. 2 bars and two clips, one clip is a little pain but the other was not that bad. wiring and connections are all the same. Tweaking was kind of a pain. I am the type that will just keep doing it over and over and over till it is as good as I can get it. I had an issue with the door sticking a little further out top rear, about 1/4 inch. I tried shimming the lower door mount ext.. nothing.. Well I posted on a auto body forum the other day when I had put the door on, A guy came back with a simple answer , simply take a block of wood (be careful not to bend anything else) and stick it into the door jam, then push hard on the rear top with the window down of coarse and that should do it. Well it worked and now it looks good there. The only issue is that the gap in between the doors is slightly larger at the top then at the bottom, man I worked and worked on that and I think I have it pretty much whiten 1/8 or so difference.. Still bothers me though lol Anyways thats the Durango door change for anybody who needs to put a newer door on an older Durango (98-03 models) Только не понял челок оставил свою обшивку или нет..и менял ли он что на свое кроме замка Сообщение отредактировал Second - 13.10.2017, 8:44 -------------------- 1B4HS28Z4WF164527
13.10.2017, 9:37
#3162
Прописался ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 119 Регистрация: 4.11.2014 Из: Калуга Пользователь №: 74 973 Реальное имя:Максим
а я с него пороги беру....
-------------------- Додж Дюранго 1, 2000 г.в., 4.7 1B4HS28N6YF120285
7.11.2017, 12:57
#3163
Долгожитель ![]() ![]() ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 920 Регистрация: 26.11.2009 Из: Московия-Балторуссия Пользователь №: 26 550 Реальное имя:Сергей
Парни! Кого я на днях в Гродно видел на черном Д2 ?
-------------------- Додж Дюранго 2004, 5,7 HEMI, чёрный, красавелла вааще!
11.12.2017, 12:32
#3164
![]() Завсегдатай ![]() ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 316 Регистрация: 7.10.2014 Из: Текстильщики Пользователь №: 74 352 Реальное имя:Дмитрий Город:Москва
Джентльмены. Еду в Питер сегодня, завтра в 13-00 оттуда в Москву. Если что кому передать тут или там - готов поработать пеРедастом, за скромное вознаграждение. Скан паспорта вышлю в ЛС. Туда же и телефон для связи.
-------------------- Dodge Durango 1B4HS28N81F524923
13.12.2017, 21:36
#3165
![]() Fanatus Vulgaris ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 1 892 Регистрация: 12.10.2009 Из: санкт-петербург ( пр.Просвещения) Пользователь №: 25 512 Реальное имя:Евгений
Ура, я смог вернуться на форум :)
Что за год изменилось? Сообщение отредактировал psi-chel - 13.12.2017, 21:37 -------------------- |
14.12.2017, 1:09
#3166
![]() Fanatus Vulgaris ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 1 761 Регистрация: 8.3.2011 Из: Москва, Алтуфьево Пользователь №: 37 680 Реальное имя:Роман
Ура, я смог вернуться на форум :) Что за год изменилось? Рад тебя слышать! Изменений никаких: новых вёдер не прибавилось, старых всё так же ковыряют... Основной состав - без изменений: "тихо и спокойно как на сельском кладбище зимней ночью"(с) Сам как? -------------------- --------------------
14.12.2017, 8:55
#3167
Ура, я смог вернуться на форум :) Что за год изменилось? Рад тебя слышать! Изменений никаких: новых вёдер не прибавилось, старых всё так же ковыряют... Основной состав - без изменений: "тихо и спокойно как на сельском кладбище зимней ночью"(с) Сам как? Тихо и спокойно Сам,а я очередной раз поменял старое корыто на более старое.... Вот ковыряюсь вечно.... -------------------- |
31.12.2017, 17:41
#3168
![]() Завсегдатай ![]() ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 330 Регистрация: 14.2.2016 Из: Симферополь Крым Пользователь №: 83 159 Реальное имя:Юрий Город:Симферополь
С наступающим Н.Г. товарищи!!!!
Всем ДОБРА!!! -------------------- |
31.12.2017, 20:46
#3169
С наступающим Н.Г. товарищи!!!! Всем ДОБРА!!! Джентьмены и дамы (если такие есть среди нас)! Категорически поддерживаю. С Наступающими!!! -------------------- Dodge Durango 1B4HS28N81F524923
31.12.2017, 22:20
#3170
![]() Долгожитель ![]() ![]() ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 575 Регистрация: 15.8.2017 Из: Северодвинск Орёл Пользователь №: 90 887 Реальное имя:Дмитрий Город:Орел
Ура, я смог вернуться на форум :) Что за год изменилось? Рад тебя слышать! Изменений никаких: новых вёдер не прибавилось, старых всё так же ковыряют... Основной состав - без изменений: "тихо и спокойно как на сельском кладбище зимней ночью"(с) Сам как? Херасссе!!! А как же я, я ж прибавился!!!! С Новым, собачьим, годом !!! https://vk.com/videos120759515?z=video12075...pl_120759515_-2 Сообщение отредактировал сизый - 31.12.2017, 22:22 -------------------- Вояжёр 02г. 2.4л, 3.3л. Ренг 2.5л.
1.1.2018, 17:49
#3171
с новым годом недовнедорожники !!!!
28.1.2018, 21:54
#3172
Просто так)))
7.2.2018, 13:01
#3173
Прописался ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 103 Регистрация: 6.12.2016 Из: Москва Пользователь №: 87 496 Реальное имя:Михаил Город:Москва
Именные тапки
-------------------- Дюранго 2001 SLT
8.2.2018, 14:18
#3174
Эт гдеж такое)?
8.2.2018, 16:18
#3175
11.2.2018, 22:47
#3176
Опять купил какую то фигню)))
![]() ![]() ![]() Предстоит некоторый колхоз для нормальной работы клапана PCV, а в остальном должно встать нормально Ну и фильтры только под заказ из штатов... -------------------- 1B4HS28Z4WF164527
11.2.2018, 23:15
#3177
Член Крайслер Клуба Группа: Член Крайслер Клуба Сообщений: 23 685 Регистрация: 27.1.2011 Из: между Ленинградом и Москвой Пользователь №: 36 503 Реальное имя:Игорь
это, просто, какое то сборище перфекционистов
12.2.2018, 10:00
#3178
Предстоит некоторый колхоз для нормальной работы клапана PCV.... Так это, можно минифильтрик на клапанную крышку. Mopar Performance Сапун Cap - P4529880 ( типа этого) А как мои порожки??))) -------------------- |
12.2.2018, 10:46
#3179
Порожки пришли)) Лежат
А вот shield не пришла - потеряла ее usa почта Перезакажу По фильтру - пока вот в раздумьях - все же думал заколхозить в штатном стиле -------------------- 1B4HS28Z4WF164527
12.2.2018, 12:26
#3180
По фильтру - пока вот в раздумьях - все же думал заколхозить в штатном стиле Так а чё там думать, заказывай ещё крышки на головы , всё в один стиль))).. Минифильтрик для газов он ведь в родное место становится, ничего переделывать не нужно. Просто вместо трубки ставишь и всё. http://www.moparonlineperformance.com/prod..._smallblock.htm Сообщение отредактировал ЮраБорода - 12.2.2018, 12:29 -------------------- |
Текстовая версия | Сейчас: 8.7.2026, 9:18 | ![]() |
