133 страниц V  « < 15 16 17 18 19 > »
> Комплектация Chrysler Dodge по VIN. Пробивается только здесь
Гость_Old Chap_*
сообщение 13.5.2011, 12:26
Сообщение #321
1D7HA18D24S668279
Year/Model: 2004 DODGE RAM 1500 QUAD CAB PICKUP
Last Odometer: 0 Miles on 5 Апрель 2004 г.
Body Style: DR1H41
In-Service Date: 14 Апрель 2004 г.
Engine: EZA-5.7L V8 HEMI Engine
In-Service Odometer: 12 Miles
Transmission: DGQ-5-Spd Automatic 545RFE Transmission
Odometer Type: Miles
Color 1: PKJ-LT. Almond Pearl Metallic Clear Coat
Car Line: X
Color 2: QKJ-LT. Almond Pearl Metallic Clear Coat
Build Date: 23 Март 2004 г.
Standard Equipment
APAS Monotone Paint BAZS 136 Amp Alternator BCES 600 Amp Maintenance Free Battery
CGDS Front Height Adjust Shoulder Belts CG1S Next Gen Multistage Front Air Bags** CKES Floor Covering Carpet
CLAS Front Floor Mats CSPS Passenger Assist Handle CUES Rear Underseat Compartment Storage
CUSS Overhead Console w/Trip Computer DGES All 5-Speed Automatic Transmissions DRBS Corporate 9.25 LD Rear Axle
GACS Tinted Glass Windows GJDS Rear Fixed Window GNMS Passenger Side Sun Visor w/Mirror
GTSS Power Heated Mirrors, Fold-Away GXMS Remote Keyless Entry HAAS Air Conditioning
HGBS Dash Liner Insulation HGFS Floor Tunnel Insulation I77S Route 77 - UP, Mesquite, TX
JAYS Instrument Cluster w/Tach JCBS 120 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter JJBS Dual Note Electric Horns JJJS 12V Auxiliary Power Outlet
JPBS Power Locks JPDS Power Windows, Driver One-Touch LBCS Glove Box Lamp
LMAS Halogen Headlamps LPES Cargo Lamp MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia MCTS Bright Front Bumper MDAS Front License Plate Bracket
MURS Dodge Badge MWDS Removable Tailgate w/Caliper Latches MXBS Front Air Dam
MXCS Front Air Close Out Panel NFWS 26 Gallon Fuel Tank NHMS Speed Control
QKJS LT. Almond Pearl Metallic Clear Coat RBKS AM/FM Compact Disc Radio w/Chgr Ctrl RCDS 4 Speakers
SBAS Power Rack and Pinion Steering SFBS Front Heavy Duty Shock Absorbers SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar SUAS Tilt Steering Column TBBS Full Size Spare Tire
TBMS Tire Carrier Winch XBSS Pickup Box XFUS Trailer Tow w/4-Pin Connector Wiring
YAAS Build To U.S. Mkt. Specifications Z1CS GVW Rating - 6650# 1AAS U.S. Dealer Retail
163S Zone 63-Dallas 5I2S Two Wheel Drive (2WD)/(4X2) 5ZES 6 FT. Cargo Box
5ZKS Quad Cab 5ZLS 1500 Series 5ZWS DR-Vehicle Family
594S Vehicle Order Tracking 6USS U.S. Specifications Label 644S Texas Ship to State Code
944S Texas Sold to State Code
Optional Equipment
*VL Leather Trim 40/20/40 Bench Seat -L5 Taupe A85P 5.7L ENG (EZA)/5SPD A/T 5-45RFE(DGQ)
BRTP Anti-Lock 4-Wheel Disc Brakes CBEP 40/20/40 Split Bench Seat CSXP Rear 60/40 Split Folding Seat
CVHP Front Center Seat Cushion Storage CVNP Folding Flat Load Floor Storage DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter DMH 3.92 Rear Axle Ratio EAGC All Gas Engine
EZA 5.7L V8 HEMI Engine GNCP Sun Visors w/Illum Vanity Mirrors GNKP Rear View Auto Dim Mirror
GVBC All Vehicles W/Power Mirrors GXXP Sentry Key Theft Deterrent System JBMP Instr. Panel Sport Bezel
JRDP Power Driver Seat JTHP Power 6-Way Driver Seat LBDP Ash Tray Lamp
Вадим2
сообщение 15.5.2011, 19:14
Сообщение #322
Из: Москва ЮАО
Пользователь №: 5 913
Реальное имя:Вадим
IGDFG15R7X1072090
1: 1: U.S. BUILT
G: G: GENERAL MOTORS
D: D: GMC INCOMPLETE
F: F: GVWR RANGE 7001-8000 BRAKE SYSTEM - HYD
G: G: VAN 4 X 2
1: 1: 1/2 TON
5: 5: VAN
R: R: ENG OPT - L31 DISPL(L) - 5.7 CYL - V8 FUEL SYS - CPI
7: Check digit
X: X: 1999 MODEL YEAR
1: 1: OSHAWA #2 ON
Код модели кузова: TG1140
Двигатель: L99 ENGINE GAS, 8 CYL, 4.3L, MFI,4.3W(L99)
Коробка передач:
Модельный год: 1999
Дата производства: 03.12.1998
01U: EXTERIOR COLOR,PRIMARY,SPECIAL OVERRIDE,(01U)
1SE: PACKAGE OPTION 05,(1SE)
6WZ: SPRING COMPTR SELECT FRT LH,SUSP(6WZ)
7WZ: SPRING COMPTR SELECT FRT RH,SUSP(7WZ)
92I: INTERIOR TRIM SHALE/PEWTER,(92I)
92W: TRIM COMBINATION VINYL, MED DK PEWTER (W) (97),(92W)
A07: WINDOW,BODY GLASS,BODY GLS(A07)
A08: WINDOW,BODY GLASS,RH SIDE,RH BODY GLS(A08)
A17: WINDOW,SWING OUT GLASS,LH,SWING OUT GLS(A17)
A18: WINDOW,SWING OUT GLASS,REAR DOOR,SWING OUT GLS(A18)
A19: WINDOW,SWING OUT GLASS,SIDE REAR DOOR,SWING OUT GLS(A19)
A31: WINDOW,ELECTRIC OPERATED,SIDE,ELEC SI WDO(A31)
AJ1: GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW),DEEP TIN
AK5: RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER,DRIV
AU0: LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM),REMOTE ENTRY LK
AU3: LOCK,SIDE DOOR,ELECTRIC,ELEC S/D LK(AU3)
BG5: COVERING FLOOR ---DELETE,BG5)
C5Y: GVW RATING(7100 LBS),7100 LB GVWR(C5Y)
C60: AIR CONDITIONER,FRONT,MANUAL CONTROLS,A/C MAN CONT(C60)
DE5: MIRROR,OUTSIDE,LH & RH,REMOTE CONTROL,ELECTRIC,DEFOG,FOLDING,PAI
DH6: MIRROR,INSIDE,VISOR VANITY,RH AND LH(ILLUM),ILLUM S/S MIR(DH6)
E24: DOOR,HINGED SIDE REAR CARGO/SEAT ACCESS,HGE CARGO/SEAT ACCESS DO
EVA: TEST DVT, EVAP EMISSION REQUIREMENT,EVAP EMISSIONS REQUIRED(EVA)
FE9: FEDERAL EMISSION CERTIFICATION,FED EMIS(FE9)
G80: AXLE,REAR,POSITRACTION,LIMITED SLIP,POSITRACTION L/SLIP R/AXL(G8
GT4: AXLE,REAR,3.73 RATIO,3.73R(GT4)
JB6: BRAKE SYSTEM,VACUUM POWER DISC,DRUM,VACUUM PWR BRK SYS(JB6)
K34: CRUISE CONTROL,AUTOMATIC,ELECTRONIC,CRCONT(K34)
KD1: COOLING SYSTEM,TRANSMISSION OIL,TRANS OIL CLG(KD1)
KW2: GENERATOR,124 AMP,124 AMP(KW2)
L31: ENGINE,GAS,8 CYL,5.7L,CPI,5.7R(L31)
M30: TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC,4-SPD A/TRANS(M3
N33: STEERING COLUMN,TILT TYPE,TILT STRG COL(N33)
N90: WHEEL,15X7(CAST ALUMINUM),AL WHL(N90)
NA1: EMISSION SYSTEM,LESS THAN 8500 LB GVW,EMIS SYS(UNDER 8500 LB GVW
NP5: STEERING WHEEL,LEATHER WRAPPED,LEATHER WRAPPED STRG WHL(NP5)
P2A: PRICING ONE COLOR, CLASS A (B/F/J/W-TRK CKGMST),CLASS "A" ONE CO
PNA: PANEL TRIM, FRT DOORS,FRT DR TRIM PNL(PNA)
PNC: PANEL TRIM, FRT DOORS & SI RR DOOR(S) & RR DOORS,ALL DR TRIM PNL
TGK: SPECIAL PAINT SOLID, USED FOR ORDERING PURPOSES.,SPECIAL PAINT(T
UP0: RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CD, A
UP8: RADIO,PROVISIONS FOR STEREO INSTRUMENTATION,STEREO RDO PROVISION
UY7: TRAILER WIRING,7 WIRE,2 LEAD FRONT HARNESS,5 LEAD REAR HARNESS,7
V22: GRILLE,RADIATOR(CHROME),CHROME GRL(V22)
V37: BUMPER,FRONT AND REAR(CHROME),CHROME BPR(V37)
V73: VEHICLE STATEMENT - US/CANADA,US/CANADA VEHICLE STATEMENT(V73)
VK3: LICENSE PLATE,FRONT MOUNTING PACKAGE,FRT LIC PLT MTG PKG(VK3)
VK5: SEAT TEMPORARY, FOR SHIPPING,SEAT,TEMP(VK5)
VR4: TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM),EQLZR HITCH(VR4)
VXT: LABEL INCOMPLETE VEHICLE,INCOMPLETE VEH LABEL(VXT)
WEN: PLANT CODE - WENTZVILLE, MO, BOC,WENTZVILLE,MO ASSEMBLY PLANT(WE
XHM: TIRE FRONT P235/75R15 WOL R/PE ST TL ALS 108S (X/LOAD),TIRE(HXM)
YD3: AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE,FRT AXLE(YD3)
YD5: SPRING,FRONT(BASE EQUIPMENT),FRT SPRING(YD5)
YD6: SPRING,REAR(BASE EQUIPMENT),RR SPRING(YD6)
YF7: RECREATION VEHICLE UPFITTER PACKAGE,RECREATION UPFITTER PKG(YF7)
YHM: TIRE REAR P235/75R15 WOL R/PE ST TL ALS 108S (X/LOAD),TIRE(YHM)
Z82: TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH),PROVISION FOR HD T
Z88: GMC TRUCK,G M C(Z88)
ZHM: TIRE SPARE P235/75R15 WOL R/PE ST TL ALS 108S (X/LOAD),SPARE TIR
ZP0: SEATING ARRANGEMENT TEMPORARY DRIVER,TEMP DRIVER SEAT(ZP0)
ZQ2: DRIVER CONVENIENCE PACKAGE,DRVR CONVENIENCE PKG(ZQ2)
ZQ3: DRIVER CONVENIENCE PACKAGE II(MERCHANDISING OPTION),DRVR CONVENI
ZW6: GLASS PACKAGE,COMPLETE BODY,GLASS PKG(ZW6)
ZW9: BASE BODY OR CHASSIS,BASE BODY/CHAS(ZW9)
Diminator
сообщение 16.5.2011, 17:29
Сообщение #323
Из: Гражданин мира. Частенько в MSK
Пользователь №: 40 065
Пробейте, пожалуйста
1A4GP44R56B753167
Спасибо!
chrysler town & country, 3.3, AT, 2006
Визел
сообщение 17.5.2011, 0:00
Сообщение #324
Из: Питер
Пользователь №: 39 139
Пробейте пожалуйста 1B4GP25B51B177047
Старик Ромуальды...
сообщение 17.5.2011, 8:25
Сообщение #325
Пользователь №: 36 503
1A4GP44R56B753167
Спасибо!
1: Manufactured By DaimlerChrysler Corporation
A: Chrysler
4: Multipurpose Passenger Vehicle
G: 5001-6000# (2268-2721 KG) GVWR & Hyd Brakes
P: Town & Country (FWD)
4: Chrysler Town & Country Short Wheel Base (US, BUX)
4: Extended Wagon
R: 3.3L V6 CYL OHV Gas
5: Check Digit
6: 06
B: St. Louis Assembly South
Body Code: RSYH53
Engine: EGA 3.3L V6 OHV Engine
Transmission: DGL 4-Speed Automatic Transmission
Build Date: June 19, 2006
*B7 Cloth Low-Back Bucket Seats
0F6A FAM: AB TRACKING: 61004T00
171S Zone 71-Los Angeles
1A7S U.S. 100% GDP Program
28F Customer Preferred Package 28F
2DFA Customer Preferred Package 2DF
3AY Price Protection - Code Y
3SH 2nd Cycle
3SM 100% GDP Program
4DHA Prepaid Holdback
4EAA Sold Vehicle
4FJA Fleet Daily Rental W/Client Code
4FMS Fleet Option Editor
4FT Fleet Sales Order
4H1 Fleet Schedule Priority
4HF Special Scheduling Condition VI
4JMA Advance Payment Of SFPAP
4ME DTG Corp.
57N Drift
595S Long Wheel Base (LWB)
5AB St Louis South Tracking
5Z8S RS-Vehicle Family
629S Nevada State Code
6USS Label - U.S. Specifications
937S Oklahoma State Code
AJY Popular Equipment Group
APAS Monotone Paint
AWS Smoker's Group
BABP 160 Amp Alternator
BCDS 500 Amp Maintenance Free Battery
BGFS Anti-Lock Brakes
BRES 4-Wheel Disc Brakes
CDLS Manual Driver Lumbar Adjust
CG3S Advanced Multistage Front Air Bags**
CGUS Child Seat Anchor System-LATCH Ready
CGYS Drvr Inflatable Knee-Bolster Air Bag
CKAS Carpets - Floor and Cargo Area
CLDS Rear Fascia Scuff Pad
CLES Front & Rear Floor Mats
CSRS Passenger Assist Handles
CTWP Vinyl Door Trim Panel w/Map Pocket
CUNP Overhead Console
CUWS Lockable Underseat Storage Drawer
CUXP Front & Rear Ash Trays
CWXS Front and Rear Cargo Nets
CWZP 2 Row Stow 'N Go w/Tailgate Seats
CXCP All Vehicles with Cloth Seats
CYBS Bucket Seats
CYCS 2nd Row Buckets 60/40 Bench Seats
-D5 Med Slate Gray
DHAS Lock-Up Torque Converter
DLNS 2.49 Overall Top Gear Ratio
GAES Sunscreen Glass
GFAS Rear Window Defroster
GKBS Right Sliding Door w/Fixed Glass
GKDS LT Sliding Door w/Glass
GNAS Rear View Day/Night Mirror
GNCS Sun Visors w/Illum Vanity Mirrors
GXWS Keyless Entry w/Immobilizer
HAGP Air Conditioning w/3 Zone Temp Cntrl
HBBP Rear Air Conditioning w/Heater
HGAP Hood Insulation
HGDS Deluxe Insulation Group
JAJP Silver Face w/Tach Instr Cluster
JAPS Instrument Panel
JBJS Instrument Panel Woodgrain Bezel
JHBS Rear Window Wiper/Washer
JJAP Cigar Lighter
JKGS Power Quarter Vented Windows
JKPS 12V Auxiliary Power Outlet
JPBS Power Locks
JPR Power 8-Way Driver Seat
K4SS STRIPE/BADGE/MOLDING/COLOR
K7DS MAGNESIUM P/C - Molding
LACS Illuminated Entry
LAGS Warning Chime
LALS Low Washer Fluid Warning Signal
LAMS Door Ajar Warning Lamp
LAQS Sliding Door Alert Warning
LBTP Overhead Ash Tray/Cupholder Lamp
LCHS Rear Dome Lamp
LDFS Liftgate Flood Lamp
LEJP Trip Computer
LHDS Headlamp Off Time Delay
MGJS LX Badge
MLNS Rear Body Color Fascia
MLUS Front Body Color Fascia
MNKS Body Color Door Handles
MNPS Bright License Plate Brow
MSMS Town & Country Badge
MSNS Grille Chrysler Wing Badge
MW9A Delete Roof Rack Crossbars
MWGP Roof Rack
MXAS Front Air Dam
MYBP Stow'N Go Badge
NAS 50 State Emissions
NB5P Federal Tier 2, Bin 5 Emissions
NFAS 20 Gallon Fuel Tank
NHJS Exterior Mirrors w/Heating Element
NHMS Speed Control
PS2 Bright Silver Metallic Clear Coat
QS2S Bright Silver Metallic Clear Coat
RAZP AM/FM Cassette Compact Disc Radio
RCGP 6 Speakers
RSB Sirius Satellite Radio
SCKS Luxury Steering Wheel
SDAS Normal Duty Suspension
TBKS Compact Spare Tire
TM4S 215/70R15 BSW All Season Tires
TZAP Goodyear Brand Tires
W5SS 15" Wheel Covers
WCPS 15X6.5 Steel Wheels
X95P Call SIRIUS to Activate@888-539-7474
X97P 1-Year Service Provided by SIRIUS
XCAP Occupant Classification System
XFAS -35F Protection Anti-Freeze
XGDP Universal Garage Door Opener
XGHS Rear Seatback Grocery Bag Hooks
XHLS 12V DC Front & Rear Power Outlets
XSLS Brake/Park Interlock
XVNP Basic Owner's Manual
YEP Manuf Statement of Origin
YGEA 5 Additional Gallons of Gas
Z1CS GVW/Payload Rating
ZALP Spring - Left Front
ZBUP Spring - Left Rear
ZNJP Spring - Right Front
ZPUP Spring - Right Rear
1: Built in United States by DaimlerChrysler Corp.
B: DODGE
4: MULTIPURPOSE PASS VEHICLE LESS SIDE AIR BAGS
G: 5001 - 6000# (2268 - 2721 kg) GVWR & HYD BRAKES
P: CARAVAN/GRAND CARAVAN FWD
2: DODGE CARAVAN SE-FWD
5: WAGON
B: 2.4L 4 CYL MPI 16V (DOHC) (EDZ)
5: Check Digit
1: 01
B: St Louis Assembly South(Fenton, MO)
Body Code: RSKL52
Engine: EDZ 2.4L 4 Cyl DOHC 16V SMPI Engine
Transmission: DGC 3-Speed Automatic Transmission
Build Date: March 08, 2001
*K5 Cloth High-Back Bucket Seats
144S Zone 44-Syracuse
22C Customer Preferred Package 22C
2DCA Customer Preferred Package 2DC
3VNA Customer Preferred Discount
4SPA Supplemental NY Consumer Protection
582S Dodge Grand Caravan Se (Fwd)
593S Short Wheel Base (SWB)
5TV BusinessLink Inventory
633S New York State Code
933S New York State Code
APAS Monotone Paint
BAES 140 Amp Alternator
BCEP 600 Amp Maintenance Free Battery
BRBS Power Front Disc/Rear Drum Brakes
CB3S Center Console w/I/Panel Open Bin
CGWS Next Generation Front Air Bags**
CLE Front & Rear Floor Mats
CMNS Front Cargo Net (Ship in Pass Seat)
CYBS Bucket Seats
CYES 7 Passenger Seating
DGAS All 3-Speed Automatic Transmissions
DLFP 3.19 Overall Top Gear Ratio
EAAC All Engines
GFA Rear Window Defroster
GNES Passenger Side Sun Visor w/Mirror
GNFS Driver Side Sun Visor w/Mirror
GUMS Fold-Away Mirrors
GXJS 2 Regular, 1 Valet Keys
I28S Route 28 - NS, Buffalo, NY
JA1S White Face Instrument Cluster
JBHS Instrument Panel Black Bezel
K2NS STRIPE/BADGE/MOLDING/COLOR
-L5 Taupe
LAGS Warning Chime
LCAS Front Courtesy/Map Lamps
LCKS Front Dome Lamp
LDBS Cargo Compartment Lamp
LDGS Liftgate Flood Lamps
MDAP Front License Plate Bracket
MG4S Dodge Badge
MGAS Ram's Head Badge
MGKS SE Badge
MNJS Black License Plate Brow
MSBS Caravan Badge
MXAS Front Air Dam
NAE California Emissions
NBVP Low Emission Vehicle (LEV)
NHLP Windshield Wiper De-Icer
PQW Aquamarine Metallic Clear Coat
QQWS Aquamarine Metallic Clear Coat
RASS AM/FM Cassette Radio
RCDP 4 Speakers
W5DS 15" Wheel Covers
WCPP 15X6.5 Steel Wheels
XPXS Driver Door Protection Block
Z1AS GVW/Payload Rating
ZAGP Spring - Left Front
ZAVP Spring - Left Rear
ZNEP Spring - Right Front
ZNVP Spring - Right Rear
Гость_Vlad_Black_*
сообщение 17.5.2011, 12:32
Сообщение #326
Будьте добры
1B4GP25B22B735323
Старик Ромуальды...
сообщение 17.5.2011, 14:20
Сообщение #327
Цитата(Vlad_Black @ 17.5.2011, 12:35) *
Будьте добры
1B4GP25B22B735323
B: Dodge
4: Multipurpose Pass Vehicle w/o Side Air Bags "CGS"
G: 5001-6000#(2268-2721kg) GVWR & Hyd. Brakes
P: Caravan/Grand Caravan (FWD)
2: Dodge Caravan/Grand Caravan SE - FWD
5: Wagon
B: 2.4L l4 CYL Gasoline (DOHC 16V) (EDZ)
2: Check Digit
2: 02
B: St. Louis Assembly South (Fenton, MO)
Body Code: RSKL52
Build Date: June 07, 2002
0BAA FAM: CS TRACKING: 50427M02 MY:2005
0BBA Pcn 41127-614 Mga 0Bb
0BDA FAM: DH TRACKING: 50919T16 MY:2006
166S Zone 66-Orlando
24C Customer Preferred Package 24C
610S Florida State Code
910S Florida State Code
APAS Monotone Paint
CYBS Bucket Seats
DGBS All 4-Speed Automatic Transmissions
DLCP 2.6 Overall Top Gear Ratio
HGAS Hood Insulation
I44S Route 44 - FEC, Miami, FL
K2ES STRIPE/BADGE/MOLDING/COLOR
-L5 Taupe
LAGS Warning Chime
MGKS SE Badge
MSBS Caravan Badge
MURS Dodge Badge
MXAS Front Air Dam
PBQ Steel Blue Pearl Coat
QBQS Steel Blue Pearl Coat
RCDS 4 Speakers
anvasor
сообщение 18.5.2011, 0:33
Сообщение #328
Из: Минск
Пользователь №: 31 075
Реальное имя:Андрей
Можете попробовать сами, пробивает нормально:
- не требуется регистрации
http://www.compnine.com/vid.php
- с регистрацией (тогда появится окошко пробить ВИН)
http://www.usa-auto.ru/
P.S. иногда одну тачку пробивает в одном месте, но не берет в другом, и наоборот. Все хлопцам легче
Андрей +Инночка
Chrysler T&C Touring Signature 2008, 3.8L , S'&'G
Chrysler Pacifica Touring FWD 2007, 4.0 L
МТС, Вацап, Вайбер: + 37пятьдвадевять77О16ОО
Любопытный
сообщение 18.5.2011, 15:03
Сообщение #329
Тысячник
Из: Москва, СВАО
Пользователь №: 6 324
Реальное имя:Василий
Пробейте, пожалуйста: 2C8GP64L35R163108
Заранее благодарен!
Из характеристики: летать любит, но боится, считает быстро, но неправильно, пьет много, но с отвращением
Старик Ромуальды...
сообщение 19.5.2011, 9:53
Сообщение #330
Заранее благодарен!
Пост над Вашим прямо по ссылке... там всё просто.... можете потренироваться... и сравнить...
И, тем неменее, вот результат:
2: Manufactured By DaimlerChrysler Canada
C: Chrysler
8: Multipurpose Passenger Vehicle With Side Air Bags
G: 5001-6000# (2268-2721 KG) GVWR & Hyd. Brakes
6: Chrysler Town & Country LTD FWD (US, Can, Mex,BUX)
4: Extended Wagon
L: 3.8L V6 CYL Gasoline SMPI
3: Check Digit
5: 05
R: Windsor Assembly
Body Code: RSYS53
Engine: EGH 3.8L V6 OHV Engine
Build Date: March 16, 2004
*TL Lux Leather Trimmed Bucket Seats
0EIA FAM: BR TRACKING: 60807T10
151S Zone 51-Chicago
29X Customer Preferred Package 29X
2DXA Customer Preferred Package 2DX
3VXA Customer Preferred Discount
44RP CHROME GRILLE
614S Illinois State Code
914S Illinois State Code
APAS Monotone Paint
BABS 160 Amp Alternator
BNMS Traction Control
CJ5S Supp. Side Curtain All Rows Air Bags
CJRS 18 Oz. Full Length Carpet
CLXS Luxury Front & Rear Floor Mats
CMAS Heated Front Seats
CTCP Luxury Door Trim Panel
CUJP Overhead Storage Bins
CVVS Removable Center Frt Seat Console
CWRS Long Overhead Rail System
CWVP O/Head Console w/Trip Computer/EVIC
CYBS Bucket Seats
-D5 Med Slate Gray
DLAS 2.37 Overall Top Gear Ratio
GNKS Rear View Auto Dim Mirror
GNZP Auto Dim Exterior Driver Mirror
GUAS Pwr Htd Drvr Memory Mirrors, F/Away
HAHS ATC w/3 Zone Temp Control
JA6S Electroluminescent Instr Cluster
JBZS Instru Panel Woodgrain/Silver Bezel
JMAP Air Filtering
JPBS Power Locks
JPKS Pwr 8-Way Drvr Mem 4-Way Pass Seats
JRAS Right Power Sliding Door
JRBS Left Power Sliding Door
JRCS Power Liftgate
LABS Tire Pressure Monitoring Warning LP
LAGS Warning Chime
LAZP Vehicle Information Center
LCBS Door Courtesy Lamps
LCDS Map/Dome Reading Lamps
LCES Rear Courtesy/Reading Lamps
LEJP Trip Computer
LEWS Radio/Driver Seat/Mirrors Memory
LMGP Automatic Headlamps
LNJS Fog Lamps
LSAS Security Alarm
MLES Front Body Color/Chrome Fascia
MLVS Rear Body Color/Chrome Fascia
MRHS Lower Bodyside Bodycolor Cladding
MSAS Limited Badge
MWMS Roof Rack
MXAS Front Air Dam
NBGP Federal Tier 2, Bin 9A Emissions
NHMS Speed Control
RB1S AM/FM CD GPS Navigation Radio
RCES Infinity Speakers
RDVS 6-Disc in Dash CD/DVD Changer
RDZS Steering Wheel Mounted Audio Ctrls
RF4P Video Remote Control
RF7P 2nd Row Overhead 7" Video Screen
RFNP Wireless Headphones (IR)
RSP Uconnect Phone with Voice Command
SCLS Leather Wrapped Steering Wheel
TM1S 215/65R16 LBL All Season Tires
TZBP Bridgestone Brand Tires
WN5S 16X6.5 Aluminum Chrome Wheels
XAAS ParkSense Rear Park Assist System
XAMS Power Adjustable Pedals w/Memory
XRV Rear Seat Video System
ZBVP Spring - Left Rear
ZNHP Spring - Right Front
ZPVP Spring - Right Rear
Сообщение отредактировал ghirr - 19.5.2011, 13:03
Гость_lexm_*
сообщение 19.5.2011, 10:11
Сообщение #331
Здравствуйте, пробейте пожалуйста
VIN: 1B3ES26C55D149793
Vehicle: 2005 DODGE NEON/SE
Records: 8 records found in the CARFAX Vehicle History database
Старик Ромуальды...
сообщение 19.5.2011, 13:05
Сообщение #332
1: Manufactured by DaimlerChrysler Corporation
B: Dodge
3: Passenger Car
E: Restraint Sys. Active Driver & Pass Air Bags (CGW)
S: Neon (US/Mexico) SX2 (Canada) SRT (US) PL Family
2: Neon DL41(U.S.)
6: 4DR-Sedan
C: 2.0L 14 Cyl 16V SOHC Gasoline
5: Check Digit
5: 05
D: Belvidere Assembly
Body Code: PLDL41
Engine: ECB 2.0L 4 Cyl SOHC 16V SMPI Engine
Build Date: November 04, 2004
*H7 Cloth Low-Back Bucket Seats
132S Zone 32-New York
24A Customer Preferred Package 24A
2DAA Customer Preferred Package 2DA
5INS PL-Vehicle Family
APAS Monotone Paint
BANS 120 Amp Alternator
BCUS 450 Amp Maintenance Free Battery
BRAS Power Front Disc/Rear Drum Brakes
CG6S Center Rear 3-Point Seat Belt
CGCS Unique Child Tether Restraint
CKPS Trunk Dress-Up
CLPS Door Sill Scuff Pads
CSAS Spare Tire Cover
CUFS Full Length Floor Console
CUTS Instrument Panel Storage Bin
-DV Dark Slate Gray
GADS Tinted Glass Windows
GBBS Tinted Windshield Glass
GUFS Driver Remote, Pass Manual Mirrors
GXTS Rear Door Child Protection Locks
GXXS Sentry Key Theft Deterrent System
HAA Air Conditioning
I57S Route 57 - CSX & NS, Ridgefield, NJ
JAAS Instrument Panel
JBKS Instr. Panel Accent Color Bezel
JBRP Accent Color PRNDL Bezel
JJFS Single Low Note Horn
JKHS Glove Box
JKKS Inside Emergency Trunk Lid Release
K48S Delete Bodyside Molding
LMBS Halogen Headlamps
LMUS Ft Side Marker/Side Repeater Lamp
LPNS CHMSL Lamp
MFDS Bright Grille
MGNS Dodge Badge
ML6S Front Body Color Fascia
ML7S Rear Body Color Fascia
MNAS Black Door Handles
MUDS Dodge I.D. Badge
MV3S Neon Badge
NB8P Federal Tier 2, Bin 8 Emissions
NBKS EVAP Control System
NFMS 12.5 Gallon Fuel Tank
NHFS Power Steering Cooler
RBBS AM/FM Cass Radio w/Changer Control
RCDS 4 Speakers
RDDS Fixed Long Mast Antenna
SCAS Steering Wheel
SDCS Touring Suspension
SHAP Front Stabilizer Bar
TBCS Compact Spare Tire
TEXS P175/70R14 BSW All Season Tires
W4AS 14" Wheel Covers
WBBS 14X5.5 Black Wheels
YGYA 6.5 Additional Gallons of Gas
ZAUP Spring - Left Rear
ZCGP Spring - Left Front
ZNUP Spring - Right Rear
ZRGP Spring - Right Front
Гость_an60_*
сообщение 19.5.2011, 18:20
Сообщение #333
Будьте добры комплектацию по vin:
1d4gp25b25b262925
Старик Ромуальды...
сообщение 20.5.2011, 7:52
Сообщение #334
1d4gp25b25b262925
D: Dodge
4: Multipurpose Passenger Vehicle w/out Side Air Bags
2: Dodge Caravan/Grand Caravan-SE/CV FWD
5: Wagon
B: 2.4L 14 CYL DOHC Gasoline SMPI
2: Check Digit
5: 05
Body Code: RSKL52
Build Date: September 29, 2004
*A5 Deluxe Cloth High-Back Bucket Seats
0ERA FAM: BR TRACKING: 60820T07
135S Zone 35-Washington
3XPA Popular Equipment Group Discount
639S Pennsylvania State Code
939S Pennsylvania State Code
ALW Popular Equipment Group
APAS Monotone Paint
CTLP Base Door Trim Panel
CWQS Easy-Out® Roller Seats
CWWS Front Cargo Net
CYBS Bucket Seats
CYNS 7 Passenger Seating w/Recline/Fold
DLCS 2.6 Overall Top Gear Ratio
GAE Sunscreen Glass
I64S Route 64 - NS, Newark, DE
-J1 Dk Khaki/Lt Graystone
JPAP Power Windows
JPBP Power Locks
K2RS SRTIPE/BADGE/MOLDING COLOR
LAGS Warning Chime
LCHS Rear Dome Lamp
MLDS Front Molded-In-Color Fascia
MLKS Rear Molded-In-Color Fascia
MSBS Caravan Badge
MURS Dodge Badge
MWG Roof Rack
MXAS Front Air Dam
NHMP Speed Control
PPK Magnesium Pearl Coat
QPKS Magnesium Pearl Coat
RCDS 4 Speakers
SUAP Tilt Steering Column
W5QS 15" Wheel Covers
XZZA Mid Model Year Vehicle Tracking
ZNDP Spring - Right Front
ronin
сообщение 21.5.2011, 13:40
Сообщение #335
Из: люберецкий р-н
Пользователь №: 37 217
Реальное имя:алексей
пожалуйста 1B3AJ46X71N707146
стратус 2.4 2001г-продан(верный конь)
додж калибер 2009г. 2.0
каплей
сообщение 21.5.2011, 15:53
Сообщение #336
Из: Севастополь
Пользователь №: 32 548
Реальное имя:Константин
много непонятных и противоречивых вариантов декодирования.
Помогите, пожалуйста Вы
1C3XAB637NF160300
CHRYSLER Saratoga V6 3.0--fuck fuel economies!
kutuzov_
сообщение 22.5.2011, 21:49
Сообщение #337
Баксозакидатель КК
Из: West MKADout
Пользователь №: 25 128
B: Dodge
3: Passenger Car
A: Restraint Sys. Active Front & Side Air Bags (CGS)
J: Stratus (U.S.)
4: H Series
6: 4 dr. Sedan-Body Style (41)
X: 2.4L 4 CYL 16V Gasoline (SMPI) DOHC (EDZ)
7: Check digit
1: 2001 Model Year
N: Sterling Heights Assembly (Sterling Heights, MI)
Код модели кузова: JRDH41
Двигатель: EDZ 2.4L 4 Cyl DOHC 16V SMPI Engine
Коробка передач: DGL 4-Speed Automatic Transmission
Модельный год: 2001
Дата производства: 26.06.2001
*N8: Cloth Low-Back Bucket Seats
-DV: Dark Slate Gray
133S: Zone 33-Philadelphia
1AAS: U.S. Dealer Retail
24B: Customer Preferred Package 24B
2DBA: Customer Preferred Package 2DB
3VDA: Customer Preferred Discount
594S: Vehicle Order Tracking
608S: Delaware State Code
6USS: Label - U.S. Specifications
908S: Delaware State Code
AJF: Remote/Illuminated Entry Group
APAS: Monotone Paint
AWS: Smoker's Group
BANS: 120 Amp Alternator
BC5S: 510 Amp Maintenance Free Battery
BRSS: 4-Wheel Disc Brakes
BTAP: All Vehicles w/o ABS Brakes
CACS: Low Back Bucket Seats
CF4S: Child Seat Upper Tether Anchorages
CFNP: Rear 60/40 Folding Seat
CG6S: Center Rear 3-Point Seat Belt
CGDS: Front Height Adjust Shoulder Belts
CGS: Supplemental Side Air Bags
CGUS: Child Seat Anchor System-LATCH Ready
CGWS: Next Generation Front Air Bags**
CHKS: Base Headliner Module
CJ2P: Supp. Side Curtain Frt/Rr Air Bags
CKBS: Floor Carpet
CKPS: Trunk Dress-Up
CLES: Front & Rear Floor Mats
CUFS: Full Length Floor Console
CUKP: Removable Ash Tray
CUTS: Instrument Panel Storage Bin
DGBS: All 4-Speed Automatic Transmissions
DGL: 4-Speed Automatic Transmission
DHAS: Lock-Up Torque Converter
DLDP: 2.7 Overall Top Gear Ratio
EAAC: All Engines
EDZ: 2.4L 4 Cyl DOHC 16V SMPI Engine
GADS: Tinted Glass Windows
GBCS: Front & Rear Solar Control Glass
GFAS: Rear Window Defroster
GNAS: Rear View Day/Night Mirror
GNEP: Passenger Side Sun Visor w/Mirror
GNFP: Driver Side Sun Visor w/Mirror
GURS: Power Mirrors
GXRP: Keyless Entry
GXTS: Rear Door Child Protection Locks
HAAS: Air Conditioning
HGAS: Hood Insulation
I64S: Route 64 - NS, Newark, DE
JAAS: Instrument Panel
JCBS: 120 MPH Primary Speedometer
JFHS: Tachometer
JHAS: Var Intermittent Windshield Wipers
JJAP: Cigar Lighter
JJBS: Dual Note Electric Horns
JKAS: Locking Glove Box
JKFS: Cowl Mounted Hood Release
JKKS: Inside Emergency Trunk Lid Release
JKPS: 12V Auxiliary Power Outlet
JPBS: Power Locks
JPCS: Power Trunklid Release
JPDS: Power Windows, Driver One-Touch
K3JS: STRIPE/BADGE/MOLDING/COLOR
LACP: Illuminated Entry
LAMS: Door Ajar Warning Lamp
LANS: Decklid/Liftgate Ajar Warning Lamp
LBCS: Glove Box Lamp
LDCS: Trunk Lamp
LHDS: Headlamp Off Time Delay
LMAS: Halogen Headlamps
MDA: Front License Plate Bracket
MFCS: Dark Silver Metallic Grille
MGKS: SE Badge
MHAS: Black Windshield Moldings
MLAS: Body Color Fascias
MU5S: Dodge Badge
MVRS: Dodge Stratus Badge
NAA: Federal Emissions
NBVP: Low Emission Vehicle (LEV)
NFZS: 16 Gallon Fuel Tank
NHMS: Speed Control
PS2: Bright Silver Metallic Clear Coat
QS2S: Bright Silver Metallic Clear Coat
RBBS: AM/FM Cass Radio w/Changer Control
RCDS: 4 Speakers
SBAS: Power Rack and Pinion Steering
SCHS: Sport Steering Wheel
SDCS: Touring Suspension
SHCS: Front and Rear Stabilizer Bars
SUAS: Tilt Steering Column
TBCS: Compact Spare Tire
TPTS: P205/65R15 BSW All Season Tires
TZAP: Goodyear Brand Tires
W5DS: 15" Wheel Covers
WCFP: 15X6.0 Black Wheels
WLYC: All Steel Wheels
XSLP: Brake/Park Interlock
XVTS: Tip's Card
YAAS: Build To U S Market Specifications
YCBS: Motor Vehicle Theft Protection
YEP: Manuf Statement of Origin
YGFA: 8 Additional Gallons of Gas
ZCCP: Spring - Left Front
ZCSP: Spring - Left Rear
ZRBP: Spring - Right Front
ZRSP: Spring - Right Rear
Гость_vudim_*
сообщение 23.5.2011, 10:01
Сообщение #338
1С8GYB1525Y558405
Вадим2
сообщение 24.5.2011, 18:38
Сообщение #339
Из: Москва ЮАО
Реальное имя:Вадим
1С8GYB1525Y558405
C: Chrysler
Y: Voyager/Grand Voyager Left Hand Drive (FWD)
B: 4 Speed Automatic
1: Van
5: 2.8L I4 CYL Turbo Diesel
2: Check digit
5: 2005 Model Year
Y: Chrysler Steyr Assembly
Код модели кузова: RGYS53
Двигатель: ENR 2.8L 4 Cyl Turbo Diesel Engine
Модельный год: 2005
Дата производства: 14.06.2005
*ML: Leather Trimmed Bucket Seats
-D5: Med Slate Gray
0BCA: FAM
0BDA: FAM
0BEA: FAM
0BIA: FAM
0BPA: FAM
0BSA: PCN 65610-704 0BS
106S: Zone 06-Export
1AUS: Export Homologated
24X: Customer Preferred Package 24X
2LXA: Customer Preferred Package 2LX
3D2A: Intl. Price Protection B
3HGA: Coso Wt. & D.M.
3HQA: Market Homologation
3HWA: Export Ocean Freight
3HZA: Export Insurance
44M: Intl Priority Sched Tracking
4ALA: 1NTL 37 DAY SCHEDULE
4HC: Special Scheduling Condition III
4XTA: Delete Domestic Warranty Manual
4YBA: Export Option Requirements
595S: Long Wheel Base (LWB)
5I8S: Left Hand Drive (LHD)
5IAS: Overseas Families
5Z9S: RG-Vehicle Family
6CTP: Certificate of Conformance
6EMP: Label - European E Mark
6MPP: Plate - Manufacturer
878P: Western Europe Region Group
895A: European Region
8DBA: Italy Country Code
ABBA: European Equipment Group
AWS: Smoker's Group
BABS: 160 Amp Alternator
BCVP: 700 Amp Maintenance Free Battery
BGFS: Anti-Lock Brakes
BNMS: Traction Control
BRES: 4-Wheel Disc Brakes
CBLP: Suede Door Trim Panel w/Map Pocket
CGYS: Drvr Inflatable Knee-Bolster Air Bag
CJ5S: Supp. Side Curtain All Rows Air Bags
CKAS: Carpets - Floor and Cargo Area
CMAS: Heated Front Seats
CSCS: Cargo Compartment Cover
CUUP: Non-Locking Underseat Storage Drawer
CUWS: Lockable Underseat Storage Drawer
CUXP: Front & Rear Ash Trays
CVV: Removable Center Frt Seat Console
CWRP: Long Overhead Rail System
CWVP: O/Head Console w/Trip Computer/EVIC
CWXP: Front and Rear Cargo Nets
CWZP: 2 Row Stow 'N Go w/Tailgate Seats
CYCS: 2nd Row Buckets 60/40 Bench Seats
DHAP: Lock-Up Torque Converter
DLLP: 2.68 Overall Top Gear Ratio
ENR: 2.8L 4 Cyl Turbo Diesel Engine
GAE: Sunscreen Glass
GKBS: Right Sliding Door w/Fixed Glass
GKDS: LT Sliding Door w/Glass
GNCS: Sun Visors w/Illum Vanity Mirrors
GNKS: Rear View Auto Dim Mirror
GPBS: Pwr Fldg Htd Drvr Memory Mirrors
GXRS: Keyless Entry
GXXS: Sentry Key Theft Deterrent System
HAJP: Air Cond ATC w/Dual Zone/Mode Cntrl
HGAP: Hood Insulation
HGDS: Deluxe Insulation Group
JA6S: Electroluminescent Instr Cluster
JAPS: Instrument Panel
JBJS: Instrument Panel Woodgrain Bezel
JDGS: 220 KPH Primary Speedometer
JHBS: Rear Window Wiper/Washer
JHSS: Headlamp Washer
JJAP: Cigar Lighter
JKGS: Power Quarter Vented Windows
JKLS: Headlamp Leveling System
JMAP: Air Filtering
JP7S: Power Frt 8-Way Seat w/Drvr Memory
JPBS: Power Locks
JRAS: Right Power Sliding Door
JRBS: Left Power Sliding Door
JRCS: Power Liftgate
LAAS: Ignition Time Delay Lamp
LACS: Illuminated Entry
LAKS: Headlamps On Warning Chimes
LALS: Low Washer Fluid Warning Signal
LAZP: Vehicle Information Center
LBES: Cigar Lighter
LBTS: Overhead Ash Tray/Cupholder Lamp
LCBS: Door Courtesy Lamps
LCDS: Map/Dome Reading Lamps
LCES: Rear Courtesy/Reading Lamps
LDGS: Liftgate Flood Lamps
LEJP: Trip Computer
LMDS: Front European Turn Signal
LMFS: Side Repeater Lens
LMHS: Halogen E Marked Headlamps
LNJS: Fog Lamps
LPBS: Rear License Plate w/Lamp Bracket
LPCS: European Tail Lamps
LSAS: Security Alarm
MLES: Front Body Color/Chrome Fascia
MLNS: Rear Body Color Fascia
MNKS: Body Color Door Handles
MNPS: Bright License Plate Brow
MRBS: Lower Bodyside Cladding
MSAS: Limited Badge
MSNS: Grille Chrysler Wing Badge
MSPS: Grand Voyager Badge
MU3S: Chrysler Badge
MWGS: Roof Rack
MXAS: Front Air Dam
MYBP: Stow'N Go Badge
MZRP: Common Rail Diesel Badge
NA1S: Export Emissions
NB3P: Euro Stage III Emission Vehicle
NFAS: 20 Gallon Fuel Tank
NHAP: Engine Oil Cooler
NHBP: Auxiliary Transmission Oil Cooler
NHMS: Speed Control
PB7: Patriot Blue Pearl Coat
QB7S: Patriot Blue Pearl Coat
RCES: Infinity Speakers
RDN: 6-Disc in Dash CD Changer
RDZS: Steering Wheel Mounted Audio Ctrls
REKS: AM/FM Compact Disc RDS Radio
SCLS: Leather Wrapped Steering Wheel
SDFS: Euro Suspension
SERS: Load Leveling and Height Control
TBMP: Tire Carrier Winch
TMMS: 215/65R16 BSW Touring Tires
XEAS: Tow Hooks
XFAS: -35F Protection Anti-Freeze
XJHS: Locking Fuel Filler Cap
YABS: Build To Export Mkt. Specifications
каплей
сообщение 25.5.2011, 10:36
Сообщение #340
Из: Севастополь
Будьте добры!
1C3XAB637NF160300
RSS Текстовая версия Сейчас: 2.8.2026, 0:46Дизайн IPB
