Вопрос Neon Sxt 2004, 132 hp & 150 hp |
Гость_dobre_* |
30.11.2007, 13:50
Обнаружил что неоны схт бывают 132 и 150 сильные , кто-то может рассказать поподробнее ?
Гость_zumer_* |
30.11.2007, 14:03
150 сил у RT а не SXT
Гость_dobre_* |
30.11.2007, 14:06
150 сил у RT а не SXT Sales of the second generation model started with model year 2000 and production ended with the 2005 model year. The second generation Neon was only available as a 4-door sedan. In some regions, including the United States, the sole engine was the 2.0 L SOHC engine, the power output remaining at 132 HP (98 kW). It also came with an optional Magnum configuration (including an active intake manifold) that produced 150 HP. Both engines had a redline of 6762 RPM. |
Гость_zumer_* |
30.11.2007, 14:32
150 сил у RT а не SXT Sales of the second generation model started with model year 2000 and production ended with the 2005 model year. The second generation Neon was only available as a 4-door sedan. In some regions, including the United States, the sole engine was the 2.0 L SOHC engine, the power output remaining at 132 HP (98 kW). It also came with an optional Magnum configuration (including an active intake manifold) that produced 150 HP. Both engines had a redline of 6762 RPM. И где там сказано про СХТ? |
Гость_RoadLASER_* |
30.11.2007, 14:38
150 сил у RT а не SXT Sales of the second generation model started with model year 2000 and production ended with the 2005 model year. The second generation Neon was only available as a 4-door sedan. In some regions, including the United States, the sole engine was the 2.0 L SOHC engine, the power output remaining at 132 HP (98 kW). It also came with an optional Magnum configuration (including an active intake manifold) that produced 150 HP. Both engines had a redline of 6762 RPM. Изучайте буквари http://www.carsdirect.com/research/compare...0,USB20DDC031E0 |
Гость_zumer_* |
30.11.2007, 15:01
150 сил у RT а не SXT Sales of the second generation model started with model year 2000 and production ended with the 2005 model year. The second generation Neon was only available as a 4-door sedan. In some regions, including the United States, the sole engine was the 2.0 L SOHC engine, the power output remaining at 132 HP (98 kW). It also came with an optional Magnum configuration (including an active intake manifold) that produced 150 HP. Both engines had a redline of 6762 RPM. Изучайте буквари http://www.carsdirect.com/research/compare...0,USB20DDC031E0 Тогда уж вот так будет в тему http://www.carsdirect.com/research/compare...0,USB40DDC031C0 |
Гость_dobre_* |
30.11.2007, 15:34
Спасибо за обьяснение просто споткнулся об это
VIN 1B3ES56CX4D638318 Year/Make/Model: 2004 DODGE NEON SXT |
Гость_zumer_* |
30.11.2007, 15:36
Спасибо за обьяснение просто споткнулся об это VIN 1B3ES56CX4D638318 Year/Make/Model: 2004 DODGE NEON SXT Чего-то там напутали с лошадями. 150 сил только с механикой. Изучил вопрос досконально при покупке своего. |
Гость_RoadLASER_* |
30.11.2007, 15:44
Спасибо за обьяснение просто споткнулся об это VIN 1B3ES56CX4D638318 Year/Make/Model: 2004 DODGE NEON SXT Бывает. А еще часто пишут, типа, ESP, VSC и т.д. Видел Стратус 2.4л на коже с обогревами, с борткопьютером, трекшном и климат-контролем (машина без пробега по РФ), который по базе идет даже без АБС. |
Гость_RoadLASER_* |
30.11.2007, 15:46
Гость_dobre_* |
30.11.2007, 15:57
Еще тогда вопрос , это адекватная цена , или за эти деньги на заказ можно взять лучше неон ? и насколько .. лучше просто ждать долго а машина щас нужна ...
Сообщение отредактировал dobre - 30.11.2007, 15:59 |
Гость_RoadLASER_* |
30.11.2007, 17:46
Конечно, дорого. Это ведь самый простой вариант. VIN запроси у продавца
Текстовая версия | Сейчас: 28.4.2024, 14:31 |
