> Ошибка P1389 как ее лечить, додж стратус 02
Bars80
сообщение 22.8.2008, 8:02
Пользователь №: 14 066
Ошибка p1389 как ее лечить. Что такое реле ASD?
Гость_Alexcomrad_*
сообщение 22.8.2008, 8:19
http://forum.chrysler-dodge.ru/index.php?s...53&hl=P1389
Bars80
сообщение 22.8.2008, 8:54
Цитата(Alexcomrad @ 22.8.2008, 9:26) *
Спасибо .
Но гед это хоть находиться? на фишке С3 IPM перегнил управляющий проводок ASD
в предохранителях?
Serg
сообщение 22.8.2008, 10:00
Администратор
Группа: Админ форума
Из: г.Москва, Тушино
Пользователь №: 5
P1389
No ASD Relay Output Voltage At PCM
No Z1 or Z2 voltage sensed when the auto shutdown relay is energized.
AUTO SHUT DOWN RELAY
DESCRIPTION
The relay is located in the Power Distribution Center
(PDC). For the location of the relay within the
PDC, refer to the PDC cover for location. Check electrical
terminals for corrosion and repair as necessary
OPERATION
The ASD sense circuit informs the PCM when the
ASD relay energizes. A 12 volt signal at this input
indicates to the PCM that the ASD has been activated.
This input is used only to sense that the ASD
relay is energized.
When energized, the ASD relay supplies battery
voltage to the fuel injectors, ignition coils and the
heating element in each oxygen sensor.
When energized, the ASD relay provides power to
operate the injectors, ignition coil, generator field, O2
sensor heaters (both upstream and downstream),
(EGR solenoid and PCV heater if equipped) and also
provides a sense circuit to the PCM for diagnostic
purposes. If the PCM does not receive 12 volts from
this input after grounding the ASD relay, it sets a
Diagnostic Trouble Code (DTC). The PCM energizes
the ASD any time there is a Crankshaft Position sensor
signal that exceeds a predetermined value. The
ASD relay can also be energized after the engine has
been turned off to perform an O2 sensor heater test,
if vehicle is equipped with OBD II diagnostics.
As mentioned earlier, the PCM energizes the ASD
relay during an O2 sensor heater test. This test is
performed only after the engine has been shut off.
The PCM still operates internally to perform several
checks, including monitoring the O2 sensor heaters.
© Serg '2012
Serg
сообщение 22.8.2008, 10:05
Администратор
Пользователь №: 5
POWER DISTRIBUTION
CENTER
DESCRIPTION
All of the electrical current distributed throughout
this vehicle is directed through the standard equipment
Power Distribution Center (PDC). The molded
plastic PDC housing is located in the left front corner
of the engine compartment. The PDC housing has a
molded plastic cover that includes an integral hinge
feature on the inboard side, and an integral latch on
the outboard side.
The PDC cover is easily removed
for service access and has a convenient fuse and
relay layout label affixed to the inside surface of the
cover to ensure proper component identification.
The PDC housing is secured in the engine compartment
on the left front corner with three screws to the
transmission and engine control module bracket. A
small red molded plastic protective cover on the top
near the rear of the PDC is unsnapped to access the
battery/generator cable input connection stud. All of
the PDC outputs are through the integral engine
compartment wire harness, which exits from the rear
of the PDC housing.
© Serg '2012
Bars80
сообщение 22.8.2008, 10:22
Цитата(Serg @ 22.8.2008, 11:12) *
ОВЕРКВОТИНГ!!!
Спасибо конечно, но в английском я не силен. По русски бы
Serg
сообщение 22.8.2008, 11:40
Администратор
Пользователь №: 5
ASD реле находится в PDC.
PDC - под капотом.
На крышке PDC всё расписано.
© Serg '2012
Bars80
сообщение 22.8.2008, 12:56
PDC - под капотом.
Ну вот теперь понятно. Спасибо огромное
КОМА
сообщение 30.5.2015, 10:40
Из: Тула
Пользователь №: 34 429
Реальное имя:Андрей
Вояджер 2001г.2.4л. ошибка р1389 .Машина перестала заводится нет искры,бывало что и заводилась ,глохла на ходу,на холостых сбои в работе двигателя,открыл крышку монтажного блока усллышал что при сбоях ДВС щёлкает реле ASD,поменял реле местами не помогло,исключил выход из строя реле.Ошибку исправил только тогда когда машина перестала совсем заводится,был перебит провод в жгуте (коричневый) под передним левым колесом,жгут идёт в монтажный блок.
ALEXAM
сообщение 3.11.2016, 21:10
Пользователь №: 62 343
Цитата(КОМА @ 30.5.2015, 11:40) *
Вояджер 2001г.2.4л. ошибка р1389 .Машина ,бывало что и заводилась ,глохла на ходу,на холостых сбои в работе двигателя,открыл крышку монтажного блока усллышал что при сбоях ДВС щёлкает реле ASD,поменял реле местами не помогло,исключил выход из строя реле.Ошибку исправил только тогда когда машина перестала совсем заводится,был перебит провод в жгуте (коричневый) под передним левым колесом,жгут идёт в монтажный блок.
Такая же хрень, неуверенная работа ДВС, сбои в работе двигателя, глохла на ходу,на холостых, далее перестала заводится нет искры. В блоке ошибка р1389, стер её больше не проявляется, но всё равно не заводится. Кто подскажет что может быть ещё?
Сообщение отредактировал ALEXAM - 3.11.2016, 21:11
ALEXAM
сообщение 3.11.2016, 21:45
На датчике колена если смотреть спереди на фишку на крайнем левом пине 5 вольт на правом 9 вольт, средний я так понимаю сигнальный, Авто Кантри 3.8 2001 г.
RSS Текстовая версия Сейчас: 21.8.2025, 6:20Дизайн IPB
